hi, everybody can someone help me how to fix an hdd with password.thanks
HDD password
Tags: None
Re: HDD password
What hdd is it? I had couple days ago one seagate hdd that was locked and I didn't managed to unlock it. there are couple of free programs that should do something depends on how it is locked. also there is one program that it isn't free but 100% sucessful, hdd unlocker I think. -
Re: HDD password
no thanks, for the price postage.it is not worth.......
if you explain me may be i can do itComment
Re: HDD password
What are you trying to do with this hard-drive?
What kind of password?
Is it Encrypted or is the drive locked?
If it's locked,
You try Ultimate Boot CD.
http://www.ultimatebootcd.com/download.html
Go TO HDD > DIAGNOSTICS > HDAT2 Ver. 3.5 > ENTER
Once loaded at the prompt, type hdat2 then select the drive and go to security, from there you should be able to unlock the drive.
If it's the filesystem that's encrypted, then there's not anything I can do or recommend since it depends on the encryption type.Comment
Re: HDD password
You need a special tool like this: http://www.salvationdata.com/data-re.../hd-doctor.htmComment
Re: HDD password
If it's locked,
it was blocked from the bios.i will try your solution....thank touComment
by NopslideHello everyone, I come here to tell you my problem regarding the power-on password. It is not a bios reset demand, and i can't have any access to windows. This is the bios and power-on password that is blocking all other things.
My Omen 15-dh0052nf purchased second-hand was configured with the bios password upon purchase (very simple password :P ).
Having decided to sell it in order to get something more powerful, I reset all BIOS settings and set a blank administrator password. But the power-on password cannot be changed to a blank one so I let the actual password set....-
Channel: BIOS Requests ONLY!
by moshuHi everyone, I have a HP EliteBook 755 G4 with a Biuos password.
I've read the 16MB chip and patched using βRCUnlocker_v_1_0 but seems it didnt worked, password is still there.
Can you please help to remove the password?
after first boot, there was an message thet firmware is restored, dont know if was suppose to happen.
HP EliteBook 755 G4
ProdID: W5Q98AV
SN: 5CG7524BY4...-
by Modify_incI have a Inspiron 11 3185, and in the BIOS setup under Security it shows "Locked Setup", which limits pretty much everything in the BIOS. I'm using bios-pw.org to generate the codes for the hash, but they never work for the Locked Setup password. The codes generated for the System password and the HDD password work fine, but the code for the Locked Setup password always fails. I don't understand, if it works for the first two, why is it not working for the Locked Setup p/w? Since I can't disable it, anytime I reboot, even after a Windows update, I have to go through the hassle of generating...
by Mike_HoDear All,
I have one 2nd hand Thinkbook 13s G2 ITL with broken display, after replace the LCD module it show password locked,
Can someone please kindly help me to get back the password code or modify this BIOS Dump to clean the password.
S/N: R912D81K
BIOS: W25R256JV
Thank's a Lot.
Best Rgds,
Mike....-
by outsiderHello
I removed the BIOS password thanks to the help of one of the friends of this forum.
https://www.badcaps.net/forum/troubl...61#post3637661
The batch from which the password was removed works correctly but... after some time, the BIOS password is set again, I reprogrammed the batch with the removed password, it's ok, there is no password, I set my password, ok, I can enter the BIOS with my password but...-
- Loading...
