Compaq Presario CQ62 410c US power supply Question
    • Jul 2011
    • 6039
    I have a Compaq Presario CQ62 410 US power supply
    The out ring is (-) and a inter ring is (+) that wll power the computer
    What dose the center pin do it is (+)
    How ever if you power that pin to the (+) side then the computer shut down and will not charge and the computer will not power ON
    When you remove the battery from the computer and reinstall it every thing come back to life
    Question I do have is
    Do I need to use the center pin and if I do.....> How do I do it ?
    I want run this computer off of some 18 volt tool batteries that I have I have done this before but not a computer that has three wires
    Thank to any one that can help
    • Jul 2011
    • 6039
    Re: Compaq Presario CQ62 410c US power supply Question
    Dose any one have idea what the center pin is for and if it is need
    • 999999999
      • Sep 2006
      • 774
      It might be like the center pin found on some Dell laptop PSU, a data signal that identifies to the laptop that a valid PSU, capable of enough current to run it at full speed and charge the battery, is plugged in instead of some who-knows-what power source.
      If that is the case you might check the bios menu to see if there is a way to disable it but there may not be, the laptop may be forced into a low speed mode and unable to charge its own battery.
      • mattbrad2
        • Jan 2011
        • 122
        It does transmit some sort of signal. For example, an HP laptop will not respond with a Dell charger even though they fit perfectly. Ironically, a common problem with some newer HP's is the TI power management IC will start to fail. When this happens, you can either replace it or jumper the center pin of the DC jack to 19v and the laptop will charge again. So yes, it is HP specific but it's anyone's guess as to what exactly it's purpose is.
          • Jul 2011
          • 6039
          Thanks for the Info
          All that relpy
          • b700029
            Banned
            • Sep 2010
            • 640
            That was a very risky thing to do, a look at the schematic shows that the pin basically goes directly to an input on the EC, with very little protection besides a diode up to the 3.3v rail. You're lucky it didn't kill the EC, because it probably tripped the OVP. The EC is a KB3926 for which I don't have the datasheet, but the similar KB926 and KB3930's datasheets show that 3.6V is the maximum that pin should ever experience.
            As to its function, since that's an input-only pin and can be configured as ADC, I think the adapter ID is implemented by nothing more than a voltage divider in the adapter. Different wattage adapters will output different voltages on that pin for the EC to sense via the ADC. This is cheaper than the Dell system with the ID chip (1-wire EEPROM).
            It depends on the model but this is a very risky move as I said above. Maybe it has no ill effects because the input is protected with a zener and resistor, but in general I would not recommend doing that without consulting the schematic or at least tracing the signal on the board. If it weren't for that diode, this guy's laptop would be dead now.
            Last edited by b700029; 06-23-2012, 05:42 AM. Reason: add the appropriate schematic excerpts
            • mattbrad2
              • Jan 2011
              • 122
              b700029 - I see what your saying but all (at least in my experience) newer "dell-type" HP adapters have the center pin at ~14v. Just to make sure, I went and tested the 3 different models I have laying around here and they are all 14v, not 3v. Shorting it to 19v certainly isn't ideal but it is in fact a work-around.
              • b700029
                Banned
                • Sep 2010
                • 640
                It depends on the exact model of laptop they were designed for, some were probably designed to have that voltage on the middle pin and so would have appropriate circuitry in the laptop. The voltage divider also may be a high impedance source, draw any significant amount of current and the voltage drops. That would also explain the 24.3K to ground I saw in the schematic above. But the 19v main power is a low impedance source, so it will not have the same characteristics.
                Not saying your idea is invalid, but it's prudent to be cautious especially when fixing customer's laptop.
                  • Jul 2011
                  • 6039
                  b700029
                  Is there a work-around for this and is this pin need if you are running off of battery power
                  Thank for any and all info that you can give me in this matter
                  The frist laptop I had it was easy to hook up a power tool battery pack I would like to do the same thing on this laptop if I can that is why I am asking is there a work-around for this
                  • 999999999
                    • Sep 2006
                    • 774
                    ^ take apart existing power adapter and reverse engineer what it would take to power that data subcircuit (then do so).
                    • b700029
                      Banned
                      • Sep 2010
                      • 640
                      Try it without the center pin connected to anything first.
                        • Jul 2011
                        • 6039
                        Originally posted by 999999999
                        ^ take apart existing power adapter and reverse engineer what it would take to power that data sub-circuit (then do so).
                        I did that on a replacement power supply and all I saw was two resisters in series which came up 220 meg ohm (+) to center pin and the same from the
                        center pin to the (-)
                        So I do not know if two 220 meg ohm resistor wired in series between (+) and the (-) terminal and hook the center pin in the middle of the two 220 meg ohm resistor
                        Would this work or not ?
                        Thanks for every one help in this matter
                        • 999999999
                          • Sep 2006
                          • 774
                          It seems as though there ought to be something more connected to the center pin than only these resistors which seem to only be forming a voltage divider.
                          • b700029
                            Banned
                            • Sep 2010
                            • 640
                            220M is extremely high for a (relatively) low-voltage consumer application like this, and resistors in those values are also quite rare. What markings do they have?
                            When plugged into the laptop you'll have basically a 220M - 24.4K divider (through R108 and R109 above) which gives ~2mV at the ADC input (neglecting the input impedance, which will probably be significant with a 220M source impedance --- so in reality it would be much lower). This looks too low.
                            220K seems like a more likely value - gives ~1.7V at the ADC input.
                              • Jul 2011
                              • 6039
                              I measure this with a DMV meter and got this value
                              But this make scent what you have above f you think this would work
                              • b700029
                                Banned
                                • Sep 2010
                                • 640
                                What multimeter are you using and did you set it to the 1M range and saw 220 on the display? That's likely 220K, not 220M. A multimeter that can measure a 220M resistor is quite high-end; most of them can't go higher than 200M.
                                • craciunaero
                                  • May 2013
                                  • romania
                                  Hi all ! I am having some problems with the same laptop. I have connected the center pin directly to the 19 volts supply and now the laptop is dead. Later I foud out that the center pin is actually connected to the +19v rail throght a 390k resistor. I hope this helps.
                                  B700029 can you tell me any advice on the motherboard. Should I replace the KB chip? or where should I look for signs of trouble?
                                  • spidey
                                    climbs
                                    • Dec 2012
                                    • 644
                                    • Cyprus
                                    i use 220k resistor between +19 and center pin. i didnt have any problem with it. U can safely use that way.
                                      by sam_sam_sam
                                      03-31-2024, 02:12 PM
                                      by sam_sam_sam
                                      07-01-2024, 06:34 AM
                                    • JimBanville
                                      Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
                                      by JimBanville
                                      The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
                                      Opened it up and discovered the power supply is making a faint clicking or ticking sound.
                                      I measured the amp's output to the woofer and it pulses up to 50mv DC to be driver. The pulses coincide with the power supply ticking/clicking.
                                      I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
                                      09-13-2023, 07:21 AM
                                      HP Compaq Elite 8300 USFF PC | i5 Would it be possible to take the switching power supply and modify it for battery operation
                                      by sam_sam_sam
                                      I have pondered this idea for a while now and I would like for anyone who has any ideas for if this would work I have one that I might scariest it just to see if it could be done
                                      I am thinking it might be possible to get a battery pack configuration that should work but I not exactly sure if it feasible or not
                                      I was just looking at some HP elite 8300 computer that are used and the price has gone up since the last time I was looking at them on eBay really this sucks to find this out about a year ago you could find them with shipping for around $50.00 of course they have...
                                      07-07-2024, 03:01 PM
