emachine hangs-on E-logo
  • welhim
    • Feb 2013
    • 40
    • philippines
    hello...please help me..i have a emachine e727 hangs on E-logo only.. ..i cant access the bios,,,when i press f2 it just says ''Please Wait'' and cant enter bios..even f8 for safe mode i cant access..
    already done:
    replaced Memory - same
    replaced Processor - same
    removed removable parts...HDD,ODD,WIFI, etc
    reseted Cmos Battery and short..
    removed Cmos and Bios IC
    reseated Mosfet ICs
    REflowed Video Chips ''slight''
    drained the board for 1 day
    BUT no LUCK..please helppp
    and Thanks n advanced......
  • masud
    • Jul 2011
    • 317
    • Bangladesh
    Re: emachine hangs-on E-logo
    install another good hdd and try.
    • fddizon
      • Sep 2011
      • 555
      • Philippines
      in addition to masud statement...
      if you have no extra hard disk, just remove the hard disk and test if you can enter bios settings. if u r able to do so, replace hard disk.
      • spidey
        climbs
        • Dec 2012
        • 644
        • Cyprus
        re-program the bios.
        • welhim
          • Feb 2013
          • 40
          • philippines
          hello sir spidey...do you any idea how to flash the bios on this kinda?..if you have some link or procedure please please share,...thank you so much Sir,..
          • welhim
            • Feb 2013
            • 40
            • philippines
            i already removed the hdd sir..and stil cant...i also removed all removable parts..ODD,KB,WIFI,LAN CARD>...and even USB PORT,AUDIO PORT,LAN PORT via hardware,,,and still cant continue..
            • welhim
              • Feb 2013
              • 40
              • philippines
              San ka sa phils sir? eheh...nagawa ko na sir..lahat removed ko nah..but no luck..
              • c_hegge
                • Sep 2009
                • 5219
                English only, please!!
                • spidey
                  climbs
                  • Dec 2012
                  • 644
                  • Cyprus
                  desolder flash chip and program it with an eprom programmer.
                  • welhim
                    • Feb 2013
                    • 40
                    • philippines
                    hello sir spidey do you some Idea like just flashing the bios without reprogramming it?
                    • spidey
                      climbs
                      • Dec 2012
                      • 644
                      • Cyprus
                      i dont understand what you mean. just desolder it. search internet for a simple parallel port programmer for 8 pin sop serial eeprom. it is just a couple of wires and resistors, i remember i've already shared one in an earlier post.
                      • RobRocks
                        • 13
                        Buy the willem eprom programmer, its cheap and works with almost all chips. Iam using it every day it has saved me a lot of troubles.
                        http://sivava.com/
                        • spidey
                          climbs
                          • Dec 2012
                          • 644
                          • Cyprus
                          http://sivava.com/
                          i am also using villem. pcb 7.5C
                          • ismy4real
                            • Dec 2011
                            • 87
                            thanks for sharing this Spidey one more thing we can i get to buy 13DB bios reset software
                            • dqtech
                              lenovo thinkpad t420 wont turn on when cmos battery attached
                              by dqtech
                              please help...this lenovo thinkpad t420 early problem is short 19v...after replace short capacitor all working fine...but, when i attach cmos battery on motherboard this laptop wont turn on, power button not respond....it only work without cmos battery....power button and cmos battery is in good condition...i try replace new cmos battery but problem still persist...any idea?...
                              06-16-2023, 03:56 AM
                            • magistertc
                              CMOS battery drains quickly
                              by magistertc
                              This problem is based on my experience with an ASUS Z390 Prime motherboard, but it appears to affect other motherboards
                              as well Install a new CMOS battery, configure computer, turn off computer and disconnect from AC power or switch off SMPS.
                              Return somewhat later and find that battery is drained, dead, or weak. Clock is wrong, other settings lost, etc.
                              Examine the power 'sharing' circuit -- when the ATX 3V supply is on, the computer will function normally. The computer is also
                              configured to support the RTC and some volatile RAM (when SMPS is on). What you may...
                              07-06-2024, 09:55 AM
                            • rumpumpel1
                              ThinkPad T470 does not power up with CMOS battery attached
                              by rumpumpel1
                              I have a ThinkPad T470 that will not boot when the CMOS battery is plugged in.
                              With only the fan, a RAM module and a USB-C monitor attached, but no CMOS battery, it starts up normally, i.e. after about 90 seconds and two reboots, it stops with a message to press F1 to enter date & time.
                              If the power is switched off and a CMOS battery is inserted, it restarts as described above. However, after switching it off and on again, it does not turn on. It draws almost no current and shows no sign of life.
                              I used a different CMOS battery and checked the components around the battery...
                              04-27-2023, 10:46 AM
                            • valente222
                              DELL Inspiron Mb FDI55 LA-J081P REV 1.0 A00 error batery CMOS
                              by valente222
                              Hello everyone, I have this DELL computer. problem when turning on it does not show an image. Diagnostic LED indicates CMOS battery failure. I measure the battery and 3v is fine. When turned on with battery CMOS consumption of 240mA. By removing the CMOS battery it can consume 800mA and sometimes gives an image when it wants. This happened after a while of installing an SSD. Will ME be corrupted by Windows?...
                              03-15-2024, 10:28 AM
                            • GIGA10
                              Gigabyte G5 KE Clearing CMOS won't reset BIOS Admin password
                              by GIGA10
                              Hello everyone. I'm not sure if this post belongs in this section? If not, please kindly move it to right section Mod/Admin.
                              I have a Gigabyte G5 KE laptop and I have forgotten the BIOS Admin password. I can enter BIOS menu but when trying to enter BIOS settings it ask for my password which I have forgotten. I can boot also in to Windows 11. I have tried to clearing CMOS by removing the CMOS battery for 10h. I have tried also to remove both power battery and CMOS battery and bridge the CMOS 2 pin connector on the motherboard. Then when booting I get a message that NVRAM has been...
                              12-23-2022, 03:31 AM
