I have an asus k53 series laptop. I cracked the lcd so I ordered a replacement from laptopscreens.com HOWEVER it was not a direct replacement. I found a slightly different asus laptop with the same screen specs (size, led, 40 pin, connector location) except for a 1080p resolution :P. After installing the screen and turning on the computer it looked like the connector wasn't on right (weird tint, etc). So I took the laptop apart again but this time I decided to test the screen before reassembly so to not have to tear it down again if it wasn't right. When I turned the computer on it still wasn't right (different tint this time) so I jiggled the connector GENTLY and after about 10 seconds of this the backlight died. Here is what I have done so far to diagnose the issue:
So my issue is basically the same as this thread http://forum.notebookreview.com/dell-inspiron-dell-studio/478489-inspiron-1545-led-screen-no-backlight-5.html
I just can't seem to find the right component, maybe there isn't a fuse and I fried something else??
Here is the connector area
![](https://cdn.badcaps-static.com/image_cache/625dbe6fbabe0ac5d5060689710157f7.jpg)
same area
![](https://cdn.badcaps-static.com/image_cache/31879ab22ed14b3741c1e0f6683e3521.jpg)
Closer. The component circled in red passed continuity and and no resistance so I'm assuming this is a fuse but is not blown.
![](https://cdn.badcaps-static.com/image_cache/6951271111153ca5415bd1dffa01e43d.jpg)
opposite side in the same area, looks like its mainly the transformer area for the cpu.
![](https://cdn.badcaps-static.com/image_cache/33f1f4afcfd23964f93f13cdc9adf4d3.jpg)
Full board shots:
![](https://cdn.badcaps-static.com/image_cache/410de206325efc108f82244e8d03010f.jpg)
![](https://cdn.badcaps-static.com/image_cache/b5c0dfaa2a3b7b96ae510d7bec790db4.jpg)
![](https://cdn.badcaps-static.com/image_cache/100d7f15f8ff4fdc7b4260fd60c33d0a.jpg)
Here is what didn't pass continuity, I forget what the ohms were.
![](https://cdn.badcaps-static.com/image_cache/a2890072215cd08f4dc0d3c4cf24b335.jpg)
Everything is so damn small and not labeled!!
Links to original images:
http://i.imgur.com/EL8ru.jpg
http://i.imgur.com/RZG2r.jpg
http://i.imgur.com/O1sAo.jpg
http://i.imgur.com/ghBPZ.jpg
http://i.imgur.com/pkwk7.jpg
http://i.imgur.com/wtRYh.jpg
http://i.imgur.com/igkPg.jpg
http://i.imgur.com/2OcPe.jpg
- Tried old screen, backlight not working (it was working before I took it out) leading me to think it was a problem with the cable or the motherboard
- Made sure it wasn't an issue with the lid switch. It works correctly.
- Confirmed both old and new screens working, I can see my desktop when using a flashlight. Just no back light. Also made sure windows was reading the new screen at its native rez.. all good.
- Tried to find a blown fuse on the motherboard around where the lcd ribbon connects. No luck, only found one fuse in the area and it passed continuity.
- found 4 other fuses in different areas of the board and all working.
- found what I think is a fuse that wont pass continuity located near the DC jack.
same area
Full board shots:
