Yesterday, while out of town, a Buddy and I took a look at a D600 On CL.
The guy wanted $35... I got it for $30. Here's what I got:
-The laptop was in "B-" Condition. The lid had a dent (no screen damage) and two base stickers were missing (Service tag was intact). Some scuffing at base corners. No missing screws.
-The keyboard is missing the right ALT key... the softkey is still there and works but the key and scissor mechanism are gone.
-The Bios was locked down with two passwords. The Owner knew the HDD password but the admin password was unknown (bought from a lot de-commissioned from Indiana University a few years back). However, thanks to some tools Gilly1984 posted back in my D800 thread, I was able to fix that issue for good.
- The battery had about 50% wear... meh.
-Specs: Pentium M 1.4ghz Banias, 512mb DDR2, ATI Radeon 9000 GPU, 1024x768 screen, 40gb 5400RPM Hitachi Travelstar, Phillips Combo drive, Intel 2100 B wifi
- There is an issue where sometimes the laptop won't turn on; instead, the power LED at the hinge lights up and the HDD led at the hinge and all LEDs in the power button area flicker for about 3 seconds before turning off. The seller claimed it was due to a "missing screw" but no screws were missing. I will give him credit, it is indeed a screwy issue!
- The power cord included was a noname knockoff "PA10". When I got home I cracked it open, wasn't super impressed, but it wasn't the worst I'd seen. Still a turd, mind you.
-The lid had two "911 was an inside job" Bumper stickers on it.. luckily those came off w/o issues.
Anyway... I took it home, and cracked it open to clean the cooling among other things. Surprisingly there was very little dust in the heatsinks! (IIRC the fan runs) However, the thermal pad for the chipset was cracked and the one for the GPU crispy, so I busted out some silver pad material to replace those. Also, I took of the metal foil think on the CPU and swapped for traditional thermal compound. Upon the swap I felt more heat blowing out the heatsink... so the pads and compound are doing their job.
While I was in there, I swapped the 1.4gHz cpu for a 1.6gHz one in my junk bin. Also, until I can get an intel replacement, I swapped the B wifi for atheros ABG wifi.
All seems to work... except the damn power on issue! I looked and looked but nothing inside the laptop seems to indicate why it's doing that. If anybody has a clue as to what is causing this, due tell...
And if ^ is an cheapish fix, then I'll get an OEM PA10/PA12 brick for it, a fresh keyboard, and a decent wifi card that doesn't show up as "unknown" in the BIOS.
And if not? Looks like I might have some D600 guts to sell!
