a vary strange problem with dell vostro 1400 some time keyboard works fine but after shutdown it does not work again .i have been change keyboard;its mouse panal;panal strip but cant succeed so what component should i check for this problem ................
dell vostro 1400 key bord not working
Re: dell vostro 1400 key bord not working
are you using a genuine dell charger or a aftermarket charger? some dells hate aftermarket chargers the touch pad and keyboard will act wonky... -
sometimes very rare but does happen when a genuine dell charger starts to fail it can cause those symptoms...is the battery good? does it do the same thing when its running off from battery? and no charger attached?Comment
try to uninstall the keyboard drivers or roll back drivers for the keyboard and reboot to see if that fixes the issue it may be software related.. one good way to rule out software issue is to either boot into mini xp with hirens boot cd or use usb stick bootable ubuntu linux see if keyboard works correctly or not....Comment
Description : Dell
Model : Vostro
Serial Number :
Product Number :
CN :
MFD:
Hard disk : NVMe 256GB
CPU: AMD Ryzen YM3250C4T20FG
RAM : DDR4 8GB
MB : GDM54 LA-L245P Rev : 1.0(A00) 2021-07-26
I don't have any other data because there is no data label on the laptop.
I have a problem with my laptop that when I connect the charger, the charging indicator lights up and goes out after 4 seconds. Windows reports charging but does not charge the battery. Can anyone help me... -
by MMH3Hello,
i have many 5050sff. all of them, and how i experienced over many years for all about 250 DELLs goin through my hands, are fully flashable and can be serviced in any way when the service_mode jumper is set.
Never ever i experienced problems with that.
Now i have one 5050sff machine, where this jumper isnt working at all.
I do not get the normal messge that the jumper is set when booting and a short test with FPT just confirms this. Everything is locked -->> EVEN for reading !?
The history of the machine is that i used it in my office... -
by playitthe comon problem they say , the charger will shut off power once plugged to laptop , i dont have battery, its long gone ago , i use it for backup with adapter and vga port to external monitor(yes no screen lcd) in case my desktop needs fix . one thing for sure i could say the clr resistor - r010 beeps ,short at both sides , the checked all the coils , the 3 coils together gives all of them beeps short along with their respective capacitors . i dont have voltage ampere injection dc machine as in videos i have seen they see where its getting hot and they remove the short and replace components...
- Loading...
