Laptop Dead except for the lights and fans.
  • I_am_learning
    • Dec 2012
    • 8
    • Nepal
    I had this compaq presario v3500 model laptop running fine. But yesterday, It suddenly won't start. When I press the power button, the fan runs, the power leds (on the motherboard and on the power button) lights continuously and nothing happens. It remains like that for eternity. .
    Doing 'HARD RESET' don't solve the problem, neither does playing with RAM. In fact, even when I remove RAM and Harddisk, the poor thing can't even complain (no blinks or beeps).
    No its not display problem, even when leaving it for hours, the CPU is dead cold.
    (if it were only the display then, cpu should have been quite hot (or atleast warm) becasue of doing *some* work)
    It had similar issue few months back, at which case, cleaning the mobo with petrol and giving a full day sunbath healed it. It won't do now.
    Help please?
    (I have all the tools and skills to replace ICs or measure voltages on the mobo if needed.)
  • gabik111
    ORD spotter
    • 142
    • USA / Poland
    Re: Laptop Dead except for the lights and fans.
    When you removing RAM usually system won't start .
    Try to reseat CPU but better if you got diferrent CPU to see if this is not dead CPU. Also do the same with RAM.
    First get the schematic then check 3.3V and 5V or Vcore to make sure you got all voltage.
    Laptops and computers repair.
    • ala_borbe
      aka Donald
      • 1625
      • Malta
      if it has nvidia graphics or chipset so some research and then do reflow like on dv6000/dv9000 series of HP
      Im Back... sort of...
      • sasser
        • Dec 2012
        • 364
        • Malaysia
        reball or reflow your nvidia graphics. set your hot air blower at 230c the reflow about 3minutes. try start your machine
        • I_am_learning
          • Dec 2012
          • 8
          • Nepal
          Thank you all.
          Yes, reflowing (or reballing?)the nvidia GPU seems like the only solution. I checked the Vcc_core voltage and it was 1.5Volts.
          What I am wondering is, in the schematics, I can see that the Power led can *only* glow when the GPU wants it. (i.e. it is connected to one of the GPU pin, or atleast controlled by it.) So, if GPU was disconnected from the pads, then the LED shouldn't have glown either.
          But, maybe only some of the GPU pins are disconnected, and those that are required to glow the Led are still connected.
          I will try reflowing and let you people hear, what happened.
          • sasser
            • Dec 2012
            • 364
            • Malaysia
            not at all led power is glow eiter the bga ok or not coz the led power when the motherboard startup power is enough and u got 18.5 with no drop. The led is not the indicator the balls under gpu its ok. Try reflow n tell we all what happen.
            • I_am_learning
              • Dec 2012
              • 8
              • Nepal
              Rflow and Kaboom!
              It won't even light the LEDs now. Completely Dead.
              Someone please help.
              • RJARRRPCGP
                • Jul 2004
                • 6304
                Did a cap pop on you?
                ASRock B550 PG Velocita
                Ryzen 9 "Vermeer" 5900X
                Arc A770 16 GB
                eVGA Supernova G3 750W
                Alienware AW3423DWF OLED
                • DerStrom8
                  Techie
                  • Dec 2012
                  • 76
                  Funny you should mention this. I just started a thread here today regarding a similar problem. I haven't yet got around to reflowing, but have been doing research on the technique for a while. When you do the reflow, it's VERY important that you protect sensitive components (electrolytic caps, for example) with aluminum foil at the very least, if not remove them entirely. It's also important that you set the board up an inch or two to ensure airflow so that you don't fry the underside of your board. Finally, make sure you remove all the important modules that can be removed safely (CPU especially). You also need to remove plastic parts, wires/cables, and labels from the board. All that can be left there are the components and board.
                  If nothing works now I'd have to say you're pretty much screwed. I'm sorry to say it. Your only chance would be if it was just the electrolytics that are damaged. They are easily replaced. But if it's something inside one of the chips, or a fried SMD resistor or capacitor somewhere, it'll take a LONG time to troubleshoot. You'd be lucky if you can even find it.
                  So the question now is, how did you reflow your board? What precautionary measures did you take to protect the sensitive parts?
                  I wish you all the best.
                  Regards,
                  Matt
                  • RJARRRPCGP
                    • Jul 2004
                    • 6304
                    Symptoms remind me of when I cracked my T-bird 1.3 core when putting the heatsink on.
                    Had to pop my T-bird 900 back in!
                    (October 13, 2002)
                    Arc A770 16 GB
                    • I_am_learning
                      • Dec 2012
                      • 8
                      • Nepal
                      Regards,
                      Matt
                      Well, I did remove all removable parts, including CPU. I did use aluminum foil to protect other parts. I practiced reflowing in a scrap desktop mother board before trying on this one.
                      There were like three small globs (of size comparable to solder ball)of black things on each corner of the chip. I believe they are some kind of adhesives to keep the chip on place. I tried to scratch them out before reflowing but they were hard, so I couldn't. I thought they will just melt away when I do reflowing so moved on. But even after about 5 minutes of heating, I wasn't able to nudge (slight movement) the chip. Since a successful reflow requires that you nudge the chip (and it will come back to its place itself), I continued to heat and after sometime a cracking sound came. I could see that from the rim of the top shiny rectangle of the chip some shiny solder like metal was squeezed out. I stopped immediately and let the things cool. I tried to scrub off the squeezed out shiny metal and it came out clean. I did partial assembly and found that my motherboard was now completely dead.
                      I hope the story was interesting to you.
                      PS: no electrolytic caps were nearby. And no component on the mother board looks damaged.
                      • DerStrom8
                        Techie
                        • Dec 2012
                        • 76
                        I'm not so sure about the part in bold above. Nudging the chip will do little but cross the solder beads underneath and create shorts. You'll probably need to put vertical pressure straight down on the chip, but horizontal movement must be avoided.
                        How exactly did you heat up your board? Did you put it in an oven, or did you use a heat gun?
                        You did not mention the cracking sound before. That could mean the hair-thin wires within the chip are now broken, and your only chance would be to replace the chip, or the entire mobo.
                        Matt
                        • gabik111
                          ORD spotter
                          • 142
                          • USA / Poland
                          Looks like you overheated GPU and the core of GPU separated from rest of it. Only you can do is replace chip.
                          Normally when I'm doing reflowing I'm using machine with special hot air exhaust tip and thermocouple that measuring temperature (thin hair that you can slide underneath chip). Depends on board thickness , solder ball used (leaded or not) and chip itself the temerature is diferrent up to 230C (with RoHS compliant solder balls) but temperature at the exhaust tip can reach even 400C. Reflowing is not easy process and if you do not want to damage your board you should use preheater installed on bottom of you board to avoid deformations and heat stress of the motherboard. Reflowing lead-free solder balls is much difficult and needs more heat .
                          • max-power
                            Dell E6540 laptop completely dead after dssasembly
                            by max-power
                            Hi, I disassemble my laptop to replace the speakers, to access them, you have to remove everything including the heat sink and fan, unscrew the motherboard, lift it up a bit to access the speaker wire.
                            that was not the first time I dissasemble it, i did replace the same speaker a few year ago and I repaste it last year, so I had nothing to worry about. but when I put everything back together, its completely dead.
                            After a bit of investigating, i found one pin of the status led ribbon cable that was unglued from the cable and bend touching another pin, I bend it back at his place...
                            03-24-2025, 08:49 AM
                            Microsoft Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum Notebook Specification for Upgrade or Repair
                            This specification for the Microsoft Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum boardview and Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from...
                            09-06-2024, 09:30 PM
                            Microsoft Surface Laptop Surface Laptop 2 Notebook 2 Specification for Upgrade or Repair
                            This specification for the Microsoft Surface Laptop Surface Laptop 2 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Laptop 2 boardview and Surface Laptop 2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                            09-06-2024, 08:47 AM
                          • RdeveLabs
                            MSI GF63 THIN 11UCX (MS-16R6) LAPTOP WON'T TURN ON AFTER RESTARTING
                            by RdeveLabs
                            To all the members here...
                            Let me tell you a little bit about what happened to my laptop (MSI GF63 THIN 11UCX model: MS-16R6) that “maybe” you know how to solve this problem.
                            So before this problem happened, my laptop was running smoothly. When I wanted to restart my laptop, it looked fine at first. But after I waited for this restart process to take a long time, until finally I panicked (because the restart process did not finish plus the laptop screen only showed a black screen), I immediately pressed and held the power button to force the laptop to turn off. But...
                            05-05-2025, 04:59 AM
                          • Loli Popu
                            DELL 5590 LAPTOP DEAD AFTER BIOS WRONG FLASHED
                            by Loli Popu
                            Hello guys ,i have a dell latitude 5590 with f411p bios,this laptop has bios password ,i tried to read the bios(winbond 25q128jv) with ch341 but when goes to verify give error ,it said doesnt match .After this i flashed another bios which is cleaned and then the laptop was dead ,i tried to turn on but only white light in the buton power turned on several times and then no display at all .I had a backup and flashed again the original bios ,but this time the laptop will not turn on at all ,no light nothing,the bios original bios that i flashed was having verify error when i verified with ch341 ,i...
                            12-13-2024, 03:28 AM
