TSP 51125 fail to give 5.0voltage
  • Zengo
    • Apr 2012
    • 4
    • Tanzania
    Mother board :
    6050A2170401-MB-A03
    Error :
    Dead no power LED ,no HHD spinning or any POST
    Troubleshooted
    Charger IC (BQ24721C)is ok giving out 10.9v with battery and 14.6Vwith
    Adaptor charger
    Obsevation:
    I obseved 10.9 along TSP5117 but Missing 5V to power TSP 5117,ADP 3208 and other 5v
    Please give me hand on this , I need to power on this Machine
    Thanks in advance
  • selldoor
    Slow Learner
    • 7870
    Re: TSP 51125 fail to give 5.0voltage
    What laptop is it out of - please put that in the thread title
    • Zengo
      • Apr 2012
      • 4
      • Tanzania
      Toshiba Satellite L300
      • selldoor
        Slow Learner
        • 7870
        here is a link to the schematic
        http://lqv77.com/download/652/
        • Zengo
          • Apr 2012
          • 4
          • Tanzania
          thanks Selldoor
          I got the LINK
          What i have on TPS 51125 is only 3.3 voltage which is good
          but on pin 20 and pin21 0Voltage instead of 5 voltage
          where is the problem?
          • Zengo
            • Apr 2012
            • 4
            • Tanzania
            thanks for all , now i will be going out till tomorrow
            • ledro
              • Aug 2012
              • 49
              • romania
              i have the same situation with Toshiba A300. no 5v on TSP51125, only 3.3v
              i replaced TSP51125 and still not working
              thanks.
              • spleenharvester
                • Mar 2010
                • 921
                If you'd like me to take any readings from a working L300 GL960 board, feel free to ask. Just as long as they're not risky (i.e individual pins on QFN chips that aren't connected to nearby components)
                Dell E7450 | i5-5300U | 16GB DDR3 | 256GB SSD
                • spidey
                  climbs
                  • Dec 2012
                  • 644
                  • Cyprus
                  i'm having the same situation here, i have 3.3v but no 5v. TPS51125, satelite c665. Still working on it, if i solve i'll let you know. But if you allready solved the problem please answer the post..
                  • spidey
                    climbs
                    • Dec 2012
                    • 644
                    • Cyprus
                    I checked datasheet of tps51125. To enable outputs, pin 1 and 6 should be connected to ground by 130k resistors. In my case, EC is driving these pins through a swithcing circuit. I disconnected a transistor, it is working now. But that means i have a faulty EC.
                    • h3roe
                      • Sep 2012
                      • indonesia
                      What is EC ? how to handle ec
                      • Agent24
                        I see dead caps
                        • Oct 2007
                        • 5080
                        • New Zealand
                        EC is the embedded controller
                        -David VanHorn
                        • rookieme
                          • Oct 2014
                          • 399
                          • Greece
                          Same issue with toshiba A300, I don't get the 5V at L22.
                          Replaced U27 with no luck.
                          System powers on and off soon after. Already replaced nec tokin capacitor.
                          If I disconnect Q34 I get the 5V but it powers off again.
                          Also I replaced U29 kbc but same issue.
                          Schematic provided.
                          Any help appreciated.
                          • Agent24
                            I see dead caps
                            • Oct 2007
                            • 5080
                            • New Zealand
                            Checked for short on that rail?
                            -David VanHorn
                            • rookieme
                              • Oct 2014
                              • 399
                              • Greece
                              I get higher than 15kohm at that rail - seems normal
                              • saqib
                                wahlaptop
                                • Mar 2014
                                • 11
                                • pakistan
                                some times ic fault and some time 5v line having shortg in any resistncs
                                • Sus256
                                  HISENSE 65E7KQ PRO - no boot
                                  by Sus256
                                  Hi all!
                                  HISENSE 65E7KQ PRO
                                  RSAG7.820.13512 - chassis
                                  MT9618BAATAB - cpu
                                  RSAG7.820.12059 - power
                                  HD650Y3U77 - panel
                                  KLM8G1GETF - emmc
                                  The TV does not turn on, the standby indicator is on. All voltages are present.
                                  Emms is dead. Not readable, not detected.
                                  Replaced emmc.
                                  But with another dump there is no launch
                                  Terminal log
                                  UART
                                  AC_ON
                                  RPMB key is not yet programmed
                                  HASH1_VERSION=0x00000000 64bit
                                  E-B
                                  FDE enabled
                                  layout pattern onebin by SAR7,0...
                                  06-01-2025, 02:11 AM
                                  Acer Aspire E5-475-3208 Notebook E Specification for Upgrade or Repair
                                  This specification for the Acer Aspire E5-475-3208 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the E5-475-3208 boardview and E5-475-3208 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for...
                                  09-06-2024, 05:54 AM
                                • dragometin
                                  Hitachi 40HYC42
                                  by dragometin
                                  TV Model: Hitachi 40HYC42
                                  Power Supply: 17IPS71
                                  MainBoard: 17MB95M
                                  Panel: VES400UNDS-2D-NO3
                                  When the set came in it was dead. Fuse was open primary side and the power mosfet was shorted. So I ordered a new power supply. Now it turns on, only displays "Hitachi" and then power off red and blue led flashing.
                                  I had to modify the 0ohm resistors in the led backlight of the new PS like the original power supply.
                                  Is there any variants on 17IPS71 power supply's?
                                  UART output pins 10 and 12 on scart connector:
                                  Code:
                                  12:24:04.595
                                  08-08-2024, 05:53 AM
                                • Perry Babin
                                  Capacitors of the same make/series that consistently fail in one amplifier while they rarely fail in a different make amp
                                  by Perry Babin
                                  This is for car audio amplifiers but I doubt that matters. There are amplifiers that use the same make/series capacitor as a different manufacturer and they consistently fail in one brand. In the other they are OK. The amplifiers are from the same era. Is it possible that the heating profile used when flow-soldering the boards could be the reason for the failure? If not, any ideas on what the difference could be?
                                  04-03-2024, 10:40 AM
                                • Phuong_Vu
                                  Please help me, Please give me the gigabyte Z87p d3 boardview diagram
                                  by Phuong_Vu
                                  I need boardview gigabyte Z87p d3 to repair
                                  whoever has please give me thank you very much
                                  09-13-2025, 12:41 AM
