acer aspire 4736z power problem
+ More Options
Posts
  • red_raian
    • Aug 2011
    • 14
    help to find these kind of problem,
    their is a supply for several parts esp. power P CHANNEL FETS, MAIN CAPACITOR, FUSE up to charging management the ISL******, PIN 1 3.*** AND 28 PIN 18.***, anybody here teach me where other parts may have a problem.. i was not able able to fix this kind of problem so i need you ideas guys here.
    thanks in advance!!
    more power BCF!
  • tedjo
    • Nov 2011
    • 5
    Re: acer aspire 4736z power problem
    Hi ... I have 4736 power problem too...
    Lets discuss it here .
    My mobo problem just blink power led, and sometimes will power on but nothing on screen ...
    • nish_pinto
      The Adventurist
      • Oct 2011
      • 83
      • India
      I have the same problem too. I happened to find a NEC/TOKEN cap, is that the culprit?
      http://nishantpinto.blogspot.in/
      • nish_pinto
        The Adventurist
        • Oct 2011
        • 83
        • India
        I removed the NEC/TOKEN(0E907) cap and replaced it with 4x330uf smd tantalum caps, dint work. then i used 2x330uf and 2x470uf tantalum caps. Bloody, now even the leds dont blink. somebody please help. Btw I used a smd rework station, just brought today.
        • Ch1p4@ll
          Newbie
          • Mar 2010
          • 19
          no clue? i got the same problem...
          but i think fixing nec/tokin only work for toshiba (Hang on charging, didnt start,always hang)
          i doubt the BIOS fail to start for acer problem (only led on, led blink) *note (intel GMA board)
          it happen on many type of acer aspire notebook.
          • b700029
            Banned
            • Sep 2010
            • 640
            http://lqv77.com/download/614/
            Is schematic helpful?
            • 2kang
              • Oct 2010
              I replaced with NEW NEC/TOKEN(0E907) .. didn't work too.. Vcore = 0 volt.
              • boodeey
                • Nov 2011
                • 7
                OE907 = 900 uF
                Try => (3 x 220 uf) + (1 x 330 uf)
                www.servicenotebookjakarta.com
                • b700029
                  Banned
                  • Sep 2010
                  • 640
                  Unless the cap is shorted, vcore won't be at 0V. Trace the vcore back to the MOSFETs and make sure those haven't failed open and are getting the right drive signal from the controller.
                  • xaviero1412
                    • Apr 2009
                    • 56
                    agreed with b700029
                    if not shorted caps, there will be a voltage.
                    if that sure not shorted, check the ISL6262 , that is Vcc_core generator IC. try resolder first, if not then try replace it.
                    • delaware74b
                      • Apr 2009
                      • 628
                      I am working on an Acer 7736 series laptop with no power problem. It has a short in the power supply section, turns off the ac adapter and no power from battery.
                      I found 2 shorted mosfets (FDS6690AS and FDS8884) located on bottom edge of JV71-MV mobo, below the memory sockets. These are controlled by the ISL62392 IC and it generates the +3.3 and +5V for the mobo. I have the mosfets removed and the short-circuit is gone from the mobo and the ac adapter isn't shutting down when I plug it in.
                      Apparently, this is a common issue on this particular mobo.
                      Stupidity should be a crime, especially for drivers. I have NO patience for them.
                      • xaviero1412
                        • Apr 2009
                        • 56
                        pardon, may i ask, i am wondering bout "shorted mosfet"....
                        what method did u use to find the "shorted mosfet" ???
                        thanks
                        • severach
                          • Aug 2007
                          • 1055
                          Removing the MOSFETs to stop the shorted power supply is not sufficient. That's no better than unplugging the power. You need to test the MOSFETs and the motherboard pads to see which is shorted. Unless the removed MOSFETs are obviously burned, my bet is the short is still on the motherboard.
                          sig files are for morons
                          • delaware74b
                            • Apr 2009
                            • 628
                            In my case, the pair of mosfets showed a dead short on pins 1 to 8 on both. I lifted pins 1-4 off the mobo solder pads enough to remove the mosfets from the mobo circuits.
                            Using my meter, the mosfets were definitely shorted. I reconnected the ac adapter to the mobo and it no longer went into short-circuit protection. I also checked the mobo where the mosfets were connected, no short circuit condition exists.
                            The shorted mosfets had no external indication of being shorted. I have seen mosfets after they have released all their magic smoke.
                            • xaviero1412
                              • Apr 2009
                              • 56
                              so, just check with diode-test/continuity-test to measure short or not. is it correct ???
                              • delaware74b
                                • Apr 2009
                                • 628
                                I used the 30megohm-range on resistance check. Continuity 'beep' mode on my meter trips at 300 ohms or less. I had a 'hard' short with the two mosfets in circuit. After I lifted pins 1-4 on each one, I tested both the circuits on the mobo and the mosfets. The mosfets were definitely still in shorted condition even after completely from the board.
                                • red_raian
                                  • Aug 2011
                                  • 14
                                  charging pin, just reflow it..
                                  • xaviero1412
                                    • Apr 2009
                                    • 56
                                    thanks for the great info....
                                    • johnwafu
                                      • May 2012
                                      • 17
                                      • philippines
                                      i have the same problem at first it has a power indicator and black screen then i tried replacing ram and processor but same problem occur.
                                      tried replacing the nectokin with 2 +330 cap
                                      then it has a display now but the problem now is you cannot shutdown the unit it always auto on
                                      tried replacing 4 +470 on netokin same problem
                                      tried replacing 2 ne 220 same problem
                                      tried replacing 4 ne 220 same problem
                                      any ideas sir?
                                      i have not yet tried the 220 negative and 330 negative
                                      • Madhusha
                                        • Apr 2012
                                        • 15
                                        • Srilanka
                                        My DMM is Sanwa "CD800a" I'm using some different way to hunt shorted caps,it s worked for me... my DMM Buzzer working for below 50ohms only & also it shows the value while it buzz. I jst take two wires from shorted path(cap's + & -) then clip DMM probes to those,on buzz mode(continuity)(it buzzes now:-), using hot-gun & a tweezers lifting and putting back caps,fets,diodes one by one until buz gos off... its worked for meeeeee
                                          ACER Aspire Aspire G7200 Predator Defender Aspire 9750 Specification for Upgrade or Repair
                                          This specification for the ACER Aspire Aspire G7200 Predator Defender can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire G7200 Predator Defender boardview and Aspire Aspire G7200 Predator Defender schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer...
                                          09-12-2024, 03:28 PM
                                          ACER Aspire Aspire X1300 Aspire Specification for Upgrade or Repair
                                          This specification for the ACER Aspire Aspire X1300 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire X1300 boardview and Aspire Aspire X1300 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
                                          Acer Aspire Aspire One 532h Netbook One Specification for Upgrade or Repair
                                          This specification for the Acer Aspire Aspire One 532h Netbook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Aspire One 532h boardview and Aspire One 532h schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
                                          09-06-2024, 05:27 AM
                                        • DenK
                                          Acer Aspire 5 A514-55 - won't power on, no charger LED, battery not flat - usual suspects?
                                          by DenK
                                          Dear all, I am trying to troubleshoot an Acer Aspire 5 A514-55 that won't power on. I'll describe the symptoms and my findings so far, and I would like to seek guidance and suggestions on possible suspects in terms of cause/component failure. My initial thoughts are battery charger IC and/or ideal diode/MOSFET (that switches between incoming DC and battery power), but I could be totally wrong on this.
                                          1) Laptop was working fine on battery, then user realised battery was running low. Plugged in AC adapter but noticed it was not charging (LED on AC adapter plug did not light). Eventually shut down
                                          12-06-2024, 01:29 AM
                                        • Bonaventure Vigil
                                          ACER ASPIRE A515-52G CAN ON BUT NO DISPLAY, NO POWER AT VCC_GT
                                          by Bonaventure Vigil
                                          Dear All,
                                          Please really2 need Help on this Acer A515-52G Motherboard Compal EH5AW LA-G521P Rev: 1A.
                                          At first this laptop can on, keyboard light on but no display. Open the motherboard, found out the PQZ3 Mosfet and PUZ3 ic near it burn. Refer picture below. Then I replaced both. All the power rail 3.3,5,1.2, 1.35, 0.8V have power back after i turn on the laptop except for the VCC_GT rail. Voltage at Power Supply showing 0.000A before turn on, after turn on it became 0.5 0.6A. Seem cannot boot and still no display. Then I replaced the PUG1 and mosfet, but the VCC_GT still no power....
                                          12-12-2024, 10:22 AM
