Adapter LED flashing, laptop not switching on
  • aaronmarsh632
    • Nov 2010
    • 20
    I did reply to a previous thread but I thought I'd create a new 1 for my own problem and provide an image with it.
    Basically if I plug the laptop charger in the LED on the charger flashes rapidly and the machine wont boot up. I have stripped the laptop and tried changing the jack but problem is still there. After reading the previous post it sounds like it could be something called the 'startup cap' I have taken a picture of the motherboard where the DC jack is connected and circled the part which I think is the 'startup cap'. Can anyone confirm if this is the correct part and if not can anyone help me with this problem please? Also how can I test the cap to see if it is faulty before replacing it?
    Aaron
  • retiredcaps
    • Apr 2010
    • 9271
    Re: Adapter LED flashing, laptop not switching on
    The startup cap that they are refering to is inside the AC adapter and usually an electrolytic capacitor. It is not on your laptop motherboard.
    --- begin sig file ---
    --- end sig file ---
    • lord
      • May 2011
      • 319
      • Croatia
      Did you try another charger?
      • aaronmarsh632
        • Nov 2010
        • 20
        Hi, yeh I tried another charger before stripping down the laptop. I have seen this lots of times and trying a new charger has never solved the problem for me atleast. I also changed the jack which hasnt fixed the issue, have you any suggestions as to what may be causing the problem?
        thanks for your replies.
        • lord
          • May 2011
          • 319
          • Croatia
          Measure the resistance between the + and the - on DC jack on the motherboard.
          • xaviero1412
            • Apr 2009
            • 56
            maybe, shorted bipolar caps
            • aaronmarsh632
              • Nov 2010
              • 20
              Hi, thanks for the replies. I have tested the jack with a multimeter and its giving an output of average 2.5v (should be 19v in my case). Which would be the bipolar caps? I'm guessing the large cylinder cap between the battery connector and cpu?
              thanks
              • aaronmarsh632
                • Nov 2010
                • 20
                EDIT: I think I may have found the problem, I left the charger plugged in for a few minutes and if I get close I can smell - not burning as such but smells like heated flux, then I noticed some bubbling from 1 of the (if im not mistaken) voltage regulators. Not the 1 I have marked blue, the 1 above it. On the top of the component is where I can see it bubbling where its soldered (not the pin side). I will have a look to see if I can get a replacement from ebay orsomewhere and once I replace it I will post results.
                • aaronmarsh632
                  • Nov 2010
                  • 20
                  Sorry for the tripple post but im having trouble finding a replacement. The information I can get off the component is...
                  1H34SB
                  FDD
                  6685
                  Both those parts on the board are the same. I dont currently have ano other motherboards which I can transplant the parts from, and I cant find any information regards these on the net so I dont know what an equivalant alternative would be, can anyone offer any ideas please?
                  thanks again
                  • trebo
                    • 514
                    • Wales, UK
                    1H34SB
                    FDD
                    6685
                    thanks again
                    Data sheet here
                    http://www.alldatasheet.com/datashee...D/FDD6685.html
                    there are plenty of replacments on Ebay found here
                    http://www.ebay.co.uk/sch/i.html?_tr...+6685&_sacat=0
                    • aaronmarsh632
                      • Nov 2010
                      • 20
                      Hi, thanks for that, I have been searching for the top number - i assumed the others were revision numbers etc so didnt use them. Thanks for that.
                      • aaronmarsh632
                        • Nov 2010
                        • 20
                        Hi, I finally got the new parts this morning and soldered them on, unfortunatly I still get the same problem - does anyone know what could be causing this please?
                        thanks
                        • ben7
                          Capaholic
                          • Jan 2011
                          • 4059
                          Something must be shorting out the Vreg, burning it up. Desolder it and see if there is a short on the output (on the board, not the regulator).
                          Muh-soggy-knee
                            That device is a MOSFET, you should remove it and then take the resistance reading between the chassis and one pad at a time, report the resistance reading on all 3 pads.
                            • ben7
                              Capaholic
                              • Jan 2011
                              • 4059
                              Originally posted by budm
                              ...you should remove it and then take the resistance reading between the chassis and one pad at a time, report the resistance reading on all 3 pads.
                              Yes, that is what I meant to say.
                              Muh-soggy-knee
                              • aaronmarsh632
                                • Nov 2010
                                • 20
                                Hi, thanks for the replies. I have set my multimeter to 200 ohm which is the lowest on the settings and it gives a default reading of 1 without doing anything, so I put 1 prong on the chassis and the other on 1 of the pads but the reading doesnt change - am I doing something wrong? This happens on all 6 solder pads (3 pads per component). Also I notice with both components removed the charger LED no longer flickeres.
                                • ben7
                                  Capaholic
                                  • Jan 2011
                                  • 4059
                                  I have a feeling that the control chip for the MOSFETS could be fried, causing them to both turn on and the same time, and overheat.
                                  Muh-soggy-knee
                                  • aaronmarsh632
                                    • Nov 2010
                                    • 20
                                    Hi Ben thanks for your time, would the controller chip for the MOSFETS be the 48-pin surface mount chip next to the DC Jack named ISL9504? I have googled the chip and some1 is calling it the Power IC, would this be the chip you're refering to? If not could you possibly identify it from my picture please? I can replace these chips if need be as I have done 128-pin ic's in the past not much bigger than this 1.
                                    • ben7
                                      Capaholic
                                      • Jan 2011
                                      • 4059
                                      It appears to be some sort of buck voltage regulator controller made by Intersil.
                                      Can't find the datasheet for the ISL9504 though.
                                      Your pic is not big/close enough to be able to read the numbers on the chip.
                                      Muh-soggy-knee
                                      • aaronmarsh632
                                        • Nov 2010
                                        • 20
                                        Hi thanks for checking, I have taken a closer image of the chip, i cant find anything that means anything to me through a google search, maby you'll know more about it than me. Heres the pic anyway.
                                        • flat-earther
                                          ASUS X54H laptop thinks it's always charging even with charger unplugged
                                          by flat-earther
                                          The charging indicator light on my ASUS X54H laptop is always on even when the charger is disconnected.
                                          Windows also shows ''Plugged in'' when charger is not connected.
                                          This problem started year ago gradually, when unplugging the charger the charging light took several seconds to disappear, then minutes, and now almost always on even when unplugged for an entire day.
                                          Strangely, before sometimes immediately when plugging in the charger the charging light went away, and later came back with it connected.
                                          If I let battery run out and say it has 3% Windows will...
                                          06-24-2025, 09:32 AM
                                        • serious_electron
                                          Strange! Acer laptop not powering on but charging the battery (orange light on when charger and battery plugged in).
                                          by serious_electron
                                          Hello Everyone!
                                          I have an Acer Aspire A315-42 laptop. I generally leave it on for long time by closing down its lid (so it enters the sleep mode). Recently, it rained quite heavily in out area. And the humidity and moisture seem to be high. So one late evening, after I opened the lid and turned on the laptop, it did power on as the blue light turned on but after it booted to the desktop screen, just 5-10 seconds after both the screen and blue light went out and laptop shut down (the blue power light turned orange). And after 2-4 seconds that orange light went off and the laptop died.
                                          06-28-2025, 02:57 PM
                                          by sam_sam_sam
                                          03-31-2024, 02:12 PM
                                          ISL6257HRZ ISL6257HRZ-T Laptop Battery Charger Datasheet
                                          Highly Integrated Narrow VDC Battery Charger for Notebook Computers
                                          The ISL6257HRZ ISL6257HRZ-T is a highly integrated battery charger controller
                                          for Li-Ion/Li-Ion polymer batteries. ISL6257 is designed for
                                          Narrow VDC applications where the system power source is
                                          either the battery pack or the regulated output of the charger.
                                          This makes the max voltage to the system equal to the max
                                          battery voltage instead of the max adapter voltage. Operating
                                          at lower system voltage can improve...
                                          11-05-2024, 04:43 PM
                                          Microsoft Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum Notebook Specification for Upgrade or Repair
                                          This specification for the Microsoft Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum boardview and Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from...
                                          09-06-2024, 09:30 PM
