my issue is that when i open the lid of the laptop the screen turns pink diffrent colors the thing is if u catch it at the right angle u get the normal screen . has any body noticed that on these laptops as after some digging iv seen that the metal brackets on the lcd screen that are screwed to the laptop base the one on the left has snapped. which i thibnk has maybee loosened the solder joints of the connector for the inverter cable connection to laptop mb hope iv made sense explaining this thankyou .
toshiba equiem p300 laptop screen flicker
Re: toshiba equiem p300 laptop screen flicker
you may have a bad connection on ribbon, or a damaged ribbon due to broken hingemy issue is that when i open the lid of the laptop the screen turns pink diffrent colors the thing is if u catch it at the right angle u get the normal screen . has any body noticed that on these laptops as after some digging iv seen that the metal brackets on the lcd screen that are screwed to the laptop base the one on the left has snapped. which i thibnk has maybee loosened the solder joints of the connector for the inverter cable connection to laptop mb hope iv made sense explaining this thankyou .
replace hinge as soon as possible, before other good hinge snaps or rips screw studs off the lid, then you would need to buy new lid -
Hi I have a similar problem with my laptop.
Toshiba Satellite P200-1EE
Model no:PSPB6E-0GMO28EN
Mainboard: ISRAA LA-3441P
The LCD is blank and only get a 1 second white flash then blank as laptop continues its boot up. I have changed the Inverter and no joy, I have a working backlight out of a smashed screen and when connected into a tested Inverter it doesn't light up at all. The laptop will work fine when connected to an external display. If anyone has had a similar issue any help would be greatly appreciated. I have read on different sites this is a common problem with Toshiba Voltage regulators is this true many thanks in advance.Comment
by VcemPzdHello everyone !
My name is Chris, I am a 30 years old embedded software developer working in the automotive industry. I am really passionate about learning new skills and repairing/crafting stuff. I came around this forum last week with the goal of repairing my faulty gaming laptop, indeed, I was video editing on it when suddenly a black screen popped and never disappeared
I bought some stuff to try to repair it and learn as many things as possible about computer repairs but nothing worked so far. When the black screen appeared, my legion 5 pro was connected to my external monitor...
Toshiba Satellite P300 P305 Laptop Schematic...
Channel: Schematics and Boardviews
10-17-2024, 09:38 AM -
by StuntHi guys i've got an Hp laptop Zbook 17 g5 Stuck on Hp protected by hp sure start screen.
I have tried almost every bios available on various platforms about this laptop but the problem is still the same.
I even successfully build my own bios using the one from the Hp website but the problem the laptop still getting stuck there.
Even if i try to press Esc key nothing happens. I tried f10 it doesn't go to bios still stuck there i just saw entering setup menu on the bottom left corner of the
screen that's it and stuck there. I left it until the following day and i still...09-02-2025, 01:51 PM -
on this laptop hp g72 b52sf i have screen problems as you can see with the photo joined in attachments.
the used graphic card is "intel hd graphics" and the id of the integrated screen is : "monitor/SEC3354".
i verified the driver of the péripherals and they are ok. i verified the definition and settings of the graphic card and of the screen : definition 1600x900 and refreshment frequency :60hz. (they are the sames for the graphic card and the screen).
i don't understand the reasons of the white stripe at the bottom of the screen below the task... - Loading...
