dell vostro 1400 key bord not working
  • alihomee
    • Dec 2012
    • 1574
    • malaysia
    a vary strange problem with dell vostro 1400 some time keyboard works fine but after shutdown it does not work again .i have been change keyboard;its mouse panal;panal strip but cant succeed so what component should i check for this problem ................
  • heavymachines
    • Mar 2011
    • 1028
    Re: dell vostro 1400 key bord not working
    are you using a genuine dell charger or a aftermarket charger? some dells hate aftermarket chargers the touch pad and keyboard will act wonky...
    • alihomee
      • Dec 2012
      • 1574
      • malaysia
      no i have a origanal charger
      • heavymachines
        • Mar 2011
        • 1028
        sometimes very rare but does happen when a genuine dell charger starts to fail it can cause those symptoms...is the battery good? does it do the same thing when its running off from battery? and no charger attached?
        • alihomee
          • Dec 2012
          • 1574
          • malaysia
          yes
          • heavymachines
            • Mar 2011
            • 1028
            Originally posted by alihomee
            yes
            indeed a strange issue......will do some research see if i can't find any clues for ya and what makes this one a hard one its intermittent and that throws a monkey wrench in the mix....
            • heavymachines
              • Mar 2011
              • 1028
              try to uninstall the keyboard drivers or roll back drivers for the keyboard and reboot to see if that fixes the issue it may be software related.. one good way to rule out software issue is to either boot into mini xp with hirens boot cd or use usb stick bootable ubuntu linux see if keyboard works correctly or not....
