Dell Vostro 1310 won't POST, Num Lock LED flashing rapidly.
  • Agent24
    I see dead caps
    • Oct 2007
    • 5068
    • New Zealand
    This is my first attempt to fix a laptop... from a friend. Don't have a lot of hope for it but thought I'd give it a go.
    It's a Dell Vostro 1310 and it won't start at all. Tried stripping down to the basics, disconnect everything except 1 stick of RAM (tested OK in another machine) and it won't start.
    Fan spins up, then stops, then Caps Lock and Scroll Lock come on solid and NumLock starts flashing. Google suggests this means motherboard problem (surprise, surprise)
    Friend said it used to fail POST and beep sometimes, but would start others. Now it won't do anyhing. No beeps so far for me. Tried reset BIOS by removing battery, no change.
    Found schematics online (attached)
    Video: http://www.youtube.com/watch?v=m_PM1DJUQ_M
    Any ideas on where to look first?
    -David VanHorn
  • siddiq
    • Dec 2011
    • 121
    • Ghana
    Re: Dell Vostro 1310 won't POST, Num Lock LED flashing rapidly.
    Try reseating the processor.
    • Agent24
      I see dead caps
      • Oct 2007
      • 5068
      • New Zealand
      Sorry, already tried that, no good.
      -David VanHorn
      • Agent24
        I see dead caps
        • Oct 2007
        • 5068
        • New Zealand
        Looks like I found one problem for a start - the crystal for the clockgen is smashed. Guess I'll have to replace that and see what happens after...
        Any advice on replacement or known issues?
        -David VanHorn
        • lumduan
          • Mar 2013
          • ไทย
          I have same problem. (Num Lock LED flashing rapidly some time.)
          Could you suggest me, How to solve it ?
          http://www.youtube.com/watch?v=4v7lN7n0MC8
          • bruvolo
            • Jun 2013
            I have the exact same problem too. Has anyone had any success fixing the issue yet? Thanks!!
            • Th3_uN1Qu3
              Believe in
              • Jul 2010
              • 6031
              • Romania
              Reflow the Intel northbridge/IGP chipset. That oughta fix it. What happens with those particular Dells is that the motherboard warps and some of the solder balls under the chipset no longer make contact. This is not the common lead-free solder cracks problem, it's a physical defect of the board itself, it is made of low quality material.
              For this reason i would not recommend attempting a reball on this mainboard, you will likely ruin it. Just reflow and hope for the best.
              A working TV? How boring!
              • bruvolo
                • Jun 2013
                Hi Th3_uN1Qu3, thanks so much for the reply! I can take computers apart and then put them back together, but never did any soldering. Can you briefly explain what Reflow the Intel northbridge/IGP chipset means? I think maybe I can try it if you can tell me what i need to do. Thanks again!
                Brian
                • ravi_1617
                  YY Solutions
                  • Jan 2012
                  • 348
                  • India
                  Hi
                  my dell vostro 1310 in the 3 led's two side's num and scrollock I think blinking but (center one)caps lock is constant on external monitor display ok on board no display no light its led screen15''6. ,no power beside screen side conector from mainboard board .THANKYOU
                  • speedypro
                    • Feb 2013
                    • 561
                    • United Kingdom
                    Brian
                    Reflow:
                    In its simplest form means to hover heat, over the gpu, which re-joins solder balls underneath the chip if they are cracked. If the balls are joined together, then a reball is needed.
                    Reball:
                    To replace solder balls on a bga chip.
                    Full-time computer repair tech (10am - 6pm) and full-time, (8am - 11pm), Ruby on Rails Developer
                    • Alfa is auto
                      • May 2013
                      • 83
                      • Finland
                      Ya need to get proper equipment and (HI QUALITY)flux and i think thats again gpu/sb etc el chip...
                      • dj_ricoh
                        • 2073
                        just a reflow its ok. this is my 1310 i did http://www.youtube.com/watch?v=ihxjo...0ORz_hRD4VCYeQ
                        • Lobo
                          • May 2010
                          • 59
                          ...those particular Dells is that the motherboard warps and some of the solder balls under the chipset no longer make contact.
                          I see this on a lot of Dells. They are notorious for overheating because they throttle down the cooling fan. In fact, sometimes the fan isn't even on. It can be a pain to take control of the fan also. Speedfan has had to actually add a setting specifically for Dell laptops. Dell is one of those companies that thinks that even after you have given them money for a product, they still own it and should have control over it.
                          So if you do get this thing running again> install Speedfan, adjust the fan speeds properly, and set it to run at start up.
                            DELL Vostro 3471 Vostro 3400 i3-9100 Specification for Upgrade or Repair
                            This specification for the DELL Vostro 3471 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Vostro 3471 boardview and Vostro 3471 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Vostro...
                            09-12-2024, 03:44 PM
                            DELL Vostro 3470 Vostro 3400 i5-9400 Specification for Upgrade or Repair
                            This specification for the DELL Vostro 3470 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Vostro 3470 boardview and Vostro 3470 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Vostro...
                            DELL Vostro 3671 Vostro 3600 i5-9400 Specification for Upgrade or Repair
                            This specification for the DELL Vostro 3671 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Vostro 3671 boardview and Vostro 3671 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Vostro...
                            DELL Vostro 3470 Vostro 3400 i3-8100 Specification for Upgrade or Repair
                            DELL Vostro 3670 Vostro 3600 i3-8100 Specification for Upgrade or Repair
                            This specification for the DELL Vostro 3670 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Vostro 3670 boardview and Vostro 3670 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Vostro...
