Toshiba A210-16F power problem
  • Joun
    • Jul 2011
    • 191
    • Greece
    Hello.
    I have a Toshiba A210-16F with a power problem that seems to be common:
    When I press power button,light comes on,fan spin for about 5 secs and HDD makes noises like it is going to boot..
    But then nothing..Fan stops , power light stays on,and nothing else happens.
    I was told that chip that controls CPU power (MAX8774) commonly has bad joints and that I have to resolder it.I did that and nothing changed.
    Anyone with a solution on that?
    Thank you..
  • Joun
    • Jul 2011
    • 191
    • Greece
    Re: Toshiba A210-16F power problem
    Anyone with similar problem?
    • theone111
      by theone111
      3. Problem: TV shuts down
      07-22-2024, 10:36 AM
    • Duranitron
      Asus x512dk rev 2.1 power on problem
      by Duranitron
      When I reflash again the bios of hoaca388 the unit powers on and the unit lives!!! Hooray!! All voltage in the coil 3.3v, 5v and 6.7v indicate charging are all present. including the cpu voltage , EEPROM and GPU voltage the unit is now alive, normal screen booting to windows and log in screen until I power it off. Then the unit never goes on even when pressing the power button in the keyboard.. Voltage reading 19v main , 3.3v VCC in IT8225E-128 and EEPROM VCC 0 volt and the charging voltage 0 volt.
      Try to trace the power switch button goin to the power switch IC PU8803 (APL3533AQBI-TRG)...
      11-26-2024, 10:22 PM
    • EazyBone
      LG OLED55C9PUA power problem
      by EazyBone
      Hello, trying to fix C9 55 inch. I have pulled the back and all looks completely normal with nothing burnt so far. This is first time attempting to fix a tv so any help is appreciated.
      Problem. I hit power button, red light on TV turns off and tries to turn on, no picture shows up and then shuts off. This occurred after house power turned on and off, not from a storm.
      I have tested the power going from power supply to main board, all 12v and 20 volt readings are proper when I hit power button.
      The power supply to t con is different story.
      This...
      06-23-2023, 07:43 AM
    • Dr.d
      Help please..Lenovo ideapad 5 14itl05 power and charging problem
      by Dr.d
      I have a lenovo ideapad 5 14itl05, board LA-K321P, That will only power up on Battery only, or with battery disconnected and power adapter only. If battery is connected and usb-c power plug connected. It only works on battery and will not charge. I can however force it to charge by connecting the battery from a disconnected state while the power USB c plug is powering the laptop.
      Additionally....to add to this strange situation. The usb-c power plug ONLY works to power the laptop on one side when inserted into the boards power usb c plug. If you rotate it 180 degrees, the board gets...
      04-05-2024, 11:48 AM
      03-31-2024, 02:12 PM
