Hp dv6700
  • orientalsniper
    • Apr 2013
    • 459
    Hp dv6700
    Got this laptop, charger LED lights up when it's plugged in, battery LED does not light up.
    I tried shorting G1 (is that a power switch?) and nothing happens.
  • Tuomo
    • 163
    • Finland
    Re: Hp dv6700
    I think you should start measuring PQ61 voltages.
    • orientalsniper
      • Apr 2013
      • 459
      Re: Hp dv6700
      I only see pads in PQ61
      • Tuomo
        • 163
        • Finland
        Re: Hp dv6700
        Do we have same shematics DV 6700 Intel_quanta_at3?
        I quess I have different schematics. Can you post your schematic?
        PQ61 should be near AC Input and it should be 8 Pin Mosfet.
        • orientalsniper
          • Apr 2013
          • 459
          Re: Hp dv6700
          I don't really see PQ61, I see PQ30, PQ31, PQ32, PQ33, PQ34
          • Tuomo
            • 163
            • Finland
            Re: Hp dv6700
            Yes, PQ61 is MosFet on DV6700 intel motherboard.
            You have other model and there is different names.
            What is your motherboard type and is it Intel or Amd?
            • orientalsniper
              • Apr 2013
              • 459
              Re: Hp dv6700
              The specific model is: DV6990LA, uses AMD processor.
              • Tuomo
                • 163
                • Finland
                Re: Hp dv6700
                Thank you. Unfortunately I can not find this model schematics.
                • orientalsniper
                  • Apr 2013
                  • 459
                  Re: Hp dv6700
                  Forgive me, but is there a basic standard test to follow for a dead motherboard diagnosis?
                  • orientalsniper
                    • Apr 2013
                    • 459
                    Re: Hp dv6700
                    I gave up, told him just to replace motherboard, that's another board to the landfill.
                    • flat-earther
                      ASUS X54H laptop thinks it's always charging even with charger unplugged
                      by flat-earther
                      The charging indicator light on my ASUS X54H laptop is always on even when the charger is disconnected.
                      Windows also shows ''Plugged in'' when charger is not connected.
                      This problem started year ago gradually, when unplugging the charger the charging light took several seconds to disappear, then minutes, and now almost always on even when unplugged for an entire day.
                      Strangely, before sometimes immediately when plugging in the charger the charging light went away, and later came back with it connected.
                      If I let battery run out and say it has 3% Windows will...
                      06-24-2025, 09:32 AM
                    • motormayhem
                      Lenovo T460 Only Charges on One Charger
                      by motormayhem
                      Laptop Question
                      I'm working on a Lenovo T460 that has been having trouble charging as of late. Its worked well since I've owned it for a few years. When I went to use it the other day it was dead and wouldn't turn on (was sitting on an Anker 65W GaN charger). After some fiddling with the charger I got it to turn on and start charging, but seemed like the charger was not working as it should (took a few plug and unplug cycles to get it to start charging).
                      A day later it was dead again and wouldn't boot/charge no matter what I did. No lights or anything when...
                      05-12-2023, 01:46 PM
                      NVDC charger configuration...
                      11-05-2024, 03:28 PM
                    • Johndill
                      Dell Inspiron 7567 LA-D993P odd charger issue
                      by Johndill
                      Hi, I have a Dell Inspiron 7567 LA-D993P that I've just got running.
                      There was corrosion around PU1503 which shorted PC1518 & blew PL1504. (Reference pictures attached)
                      I've replaced PC1518 & PL1504 & the laptop is now running however I now have another issue.
                      Here are the tested scenarios:
                      1. With the laptop running on battery, I plug in the 150W charger & the charger shuts off (no LED, protection mode) but the laptop remains running on battery.
                      2. With the laptop off, plug in charger (LED says on) & the front charging...
                      11-16-2022, 10:55 PM
                      ISL6257HRZ ISL6257HRZ-T Laptop Battery Charger Datasheet
                      Highly Integrated Narrow VDC Battery Charger for Notebook Computers
                      The ISL6257HRZ ISL6257HRZ-T is a highly integrated battery charger controller
                      for Li-Ion/Li-Ion polymer batteries. ISL6257 is designed for
                      Narrow VDC applications where the system power source is
                      either the battery pack or the regulated output of the charger.
                      This makes the max voltage to the system equal to the max
                      battery voltage instead of the max adapter voltage. Operating
                      at lower system voltage can improve...
                      11-05-2024, 04:43 PM
