dv6000 problem
    dv6000 problem
    i have dv6000 that when push button to switch on for sec and switch off again someone can give help need reflow or what to check in motherboard
    Re: dv6000 problem
    Chances are it will need a reflow or better yet a reball of the gpu/mcp chip. Very common on that model and dv series
      Re: dv6000 problem
      and this can be too reflow problem becouse just one sec be on and off again so no fan and nothing
        Re: dv6000 problem
        yeah if its one of the ones with the chipset and gpu all in one it can give those symptoms. Had a similar on about 4-5 weeks ago but in a dv9000. tried a reflow and it worked so had it reballed and no problem since
          Re: dv6000 problem
          ok and client say that did reflow last time 6 month ago so again reflow i can try becouse reballing never did.
            Re: dv6000 problem
            reflow generally isnt a permanent fix reballing will fix permanently. The solder is bad under the chip and needs replacing
              Re: dv6000 problem
              and now want be sure is reflow or smth other that give this problem
                Re: dv6000 problem
                and for reballing what mashine you use
