Dell latitude no power on
  • quartz
    • Nov 2010
    • 14
    forum has already identified a cap in a display power board, thanks, hoping some luck with this.
    Have a dell latitude d400 (second hand), been using ok for 12 months. a week ago, it was switched on all ok,4 hours later, came back to it and it had died. state of play is....
    as soon as i try to turn the laptop on, the LED on the power block, goes off. have to remove the ac adaptor from the mains, to get the power block LED to go on again. the moment i try to switch the laptop on, the power block led goes off again
    when attempting switching the laptop on, the laptop power button light barely flicks on, and straight off again.
    ive tried switching on with no battery and no hard disk installed, also reseated both so-dimm modules. i'm guessing either the display, or the laptop motherboard itself ?
  • LDSisHere
    • May 2012
    • 727
    • U.S.A.
    Re: Dell latitude no power on
    From what you describe it sounds like you have something shorted on the motherboard or your power supply is bad. Try another known good adapter and if it has the same symptoms then you know the problem is with the laptop. If the computer works then you just have to buy an adapter.
      by sam_sam_sam
      03-31-2024, 02:12 PM
      by sam_sam_sam
      07-01-2024, 06:34 AM
    • hoarderteks_kyriakos
      Dell Latitude E5570 - No display, turns off after a minute of pressing the power button.
      by hoarderteks_kyriakos
      Hello.
      Yesterday my mother encountered a problem with her laptop, which led to it not turning on and expressing the behaviour mentioned in the title (you press the power button and then it turns off after a minute)
      Here is what happened:
      At one point i was fixing a setting on the laptop to make the laptop properly recognize the NVMe drive i put in months ago. All worked until all of a sudden the computer blue screened. The screen said it would reboot, but it never did. So she held down the power button, powering it off. Pressing it again, the screen briefly turned...
      10-08-2025, 07:33 AM
    • dlonely94
      Dell Latitude 5591 not power on
      by dlonely94
      Hi everyone!
      I have a Dell Latitude 5591. It has a strange problem:
      First, when the WLAN card is plug in, it will not power on when press power button, even all voltage is up (19v, 3v, 5v, 3valw, 5valw)
      When I remove the WLAN card, it will start nomarlly. Then I power off and re-insert the WLAN card, it still work normally.
      But, if I left it for 3 or 4 days without the battery and adapter plugged in, it will not power on, and I have to repeat the above sequence.
      Sometime, when it not power on, I just unplugged the battery and adapter, wait...
      10-13-2024, 10:29 AM
    • imedbox
      Dell Latitude 5440 no power on
      by imedbox
      ihave the same probleme the labtop want charge with the power supply! my bat is decharged then i can test it with battry it power on!
      i got this after flash bios "XM25QH256C" for removing admin password,i revert to the original then not charge or power on, befor it power on and chargin!
      Any Help !
      her link for Boardview and the Schematic
      Dell Latitude 5440
      bios version : 1.12.20
      MTHERBOARD : IDB40 LA-M401P Rev:1.0(A00) 2023-11-10
      https://www.transfernow.net/dl/20250721QpvcJ0UG
      07-21-2025, 03:03 AM
