Acer aspire 5334 stuck on start
+ More Options
Posts
  • primoz1
    • Oct 2010
    • 270
    • Italy-Slovenia
    Hi again. I got aspire 5334 with starting problem, it just stuck on start, if I push F2 to go on bios settings nothing happend.
    see the video http://tinypic.com/r/dpejhd/5
    Maybe is I/0 chip ?
    Any idea what can cause this error ?
    Thankyou.
  • joshnz
    • Feb 2011
    • 969
    • New Zealand
    Re: Acer aspire 5334 stuck on start
    Have you tried removing the hard drive?
    My pc
    CPU : AMD PHENOM II x4 @ 3.5Ghz
    MB : ASUS M4A89TD PRO USB3
    RAM : Kingston ValueRAM 16gb DDR3
    PSU : Cooler Master 850W Silent Pro
    GPU : ATI Radeon HD 6850
    • primoz1
      • Oct 2010
      • 270
      • Italy-Slovenia
      Hi.
      Yes I remove HDD, replace RAM with 100% working, no diference at all.
      • selldoor
        Slow Learner
        • Dec 2010
        • 7870
        What are you trying to do - eventually?
        If you dont press anything does it continue and boot from the hard drive?
        • ismy4real
          • Dec 2011
          • 87
          i have the same problem too , when you press the f2 to go to setup is not responding too . any solution pls
          • primoz1
            • Oct 2010
            • 270
            • Italy-Slovenia
            I got the same issue, if I pres F2 nothing happen and I wait one hour or more.
            Is complete no possible to get in BIOS or if do not touch anything to star up windows.
            It just stuck there.
            • selldoor
              Slow Learner
              • Dec 2010
              • 7870
              Hi - If it has already been set up it may be that when the start up screen comes on you press F12 to change the boot sequence and may be
              something at the bottom of that menu to get into the bios?
              That is why I asked what are you trying to do -but you did not answer.
              Please update your profile with the country where you live.
              • primoz1
                • Oct 2010
                • 270
                • Italy-Slovenia
                Hi. I try F12, F10, Delete etc. nothing hapen, react only on F2 and then stuck like on video http://tinypic.com/r/dpejhd/5
                • jancker
                  • Jun 2011
                  Try to disconect laptop keyboard, and put usb keyboard. Maybe some key is stuck. It happend to me more then once.
                  • primoz1
                    • Oct 2010
                    • 270
                    • Italy-Slovenia
                    Good idea, thankyou, I will try and report what happend.
                    • selldoor
                      Slow Learner
                      • Dec 2010
                      • 7870
                      I thought of suggesting that but it does seem to recognise the F2 keypress
                      as it changes to "please wait."
                      If you take all the ram out does it start differently perhaps with an error message?
                      Have you tried a bootable cd or bootable memory stick instead of the hard drive.
                      Did the hard drive work ok -(boot to Windows) in another machine
                      • primoz1
                        • Oct 2010
                        • 270
                        • Italy-Slovenia
                        Hi. I try with diferent 100% working memory RAM, no changes
                        take apart complete laptop desolder CMOS battery, HDD, keyboard and use USB keyboard, no changes.
                        I try hard reset pusk ON button 30 sec. without any battery or power suorce then connect on charger , no chenges
                        I spot only strange heating of intel I/O chip app. 60-70°C meantime processor and Nvidia graphic chip got app. 40°C
                        I think is that I/O chip got bad connections with mboard and need reball, similar thing I see on many HP nx8220 with "insert smart card into reader" issue
                        • primoz1
                          • Oct 2010
                          • 270
                          • Italy-Slovenia
                          Hi. I reball Intel AF82801IBM chip, but no changes, Im not shure is chip OK or BAD.
                          Is possible to defected bios ?
                          And now before I order new chip again ask for help, is anyone experienced with this laptop or problem ?
                          Thankyou.
                          • xaviero1412
                            • Apr 2009
                            • 56
                            try reflash the BIOS first...
                            • primoz1
                              • Oct 2010
                              • 270
                              • Italy-Slovenia
                              Hi. I try but I do not have bootable USB key, all tools like make usb bootable not work.
                              I use FAT formated USB key, and put on FLASHIT.EXE, PAWF5104.BAT, PAWF5104.fd (bios files for DOS, from acer site) but nothing happend. Maybe is USB cause this, because is not bootable ?
                              Thankyou.
                              • primoz1
                                • Oct 2010
                                • 270
                                • Italy-Slovenia
                                Update. I make botable USB and try first on other laptop if work, and boot just fine. Then I try on this aspire 5334 and nothing, I hold ESC and FN then turn ON with hold ESC-FN about 7 sec, no changes. Has anyone idea where on board is BIOS chip ? Maybe if I desloder and solder back will help ?
                                Thankyou.
                                • b700029
                                  Banned
                                  • Sep 2010
                                  • 640
                                  It's a small 8-pin chip that should be near the keyboard controller (ENE KB926).
                                  The '5334 should be a Compal LA-4854P/PAWF6 (which shares the same motherboard as the eMachines E525 and a few others), there is a schematic for that here:
                                  http://lqv77.com/download/615/
                                  where the BIOS is U21.
                                  • shovenose
                                    Send Doge Memes
                                    • Aug 2010
                                    • 6575
                                    Did you mention nvidia graphics?
                                    This is very problematic!
                                    • primoz1
                                      • Oct 2010
                                      • 270
                                      • Italy-Slovenia
                                      Hi. Like I promise I share News from this case. I order new (with new bios) bios chip from ebay, and when I change chip on this board, the board work just fine.
                                      in the end, my suspicion was confirmed. tomorow morning (now is 22:07 west europe time) I will send a video to prof my story.
                                      Thankyou for all help again.
                                      • primoz1
                                        • Oct 2010
                                        • 270
                                        • Italy-Slovenia
                                        Hi like I say, I upload video with fixed this problem
                                        http://tinypic.com/r/icuw3r/5
                                        Thank's for all
                                          ACER Aspire Aspire E560 Aspire E6400 Specification for Upgrade or Repair
                                          This specification for the ACER Aspire Aspire E560 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire E560 boardview and Aspire Aspire E560 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                          09-12-2024, 03:28 PM
                                          ACER Aspire Aspire E700 Aspire E6300 Specification for Upgrade or Repair
                                          This specification for the ACER Aspire Aspire E700 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire E700 boardview and Aspire Aspire E700 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                          09-12-2024, 02:30 PM
                                          ACER Aspire Aspire M7711 Aspire Q9300 Specification for Upgrade or Repair
                                          This specification for the ACER Aspire Aspire M7711 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire M7711 boardview and Aspire Aspire M7711 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
                                          09-06-2024, 05:27 AM
                                          ACER Aspire Aspire G7200 Predator Defender Aspire 9750 Specification for Upgrade or Repair
                                          This specification for the ACER Aspire Aspire G7200 Predator Defender can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire G7200 Predator Defender boardview and Aspire Aspire G7200 Predator Defender schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer...
