Help with Dell 1501 Laptop
  • Howie
    • Dec 2004
    • 31
    Hey guys, I need some help with a Dell 1501 laptop motherboard.
    I'm trying to identify a part that was damaged near the charging port so I can buy a replacement.
    Below is a pic of the same model board with an arrow pointing to the part.
    I know this isnt much to go on but a simular looking part was on the reverse side of the board and had: TXCefod 25.000 written on top. It appears to be some sort of crystal quartz peice but no clue on the exact part, type or specs. Hoping maybe someone here has addressed this or has a schematic to look this part up.
  • Howie
    • Dec 2004
    • 31
    Re: Help with Dell 1501 Laptop
    No one has any ideal what this thing could be?
    • heavymachines
      • Mar 2011
      • 1028
      can you get a close up pic of that chip can't see it very good part number comes up with nothing
      • nikalai
        • Nov 2012
        • Romania
        Hi, you need a qurtz rezonator for 25 MHz ! It is the resonator for your network card.
        • electro1
          • 38
          • usa
          The part on the bottom of the circuit board to the right of the battery terminals right most very close you will see a 3r3 coil under that are 2 black mosfets side by side then the 3rd big brown smd ceramic capacitor not the other 2 small ceramic caps directly above its the bigger brown smd cap just above pr11 is what I need specs for, It blew open need to know the values its not on my dell 1501 schematic, forum wont let me post a picture please look at top of this thread for picture
          • mon2
            • Dec 2019
            • 14659
            You should be able to post attachments. Do you see the 'upload attachments' button on the lower left side of your window?
            What other markings do you see on the silk screen? Something like 'LA-****' or similar?
            • electro1
              • 38
              • usa
              • electro1
                • 38
                • usa
                La ill check now no LA - on silk screen no marking on part taking a up close picture should be uploaded by 930am or sooner no good having issues with picture to my computer figure 10am
                • mon2
                  • Dec 2019
                  • 14659
                  Do you mean the yellow / brown SMD parts as attached? These are polarized tantalum caps. Do you have either one still onboard?
                  • electro1
                    • 38
                    • usa
                    • electro1
                      • 38
                      • usa
                      • electro1
                        • 38
                        • usa
                        The part looks like its beige or white rt side as pictured you see it blew out on the right side note your picture on the left side that 3r3 then 2 black objects 8 pins each then 3rd rectangle looks like its brown on your picture it's right above silk screen pr11
                        • electro1
                          • 38
                          • usa
                          I see on your picture at the bottom 3 of them small to big capacitor its brown on your picture
                          • electro1
                            • 38
                            • usa
                            • electro1
                              • 38
                              • usa
                              The part is circled in red
                              • mon2
                                • Dec 2019
                                • 14659
                                This is a non-polarized ceramic capacitor but not sure of its value or voltage rating. For the voltage rating, you will have to measure the voltage to ground of each of the PCB pads used by this component. One side will most likely be ground, the other side will be the operating rail. The capacitor must be rated at a higher voltage than this measured voltage.
                                • electro1
                                  • 38
                                  • usa
                                  The computer is turning off and on without pressing the power button with battery in and with it removed does this like 5x plus then went off. I unplugged cord and plug back in starts going on off on offf on offf fan spins for a few sec voltage at part is 19.53v dc when it's on I see it drop to 19.22v off and plugged in reads 19.53v its turned off and on 12x plus, Then i pulled the power plug note lcd screen is disconnected ,and i removed the hard drive the ram is installed when it first started doing this id hear the hard drive spin up then turn off to prevent damage i removed the hard drive..
                                  • mikey5791
                                    Dell laptop model PP24L won't start from ac adapter
                                    by mikey5791
                                    Dear all,
                                    Bought this used Dell laptop PP24L(studio 1435) in Jan 2022. It was running smooth on 64 bit Windows 7 pro from processor Intel core Duo T6400@2Ghz with 2GB RAM. The laptop battery was charging and working fine until few months back the opening screen will display something like "replacing the battery warning", press F1 to continue. Normally i press F1, the laptop will proceed to Windows and i can use as normal.
                                    But last week, after i pressed F1, the laptop just shut down. I suspected the laptop battery is dead. So i pulled out the battery and...
                                    03-24-2023, 09:06 PM
                                  • Mots06
                                    Old Dell E5400 Laptop ( Purchased in the year 2008)
                                    by Mots06
                                    Hi, I'm unable to find the motherboard number (PPID number) or the board view for this old laptop. My laptop won't start, and when I enter the serial number on the Dell website, it says the number is invalid. The sticker on the bottom is unreadable because it has faded over time. Unfortunately, I'm unable to start the laptop to use the power cell or explore other options.I needed the CMOS Cell & it also seems the Laptop will not start now because of the power switch issue, which is yet to be detected.
                                    07-19-2025, 01:56 AM
                                  • Bowline
                                    by Bowline
                                    06-11-2025, 10:13 AM
                                  • Calidebear
                                    Dell 3537 laptop doesn't boot without embedded display.
                                    by Calidebear
                                    I have this laptop for a long time, still it does it's job, like browsing, word , excel. Two years back laptop Hinge base broken but now it's damaging other parts of laptop so I tried to totally remove the embedded display cable from laptop and tried to boot only with external display monitor, but it doesn't boot and gives single beeps. BIOS checking the embedded display to be connected.
                                    So checked the schematics to bypass this issue.
                                    Found something but I don't know how to read this schematics.
                                    Dell 3537 mobo 9982p rev 3
                                    Schematics attached,...
                                    03-29-2025, 11:37 AM
                                    Microsoft Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum Notebook Specification for Upgrade or Repair
                                    This specification for the Microsoft Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum boardview and Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from...
                                    09-06-2024, 09:30 PM
