Dell latitude no power on
  • quartz
    • Nov 2010
    • 14
    forum has already identified a cap in a display power board, thanks, hoping some luck with this.
    Have a dell latitude d400 (second hand), been using ok for 12 months. a week ago, it was switched on all ok,4 hours later, came back to it and it had died. state of play is....
    as soon as i try to turn the laptop on, the LED on the power block, goes off. have to remove the ac adaptor from the mains, to get the power block LED to go on again. the moment i try to switch the laptop on, the power block led goes off again
    when attempting switching the laptop on, the laptop power button light barely flicks on, and straight off again.
    ive tried switching on with no battery and no hard disk installed, also reseated both so-dimm modules. i'm guessing either the display, or the laptop motherboard itself ?
  • LDSisHere
    • May 2012
    • 727
    • U.S.A.
    Re: Dell latitude no power on
    From what you describe it sounds like you have something shorted on the motherboard or your power supply is bad. Try another known good adapter and if it has the same symptoms then you know the problem is with the laptop. If the computer works then you just have to buy an adapter.
      03-31-2024, 02:12 PM
      07-01-2024, 06:34 AM
    • hoarderteks_kyriakos
      Dell Latitude E5570 - No display, turns off after a minute of pressing the power button.
      by hoarderteks_kyriakos
      Hello.
      Yesterday my mother encountered a problem with her laptop, which led to it not turning on and expressing the behaviour mentioned in the title (you press the power button and then it turns off after a minute)
      Here is what happened:
      At one point i was fixing a setting on the laptop to make the laptop properly recognize the NVMe drive i put in months ago. All worked until all of a sudden the computer blue screened. The screen said it would reboot, but it never did. So she held down the power button, powering it off. Pressing it again, the screen briefly turned...
      10-08-2025, 07:33 AM
    • dlonely94
      Dell Latitude 5591 not power on
      by dlonely94
      Hi everyone!
      I have a Dell Latitude 5591. It has a strange problem:
      First, when the WLAN card is plug in, it will not power on when press power button, even all voltage is up (19v, 3v, 5v, 3valw, 5valw)
      When I remove the WLAN card, it will start nomarlly. Then I power off and re-insert the WLAN card, it still work normally.
      But, if I left it for 3 or 4 days without the battery and adapter plugged in, it will not power on, and I have to repeat the above sequence.
      Sometime, when it not power on, I just unplugged the battery and adapter, wait...
      10-13-2024, 10:29 AM
    • ARS
      Dell Latitude 5501 LA-H182P wont power on
      by ARS
      Board was water damaged with short on 13,5V power line.
      After celaning and removing short on board i have 5v, 3,3v, 1v, 1,8v but no reaction to power button. Its same if i use USB-C or normal power supply.
      No shorts detected (only CPU power is 1.2 Ohm, but thats OK i think) no other water damage found.
      Tried to flash BIOS, no change.
      After pressing power button i get orange light in front (no light on power button LED) as long button is pressed.
      Advice needed.
      TIA Matus.
      11-13-2025, 08:26 AM
