Dell Inspiron N5110 help!!
  • bushido
    • Oct 2012
    • 32
    • japan
    hi i'm new here i need your help my sister give me broken dell inspiron n5110 there a power problem if i push power button with ac adaptor nothing happen no display no cpu fan if i do it again without ac adaptor still the same and then again if power up without the battery and ac adaptor only still the same i check the ac adaptor with multimeter it is ok i think its the motherboard component but i dont no what can check and where can i check plz help me thanks a lot sorry for my english
  • bushido
    • Oct 2012
    • 32
    • japan
    Re: Dell Inspiron N5110 help!!
    Plz guys i'm badly need your help plz give me some info how to check the motherboard and where can find the right component like fuse or something related in the power...thanks i hope you can help me
    • kammy6000
      • Oct 2012
      • 22
      hi, what else have you checked?
      have you reset bios?
      have checked charger port?
      if these are ok then you have bad component and need schematics to locate fuses or capacitors
      • trebo
        • 514
        • Wales, UK
        Check the power socket for failure
        Youtube video link, how to get to it
        http://www.youtube.com/watch?v=C_cT-b8eYZk
        The next one says they are prone to failure
        http://www.youtube.com/watch?v=HuzAMlCT1QU
        • bushido
          • Oct 2012
          • 32
          • japan
          thanks trebo for your advice. yes i reset the bios i check the ac adapter by multimeter i'll check the ac port seams nothings wrong i think is kind of the component or fuse failure but i'm not sure sorry for my english...plz help me thanks again and here the link of the schematic of the board http://www.laptopschematic.com/page/14/ plz help me thanks a lot
          • trebo
            • 514
            • Wales, UK
            Hello Bushido
            Your English is fine
            I am not going to be of much help to you, but other members will be
            I suggest that you post some pictures of your laptop boards for others to see, and they will make some suggestions
            • bushido
              • Oct 2012
              • 32
              • japan
              plz check this full schematic of inspiron n5110 i hope any one here can help me to find what need to be check for power problem thanks...
              • bushido
                • Oct 2012
                • 32
                • japan
                thanks kammy6000 but i did what u said but still not working i think its fuse or caps but im not sure
                • maybenever
                  • 158
                  It's not going to do anything without ac adapter or battery. You need to find a working laptop (with same battery) with charged up battery and switch batteries. If if does not boot up, then you have other problems.
                  • Nightwalker
                    • Oct 2012
                    • 76
                    • Greece
                    Hi bushido
                    Unplug ac adapter and remove battery. Press and hold power button for 15-30 seconds. Release it, plug ac adapter and press power button once. Maybe work this for you..
                    • bushido
                      • Oct 2012
                      • 32
                      • japan
                      hi maybenever thanks for the advice i try what you said but still not working
                      • bushido
                        • Oct 2012
                        • 32
                        • japan
                        Originally posted by Nightwalker
                        Hi bushido
                        hi nightwalker thanks i did what you said many time but still not working
                        • heavymachines
                          • Mar 2011
                          • 1028
                          hey you need to reflow the the motherboard , its caused by it being overheated very common issue with this model and hundred others and not limited to nvidia chipset, intel and ati have these issues as well. What you need to do is strip the motherboard, remove bios battery, cords etc any anything that may melt the high temp plastic is ok to leave there its the pvc you have to worry about..once processor is removed and motherboard is bare, turn your oven on to 375F wait till oven reaches temp and put that motherboard on a cookie pan with the bga chips upright and put it in the oven for 8 minutes and pull it out let cool then reassemble with new thermal grease and cleaned heatsink and i bet you it will fire right up and run....
                          • bushido
                            • Oct 2012
                            • 32
                            • japan
                            hi heavymachines thanks after i reflow the mobo i attach the cpu fan rtc battery memory without the battery and i press the power botton and its power up but its hang and i cant not shutdown true power botton so i need to unplug the ac adapter and then i try to power up again but its not working again what should i do after this happen? thanks a lot
                            • bushido
                              • Oct 2012
                              • 32
                              • japan
                              hi heavymachine thanks its work you save my laptop from dead but there is one problem the charging was not work
                              • heavymachines
                                • Mar 2011
                                • 1028
                                check the dc jack on mobo, make sure none of the pins are loose, if you have a digital multimeter put it on diode test and check continuity from the pins on dc jack to motherboard, and on the power cord there is a pin in the center that controls the battery charging if this pin in broke or not putting out 3 to 5 volts then the power cord either needs a new end or just replace the power cord and the metal inner circle is supposed to put out from 18 to 19 volts dc and use the outer of the plug as your ground...sounds like this laptop had a rough life messed up jack and overheated very common problem with people and laptop. now that you got it working again you will need to watch your temps and make sure its cool before you shut it off otherwise it will happen again....
                                and set the multimeter to dc volts 20 when test the ac adapter voltages if the center pin not have any volts then it will not charge battery another common problem with dells put black probe on outside of the plug and red probe to the center pin that looks like a needle should have 3 to 5 volts if none then the charger is bad....
                                • heavymachines
                                  • Mar 2011
                                  • 1028
                                  here is an illustration for you
                                  • bushido
                                    • Oct 2012
                                    • 32
                                    • japan
                                    hi heavymachines i really thank you for helping me i really appreciate i will check it after my work thank you very much
                                    • heavymachines
                                      • Mar 2011
                                      • 1028
                                      any updates?
                                      • bushido
                                        • Oct 2012
                                        • 32
                                        • japan
                                        any updates?
                                        hi heavymachines sorry for late replay i check the ac adapter port in the middel pin i cannot get any voltage output i try to check other ac adapter but the same still no volts output what do you think i need to check the dc jack port to? thanks for your help !!!!
                                          DELL Inspiron 3671 Inspiron 3000 i3-9100 Specification for Upgrade or Repair
                                          This specification for the DELL Inspiron 3671 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Inspiron 3671 boardview and Inspiron 3671 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL...
                                          09-12-2024, 03:36 PM
                                          DELL Inspiron 5680 Inspiron 5000 i5-8400 Specification for Upgrade or Repair
                                          This specification for the DELL Inspiron 5680 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Inspiron 5680 boardview and Inspiron 5680 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL...
                                          09-12-2024, 03:30 PM
                                          09-12-2024, 03:28 PM
                                          DELL Inspiron 5680 Inspiron 5000 i3-8100 Specification for Upgrade or Repair
                                          DELL Inspiron 3668 Inspiron 3000 i5-7400 Specification for Upgrade or Repair
                                          This specification for the DELL Inspiron 3668 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Inspiron 3668 boardview and Inspiron 3668 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL...
