Dell d630 dead problem
  • Trigri waley
    • Mar 2013
    • 12
    • Pakistan
    dell latitude d630 all screen leds blinks one time and turn off
    send solution of this problem plzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzz
  • smason
    • 1652
    Re: Dell d630 dead problem
    Wow, how many dead laptops with blinking LEDs do you have?
    • ojhaslo
      • Feb 2015
      • 6
      • POLAND
      may have died power slot, battery is functional?
      • SDNarcia
        Dell 15R-5521 keyboard problem (KBC?)
        by SDNarcia
        Hello, I have a Dell 15R-5521, with the problem that the Ctrl, Alt, Shitf and Num Lock keys do not work, I tested the keyboard with a keyboard tester and it is functional, I also got another new keyboard and the computer has the same problem with the same keys. Check continuity between the ZIF connector from the keyboard to the KBC and all pins are correct. I cleaned the ZIF connector and the KBC and I still have the same problem. I reinstalled windows just in case, and it didn't work. I updated the BIOS to the latest version A16 and there were no changes.
        As additional information,...
        07-20-2024, 10:47 PM
      • Achille15
        Dell N5110 problem
        by Achille15
        so, I have this laptop Dell Inspiron N5110 with a heating problem on both CPU (I7-2680qm) and GPU (GT 525m), I tried many solutions, like changing thermal paste every month, using thermal pads on CPU and GPU, even using thermal pads on CPU nearby coils; but nothing worked, just minutes after booting the laptop shuts itself down so I thought it might be a short problem, so I decided to check what's going on, so I went online and some tutorial (general one) said to check inductors in order to find the shorted circuit, after checking (CPU removed), I found the culprit to be...
        03-29-2025, 04:41 PM
      • HTR-Informatique
        Dell G3 15 3500 - Battery bug (black screen and flashing keyboard backlight)
        by HTR-Informatique
        YouTube video of the problem encountered: https://youtube.com/shorts/q7TLNv36LUo
        I am a pro and I have a problem that I have never seen despite my 7.5 years of experience on my own and my thousands of repairs, on a customer's Dell G3 15 3500.
        On this PC I have already changed the complete palmrest because the keyboard was no longer working properly.
        I also changed the screen because the PC fell and the screen was broken.
        I changed the battery with a new and original battery.
        I also had corrosion/oxidation on the...
        02-09-2025, 06:51 AM
      • masoksian
        Dell latitude e7470 not turn on .power buton on off and Run Power problem
        by masoksian
        I am dealing with the problem of turning on and off my Dell e7470 notebook.
        The battery charge light is solid white, I press the button, the power indicator and the light on the button are solid for 1-2 seconds and immediately turn off.
        The system does not turn on, there is no post.
        I removed the RAMs and changed them, changed the battery, RTC battery, AC adapter, removed them and waited, tried again, it does not turn on.
        The problem continues in the same way.
        I tried to turn on the Fn key, nothing came to the screen....
        02-15-2025, 12:08 PM
      • MahmoudNasser
        Dell 7480 problem with freezing during the Windows loading process
        by MahmoudNasser
        Hello everyone, I wish you a happy day.
        I have a Dell Latitude 7480 laptop that has a problem with freezing during the Windows loading process. If it manages to boot up, it becomes very slow and doesn't load anything from the desktop.
        Device Data
        Model Dell Latitude 7480
        CPU:i7-7600U
        SN:7T58PL2
        MP PartNumper:CAZ20 LA-E131P Rev:1.0 A00
        Bios Chips:W25Q128BV
        The attempts that have been made to solve the problem have not yielded any results.
        1. Changing the M.2 and M.2 Nvme hard drives.
        2. Trying...
        07-09-2023, 05:04 AM
