laptop battery repair
  • masud
    • Jul 2011
    • 317
    • Bangladesh
    is there any practical idea on laptop battery repair.
    plz share.
  • spidey
    climbs
    • Dec 2012
    • 644
    • Cyprus
    Re: laptop battery repair
    just change it, it doesnt worth to fix.
    • severach
      • Aug 2007
      • 1055
      There are lots of companies that rebuild battery packs.
      sig files are for morons
      • masud
        • Jul 2011
        • 317
        • Bangladesh
        many times we cant get some models of battery. that's why it is impotent to know how to repair a battery unit.
        • kc8adu
          • Nov 2003
          • 8832
          • U.S.A!
          i have restuffed a few.ones not easy/cheap to buy.
          lots of sources for 18650 cells.
          • smason
            • 1652
            True, but most only repair NiCd and NiMH and will say "no way" to a Li-Ion pack.
            The potential for a Li-Ion pack to do "bad things" whether re-built correctly or not, scares the re-builders, as they don't want the liability.
            That and some packs have some "smarts" on them, that sometimes prevent rebuilding them.
            • serious_electron
              Strange! Acer laptop not powering on but charging the battery (orange light on when charger and battery plugged in).
              by serious_electron
              Hello Everyone!
              I have an Acer Aspire A315-42 laptop. I generally leave it on for long time by closing down its lid (so it enters the sleep mode). Recently, it rained quite heavily in out area. And the humidity and moisture seem to be high. So one late evening, after I opened the lid and turned on the laptop, it did power on as the blue light turned on but after it booted to the desktop screen, just 5-10 seconds after both the screen and blue light went out and laptop shut down (the blue power light turned orange). And after 2-4 seconds that orange light went off and the laptop died.
              06-28-2025, 02:57 PM
            • Bowline
              by Bowline
              06-11-2025, 10:13 AM
            • ahmarzo
              Acer TMX314-51 laptop battery problem
              by ahmarzo
              I have acer laptop tmx314-51 with part no 6050A3020501.
              The laptop is working fine on adapter and battery is also charging and when adapter is disconnected in on state the laptop gives backup on battery and gives good backup.
              But when laptop is powered on through battery only the laptop does not power on and there is 0 voltage on battery connector.
              I have not not tried another battery as it is not available locally could this be a battery problem.have checked discharging mosfet and there is no shorting to ground on any pin of battery connector.
              The schematic is not available...
              04-11-2025, 09:14 AM
              ISL6257HRZ ISL6257HRZ-T Laptop Battery Charger Datasheet
              Highly Integrated Narrow VDC Battery Charger for Notebook Computers
              The ISL6257HRZ ISL6257HRZ-T is a highly integrated battery charger controller
              for Li-Ion/Li-Ion polymer batteries. ISL6257 is designed for
              Narrow VDC applications where the system power source is
              either the battery pack or the regulated output of the charger.
              This makes the max voltage to the system equal to the max
              battery voltage instead of the max adapter voltage. Operating
              at lower system voltage can improve...
              11-05-2024, 04:43 PM
              NVDC charger configuration...
              11-05-2024, 03:28 PM
