Gateway MA3 Laptop, Overheating?
  • cantholdmd
    • Jun 2012
    Hello guys -
    I am helping a friend whose laptop was not booting. When I pushed the power the blue circle around the power button appeared along with the hard drive symbol and another symbol then turned off within a few seconds. Her battery no longer would charge so its not in the laptop so I began to think that the power adapter was bad and shorting out.
    I opened the laptop, disconnected the hard drive, removed the RAM and unplugged the display but still the same. I then removed the fan and CPU and tried the power and it worked. I reseated the CPU and tried and again and it worked. Connected and reseated everything else and its not working again. As I have it next to me booting up, it seems to be hotter than normal, is this what caused the problem? What tools can I run to figure out what caused the problem so she doesnt have an issue with it again?
    Thanks very much
  • Spitz
    • Oct 2010
    • 95
    Re: Gateway MA3 Laptop, Overheating?
    Originally posted by cantholdmd
    Hello guys -
    I am helping a friend whose laptop was not booting. When I pushed the power the blue circle around the power button appeared along with the hard drive symbol and another symbol then turned off within a few seconds. Her battery no longer would charge so its not in the laptop so I began to think that the power adapter was bad and shorting out.?
    Thanks very much
    This particular model has a problem with the artwork around the power jack. The plated thru hole on the positive pin disintegrates and looses connection on the top, or bottom or both. You have to add a small wire on both sides of the board. Here is a link describing the problem with an ma7 which has the same problem.
    https://www.badcaps.net/forum/showth...&highlight=ma7
    • cantholdmd
      • Jun 2012
      Thanks Spitz. Since I was able to reseat the processor and it now turns on fine, do you believe this advice still applies? After messing it with it for a couple hours, I notice the fan stays on non stop and I get shut downs if the laptop has poor airflow from overheating. No malware or viruses were detected, hardware is checking out fine, updated all Windows components and updated drivers along with flashing BIOS. If I hold the laptop up in the air and use it, the laptop stays on for hours. If I turn it on and sit it on the couch, the laptop shuts down from overheating at around 90C core temp.
      • Spitz
        • Oct 2010
        • 95
        It needs to be on a flat surface so the air flow around the fan is clear. All notebooks overheat if you cover the bottom since they draw air in from the bottom and exhaust it on the sides. You also need to check that the exahaust on the side is not full of lint and carpet fiber. As far as the jack problem, it is just a matter of time and it will start acting up.
          Microsoft Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum Notebook Specification for Upgrade or Repair
          This specification for the Microsoft Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum boardview and Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from...
          09-06-2024, 09:30 PM
          Microsoft Surface Laptop Surface Laptop 2 Notebook 2 Specification for Upgrade or Repair
          This specification for the Microsoft Surface Laptop Surface Laptop 2 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Laptop 2 boardview and Surface Laptop 2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
          09-06-2024, 08:47 AM
        • RdeveLabs
          MSI GF63 THIN 11UCX (MS-16R6) LAPTOP WON'T TURN ON AFTER RESTARTING
          by RdeveLabs
          To all the members here...
          Let me tell you a little bit about what happened to my laptop (MSI GF63 THIN 11UCX model: MS-16R6) that “maybe” you know how to solve this problem.
          So before this problem happened, my laptop was running smoothly. When I wanted to restart my laptop, it looked fine at first. But after I waited for this restart process to take a long time, until finally I panicked (because the restart process did not finish plus the laptop screen only showed a black screen), I immediately pressed and held the power button to force the laptop to turn off. But...
          05-05-2025, 04:59 AM
        • Dan John
          Gateway P5WS0/NV57H58u laptop (P5WEO LA-6901P REV:2.0) - (Possible) Multiple Issues
          by Dan John
          Greetings everyone,
          I have a Gateway P5WS0/NV57H58u laptop (P5WEO LA-6901P REV:2.0). The client said the battery was not charging. Upon checking the laptop,
          1) On pressing the power button, the (power button) light turns on and stays on.
          2) There is no boot, or anything on the screen.
          3) The fan starts and stops a few times, then it stops completely.
          4) The light on the power button remains on.
          5) Battery not charging (original issue).
          The original problem was that the battery was not charging, but the laptop still worked. My belief
          04-23-2025, 08:12 AM
          Microsoft Surface Laptop Surface Laptop Go 2 Notebook Go 2 Specification for Upgrade or Repair
          This specification for the Microsoft Surface Laptop Surface Laptop Go 2 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Laptop Go 2 boardview and Surface Laptop Go 2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
          09-07-2024, 06:11 AM
