HP DV7 Component Ident.
  • Kilroy2k1
    • Aug 2009
    • 69
    I have a DV7-1428ca laptop that the my daughter spilled something on and a drip got on the motherboard in a couple areas. The worst so far is a corroded resistor, bad enough i cant get a value reading.
    If anyone would happen to have a dv7 1400 or 1200 series motherboard would it be possible to measure the value of a resistor for me?
    The item in question is in the circle on the image and is labled R871 on the board.
    Thanks for any assistance.
    Tom.
  • ablacon64
    • Jan 2011
    • 89
    Re: HP DV7 Component Ident.
    It may be difficult for someone to have the same motherboard to measure the component. It's better if you post the MB model, maybe someone may take a look at the schematics. The MB model is something like LA-xxxxP, usually next to the memory slots or keyboard connector.
    • Kilroy2k1
      • Aug 2009
      • 69
      Thanks for the reply, There are a ton of numbers on here so I'm glad you clued me in on which one is necessary.
      The number on this one is JBK00 LA-4091P
      I Hope someone has the schematics or a matching board to measure up
      Thanks again
      Tom.
      • yyonline
        • Jul 2009
        • 692
        From the datasheet:
        R871
        330K_0402_5%
        So 330Kohm resistance, 5% tolerance, 0402 size.
        • Kilroy2k1
          • Aug 2009
          • 69
          Thank you very much sir.
          I'll get that replaced in the morning and see if it solves the issue this unit has developed.
          Thanks again
          Tom.
          • Kilroy2k1
            • Aug 2009
            • 69
            Apparently that is not the only problem on the board. I replaced the resistor and the unit still shuts down 3 seconds after headphones are plugged in and the IR remote reciever does not work.
            Would anyone have any ideas where to look?
            Or maybe i whould start a new topic..
            yyonline would there be any possibility of getting a copy of the schematic or just the parts pertaining to this section?
            Tom.
            • ablacon64
              • Jan 2011
              • 89
              Does the unit work fine without plugging the headphones?
              • Kilroy2k1
                • Aug 2009
                • 69
                Yes everything else but the IR reciever for the remote and the headphone outout works well.
                The IR does show a voltage change when you point and shoot the remote, but there may be a problem in the chip that translates it.
                Audio works fine from the laptops speakers.
                I isolated the jack daughterboard and manually pulled the sense line (3.4V) to ground and it still shuts the unit down after 3 seconds.
                It seems like the sense line runs through 2 6 pin transistors, Q20 and Q148, between the codec chip and the jack daughter board so I am wondering if something in that little mess is shorting and tripping the protect.
                I've been trying to identify those two transistors but the markings of MNIVO dont come up at all.
                • Kilroy2k1
                  • Aug 2009
                  • 69
                  Well audio is fixed. found some more corrosion over by the docking port, cleaned it up and touched up a few solder joints.
                  The IR is still out to lunch tho..
                  • ablacon64
                    • Jan 2011
                    • 89
                    Have you checked bios config for IR?
                    • Kilroy2k1
                      • Aug 2009
                      • 69
                      I took a quick look in there and didnt see anything relating to the IR.
                      With some probing I see the IR functioning but only getting a .09V fluctuation when hitting a button on the remote, this seems a little low to me.
                      • jinu_j
                        by jinu_j
                        Hi
                        05-03-2025, 10:51 PM
                      • mikey5791
                        by mikey5791
                        Hi to all forum members,
                        12-26-2024, 04:55 AM
                      • MidnightRoller
                        Can a resistor lose resistance after hot air?
                        by MidnightRoller
                        I am curious if a 0402 resistor could go from 43 ohm to 0. In electronics class and my experience a resistor can degrade and gain resistance all the way up to not being able to conduct at all. I have never heard of a resistor decreasing in resistance and becoming 0 ohm or a dead short… that's not the direction they fail… or so I thought.
                        I was attempting to remove a wson8 chip on an iMac motherboard and it required a lot of heat, on one side of the chip were 3 0402 resistors that were very close. I popped the chip out unintentionally out of the tweezers and sent those resistors...
                        02-02-2022, 11:46 PM
                      • artvandalai
                        What resistor ohm will work better to repair this waterpik?
                        by artvandalai
                        The resistor on this waterpik blew. I changed it with the a similar spec 47ohm 2 watt yageo resistor but it still keeps blowing the resistor. Checking with the multimeter the motor, capacitor, diodes, and thermal fuse all checked normal. Will a higher ohm resistor work better? What ohm resistor will work better to repair this waterpik? This video is showing the repair with a 56 ohm resistor https://www.youtube.com/watch?v=_J7_rV7ui1Y
                        01-05-2025, 04:10 PM
                      • badcap111
                        Xiaomi mi 9T missing resistor
                        by badcap111
                        Hi, while trying to replace a broken screen connector on the motherboard, I knocked off a resistor next to the connector, and the resistor vanished. I have tried to find out the value of the resistor by looking at the schematics, but I cannot find the value. The ID of the resistor, or what you should call it, is R6400.
                        I don't know if the resistor is necessary for the phone to function, and the connector is still not soldered on to motherboard. I have contacted Xiaomi and asked them if they know the value, but they want a proof of purchase, which I don't have.
                        Is...
                        08-07-2023, 10:42 AM
