Gateway MA3 wont charge or run off of dc power
  • johnsr11
    • Mar 2012
    I have a gateway ma3 laptop that will not run or charge off the dc power. I have just replaced the dc jack and noticed that it was sparking a little on the mb. I noticed that these are common for these kinda of issues, and I noticed on one of the threads that they were putting in a jumper wire to get this all to work. Well the picture of the mb was different and mine, and I was wondering if someone could tell me where I need to jumper the wire if I put up a picture. Thanks
    http://*************/photo/my-images/825/img0630z.jpg/
    http://*************/photo/my-images/703/img0629rw.jpg/
  • johnsr11
    • Mar 2012
    Re: Gateway MA3 wont charge or run off of dc power
    nobody out there can help me?
    • Spitz
      • Oct 2010
      • 95
      The problem with the ma3 & ma7 boards is that the tracks around the plated thru hole that the center pin of the jack goes into, disintegrate completely and no longer make contact to the pin. You have to look carefully at the track around the center pin hole on both the top and the bottom. Find the component that is attached by solder to that track and run a wire between that component and the actual center pin post. Just because there is a component next to the jack, it does not mean that it connects to the jack. You have to look closely at the track to find the closest solderable component and carefully solder the wire to it and the post. Do it on both sides of the board.
      • johnsr11
        • Mar 2012
        I will give that a shot, thanks.
        • ipatch
          troubleshooting microsoft surface pro 4 no power no led charge light
          by ipatch
          hello, �� i have been sitting on some microsoft surface pro 4 tablets for a while now. i was originally tasked with replacing the battery in one of the tablets, and ended breaking the screen and logic board in the process. decided to buy another tablet with the same specs. got that screen off successfully of the second tablet. the logic board appeared good, but i guess i shorted something out in the installation process of the logic which i've read is a common issue if there is no barrier between the logic board and battery pins. all that said, i ate costs of the repair and have...
          10-05-2023, 11:59 AM
        • ruletero
          Acer a515-43 low battery charge voltage
          by ruletero
          Hi
          Acer A515-43
          LA-H801P
          Fail: Does not charge battery, has low voltaje on connector.
          Laptop didn't want to turn on, only charge led blinked.
          I found PQB5 (mosfet high battery charger) in short, voltaje in +12.6V_BATT was 19 v ...
          I changed it, changed PQB6 too and now battery charger voltage is 4.4V but battery is 3 cell, 11.25v, then is very low to charging.
          Laptop turns on without battery and works fine, but with battery turns on and turns off inmediately, I suspect battery bad but I don't know...
          10-24-2022, 02:31 PM
        • Klevjetack
          Charge a L19D3PDA battery externally from the laptop
          by Klevjetack
          Is there a way to externally charge a L19D3PDA battery from the laptop. I have a broken charging port on my laptop and am trying to find a way to charge the battery for it. I have been doing some research and I have found that there is a module, TP4056, that can be used to charge Li-ion batteries. It says it is used to charge single cell Li-ion batteries. The L19D3PDA battery is a three cell battery. Is it possible to use the module to charge my battery and it would just be very slow? Or would that be a bad idea. Is there a different kind of module I can use to charge my Li-ion three cell battery?...
          03-05-2024, 07:26 AM
        • Elektronror
          Asus GL702VS No charge, unstable GPU power
          by Elektronror
          First post here, second if you count the introduction thread, so don't hesitate to tell me if I'm doing something wrong.
          Bought a used Asus GL702VS which had been sitting for a while so it arrived with a dead battery. Plugging in the charger it came back to life and I didn't notice any problems with the computer. I also used it running on battery for 1-2 hours. I then played around with undervolting the CPU with the charger connected when a 10uF MLCC shorted AC_BAT_SYS. After removing the short, battery won't charge and the GPU has power limitations. I suspect that these are 2 different...
          02-05-2021, 10:39 AM
        • MMH3
          Dell Optiplex 5050 SFF - strange behavior and service_mode jumper not working anymore
          by MMH3
          i have many 5050sff. all of them, and how i experienced over many years for all about 250 DELLs goin through my hands, are fully flashable and can be serviced in any way when the service_mode jumper is set.
          Never ever i experienced problems with that.
          Now i have one 5050sff machine, where this jumper isnt working at all.
          I do not get the normal messge that the jumper is set when booting and a short test with FPT just confirms this. Everything is locked -->> EVEN for reading !?
          The history of the machine is that i used it in my office...
          03-23-2025, 09:28 PM
