MSI A6200 Laptop Power Jack Problems
  • MisterD
    • Oct 2012
    • 668
    My MSI A6200 was shutting down at times but only when I had the Power Supply plugged in and also the connector was hot to the touch, it wouldn't always recharge the battery, I was thinking I was going to have to disassemble it and resolder the DC Jack but I tried something else, I just kept unplugging and plugging in the AC Adapter connector at a fast rate over and over and spinning it around back and forth, this cleaned the jack connector and now it's working normally again. not getting hot at all and charging the battery again.
  • opamp
    • Dec 2012
    • 160
    • united states
    Re: MSI A6200 Laptop Power Jack Problems
    Well that was an easy fix but I suggest you replaced the dc jack the corrosion is going to come back.
    • MisterD
      • Oct 2012
      • 668
      It started doing it again, this time I took a small screwdriver and scraped the negative outside edge connector inside the jack, now it's working normally again. I really don't want to have to replace the jack unless totally necessary. I think I will coat that portion of the jack with a light coat of petroleum jelly.
      • Sanjit Keskar
        Laptop mouse & KB NOT available on power option restart but available only when laptop is cold booted using power button
        by Sanjit Keskar
        I have this inexplicable problem from yesterday
        Each time i start my laptop by pushing the physical power button in, the laptop keyboard and touchpad are available to me for use when the system has booted to the desktop (I can enter the bios by pressing on F10 too) irrespective of whether the laptop is powered by the AC adapter or the battery. This is normal behaviour
        BUT NOW FOR THE ABNORMAL PART
        However, when using the laptop normally, if i choose restart from the power options, the touchpad and mouse are non-functional when the system has booted to the...
        06-06-2024, 10:35 AM
      • Tynan Dill
        by Tynan Dill
        Assuming...
        11-22-2024, 01:46 PM
      • GLISIT
        by GLISIT
        01-16-2025, 02:29 PM
      • jrodefeld
        Asus laptop won't boot (no power) - possible bad caps?
        by jrodefeld
        I would like to see if anyone could help me salvage a very expensive laptop that is no longer working.
        The model:
        Asus Zenbook Pro Duo UX582L
        I have used this laptop lightly since I purchased it new in 2022. I have always taken precautions to take care of it the best I could, and have never done anything that would risk causing damage to it or shorten it's life.
        However, around six months ago, the laptop stopped working on battery power. It continued to work fine when plugged in, but as soon as power was disconnected,...
        09-02-2024, 04:55 PM
      • yaya3gmax
        Laptop Power Issue – Works on Battery, Fails on Adapter Load
        by yaya3gmax
        Dell laptop (E7440, uses the notorious CD3301B power controller + MEC5075 EC + BQ24715 charger IC)
        Symptoms:
        • Laptop works normally on a pre-charged battery.
        • Battery does not charge when adapter is connected.
        • Without battery:
          • Laptop powers on from DC adapter, passes CPU/RAM init checks, then cuts DC power abruptly.(seems to shutdown one of the mosfets in the charger path). Then the loop continues indefinitely
          • Speakers “pop” when power cut occurs indicating harsh sutdown.
          • If RAM is removed, the system shows RAM missing blink error code indefinitely without cutting DC power
        08-21-2025, 07:16 AM
