Rii Mini Keyboard/Touchpad
  • lv128
    PCB Tech
    • Aug 2011
    • 28
    This isn't the best topic to post it in, but it's the closest.
    I've got a Rii keyboard/touchpad, some of you might be familiar with these, they're poorly made keyboard and touchpad combos that are designed mostly for home theater PCs and cost about $60 usually.
    I had it for a little over a week and it worked well, then I set it upon the couch face down and picked it up about 5 minutes later, the orange (trasmitting) light was solid, when normally only blinks to indicate transmitting, and the green power LED was off. I've tried all the normal bevvy of troubleshooting, battery drain, etc. Nothing worked, and anytime it's powered on, just the solid transmit light. I've tested with another unit's receiver and they seem to be keyed to each other, so there's no love there.
    The electronics inside seem exceedingly simple, I'm wondering if anyone who's more well-versed in this might have some ideas of what could have gone wrong at a circuit level that I might poke at.
    Things I've tried:
    Quick reflow of the unlabeled ICs, some pins are joined together, but it looked like that before I touched it, so I assume they're bonded grounds. It uses Lead solder (of course).
    There doesn't seem to be any smt fuses on here, but it is getting power, so I don't think that's the issue.
    Notes: I believe J1 might be a USB header, so my next test will be to see if I can wire that up to see if it's the wireless part of it.
    Any input would be appreciated. Thanks guys!
  • PCBONEZ
    Grumpy Old Fart
    • Aug 2005
    • 10661
    Re: Rii Mini Keyboard/Touchpad
    You probably inadvertently changed channels so it can't connect.
    Read 4.7.
    The other unit's receiver is probably on a different channel too.
    Think like the keyboard and receiver are walkie-talkies.
    If they aren't on the same channel they can't 'talk' to each other.
    Mann-Made Global Warming.
    - Dr Seuss
    • lv128
      PCB Tech
      • Aug 2011
      • 28
      Read 4.7.
      Thanks for the suggestion, but I already tried that after checking the 1/2 page pamphlet that came with the unit. the ESC key has the RF subitem (which is triggered with FN key) but just for kicks I tried F1 as in that manual you listed, but it's a no-go.
      I'm pretty sure it's an electrical problem, the orange light immediately turns on and solid, indicating data, but the power light never comes on, I would assume if anything, the green power light should be on long before it tried to initialize the wireless.
      Any other ideas?
      • digge
        • Apr 2006
        • 296
        This might be a stupid suggestion, just wanted to ask if it might be possible that one of the keys got stuck and thats why it wont play nice? I have the same keyboard, never had that particular problem though, its not the best keyboard around but for linux use its way better then the expensive logitech ones that doesnt have any f1-f8 keys
        • lv128
          PCB Tech
          • Aug 2011
          • 28
          Unfortunately, no, I've had the unit completely dismantled and what appeared to be a USB header is a power header, but the +D and -D don't go anywhere, so it doesn't negotiate with a usb host at all, but it does power the unit.
          Not a stuck key, so I'm going to assume that this is static damage, because I had the thing face down on my couch on top of a blanket for about 5 minutes or so while moving around the living room. I've honestly never seen any electronic component die from static first-hand (heard about plenty) but given it's poor build quality it doesn't seem it could be anything else.
          • egorkat
            • Jun 2013
            • Moldova
            Hi! I have exactly same situation with Rii Mini II. It looks 100% same inside like yours.
            Did you find some information about these keyboards that might help in repair?
            • egorkat
              • Jun 2013
              • Moldova
              I've noticed unsoldered R4 and R5 resistors on D+ and D- lines. Will try to put a pair of 30-60 Ohms ones, to see if it will start talking on USB.
              • gobinath
                • Apr 2014
                • india
                acer travelmate 5270 cricut diagram
                • gobinath
                  • Apr 2014
                  • india
                  acer travelmate 5270 cricut diagram i need that
                  • djty
                    MBP 2013 15" 820-3787 no keyboard, no touchpad
                    by djty
                    Device: Laptop
                    Brand: Apple
                    Model: MacBook Pro
                    Board number: 820-3787-06
                    Problem:
                    • no keyboard, no trackpad
                    • Fans Spinning fast
                    Hello everyone. The MacBook pro late 2013 keyboard is not responses even when trackpad is disconnected.
                    no reaction on KB, only power button andd ctrl alt shift, which are on keyboard connectore are separately on the KB pinout KB backlight is present the PP3V3_S4 and PP3V42_G3H one keyboard connector J4813 are present on keyboard
                    external USB keyboard works Should touchpad be connected to motherboard for KB to be working?
                    03-17-2025, 11:03 AM
                  • playit
                    ps/2 port keyboard dead ? p5ql pro / ethernet cable light
                    by playit
                    my system is p5ql pro asus mobo , logitech keyboard ps2 keyboard (more than 10 years) .
                    my place use to get some power drip for a second ,at that time , pc shuts and restarts itself , it dint cause any problem till now , once or twice i noticed , i am not sure if it was exactly at power drip time or normal time - both keyboard and ethernet lan stopped working , the keyboard would lose power i mean led lights-num lock caps lock would not stay on , no light at etherbet cable too..then i would restart the pc - then its all good .
                    few years back ps2 mouse stopped working, but ps2...
                    12-23-2024, 06:05 AM
                    HP ProBook 430 G5 + Essential Top Load Case + USB Essential Keyboard & Mouse Notebook 400 Specification for Upgrade or Repair
                    This specification for the HP ProBook 430 G5 + Essential Top Load Case + USB Essential Keyboard & Mouse Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 430 G5 + Essential Top Load Case + USB Essential Keyboard & Mouse boardview and 430 G5 + Essential Top Load Case + USB Essential Keyboard & Mouse schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you...
                    09-06-2024, 06:21 AM
                    HP ProBook 450 G5 + Essential 15.6-inch Case, Keyboard & Mouse Notebook 400 Specification for Upgrade or Repair
                    This specification for the HP ProBook 450 G5 + Essential 15.6-inch Case, Keyboard & Mouse Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 450 G5 + Essential 15.6-inch Case, Keyboard & Mouse boardview and 450 G5 + Essential 15.6-inch Case, Keyboard & Mouse schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users...
                    HP ProBook 450 G5 + Essential Top Load Case + USB Essential Keyboard & Mouse Notebook 400 Specification for Upgrade or Repair
                    This specification for the HP ProBook 450 G5 + Essential Top Load Case + USB Essential Keyboard & Mouse Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 450 G5 + Essential Top Load Case + USB Essential Keyboard & Mouse boardview and 450 G5 + Essential Top Load Case + USB Essential Keyboard & Mouse schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you...
