This laptop will not power on .The keyboard indicator leds have 1 solid green and 2 flashing . I dont have a good battery to check if it would run on batterys.
dell isperion 9400 will not power on
Assuming...7 Photos -
by PantherDaveHi all!
I'm trying to troubleshoot a Microsoft Surface Pro (5th gen) model 1796 that won't power on. Motherboard model is M1007506-015. My priority is retrieving data, but the SSD is integrated so it looks like if I can't repair it it'll need to go to a data recovery company. I've done a little basic board repair before, but nothing this advanced until now. So please forgive my ignorance in advance. ๐
https://www.badcaps.net/forum/troubl...-hardware-devi... -
by Mark01Hi guys,
This is my first post! ๐
I have no idea what Iโm doing, but Iโm learning by trial and error.
Iโm currently working on a Dell Optiplex AIO 7490โone of a bunch of AIOs that mysteriously failed to POST just a few days after the warranty expired. The original issue was that the PC worked fine until it was rebooted, after which it got stuck on a black screen (no backlight), with fans spinning at normal speed and a solid white power LED. Forcing it off by holding the power button would just cause it to switch on automatically and get stuck again on...07-04-2025, 12:54 PM -
by zlr8rhey guys, hoping for some pointers to repair an eBay bought "faulty" laptop.
Ill try and give as much info as I can.
Dell Inspiron 17 (7786) Laptop
Service Tag: 5J0NHT2
Bios: 1.9.0
When I received this , it would only flicker on the KB backlight for a second, then off and on.
Then it started getting weirder!
Sometimes when attaching the AC power supply, and pressing various pre-boot diagnostic keyboard keys... it did try to boot, in fact out of a hundred attempts, the laptop did actually boot into the Bios ! but never has... -
by LimesKeyHi everyone, I have an Inspiron 7506 laptop I've had for a few years, and it'd occasionally have a problem where after I'd power it off, it wouldn't turn on again unless I disconnected, drained residual voltage by pressing the power button, and reconnected the battery. It now seems to be occurring every single time I shut down the laptop and attempt to turn it back on again. I have done all the common troubleshooting steps, such as completely disconnecting the battery & CMOS battery and draining the voltage and leaving it for an hour, and I've even replaced the battery. This is definitely...10-17-2025, 05:33 PM
- Loading...
