Dell Latitude 5501 LA-H182P wont power on
  • ARS
    • Mar 2013
    • 28
    • Slovakia
    Board was water damaged with short on 13,5V power line.
    After celaning and removing short on board i have 5v, 3,3v, 1v, 1,8v but no reaction to power button. Its same if i use USB-C or normal power supply.
    No shorts detected (only CPU power is 1.2 Ohm, but thats OK i think) no other water damage found.
    Tried to flash BIOS, no change.
    After pressing power button i get orange light in front (no light on power button LED) as long button is pressed.
    Advice needed.
    TIA Matus.
  • mon2
    • Dec 2019
    • 14731
    What is the voltage and current draw showing on the usb-c meter?
    • ARS
      • Mar 2013
      • 28
      • Slovakia
      Current draw is nly 0,03A, without change after pressing power button.
      • hoarderteks_kyriakos
        Dell Latitude E5570 - No display, turns off after a minute of pressing the power button.
        by hoarderteks_kyriakos
        Hello.
        Yesterday my mother encountered a problem with her laptop, which led to it not turning on and expressing the behaviour mentioned in the title (you press the power button and then it turns off after a minute)
        Here is what happened:
        At one point i was fixing a setting on the laptop to make the laptop properly recognize the NVMe drive i put in months ago. All worked until all of a sudden the computer blue screened. The screen said it would reboot, but it never did. So she held down the power button, powering it off. Pressing it again, the screen briefly turned...
        10-08-2025, 07:33 AM
      • dlonely94
        Dell Latitude 5591 not power on
        by dlonely94
        Hi everyone!
        I have a Dell Latitude 5591. It has a strange problem:
        First, when the WLAN card is plug in, it will not power on when press power button, even all voltage is up (19v, 3v, 5v, 3valw, 5valw)
        When I remove the WLAN card, it will start nomarlly. Then I power off and re-insert the WLAN card, it still work normally.
        But, if I left it for 3 or 4 days without the battery and adapter plugged in, it will not power on, and I have to repeat the above sequence.
        Sometime, when it not power on, I just unplugged the battery and adapter, wait...
        10-13-2024, 10:29 AM
      • imedbox
        Dell Latitude 5440 no power on
        by imedbox
        ihave the same probleme the labtop want charge with the power supply! my bat is decharged then i can test it with battry it power on!
        i got this after flash bios "XM25QH256C" for removing admin password,i revert to the original then not charge or power on, befor it power on and chargin!
        Any Help !
        her link for Boardview and the Schematic
        Dell Latitude 5440
        bios version : 1.12.20
        MTHERBOARD : IDB40 LA-M401P Rev:1.0(A00) 2023-11-10
        https://www.transfernow.net/dl/20250721QpvcJ0UG
        07-21-2025, 03:03 AM
      • NADJIB
        Dell Latitude 7390 _DAZ20 LA-F312P 1.0 - all power rails up except VCC_CORE and VCC_GT
        by NADJIB
        I need help please​
        I have Dell Latitude 7390, LA-F312P 1.0
        - power LED turns on a few one second or two withe power supply or battery
        - the power supply indicate current 0.16 A While laptop is powered
        I checked:
        While laptop is powered from battery/barrel plug AND power LED is on, all voltage rails show up, except +VCC_CORE and +VCC_GT.
        * COIL
        PL612
        - Output resistance to ground is 14.7 ohm.
        PL613 AND PL610
        - Output resistance to ground is 9.8 ohm.
        01-23-2024, 04:31 PM
