Dell D610 bleed resistor
  • Uranium-235
    Comrade Glimmer
    • Aug 2007
    • 5045
    • US
    Re: Dell D610 bleed resistor
    yes yes yes
    • Uranium-235
      Comrade Glimmer
      • Aug 2007
      • 5045
      • US
      in the end the question still remains, should I go for it, or is this something I should not even bother ordering from digikey and waiting another few days for it to get here?
      I already got the jack in, I probably should of done the rv's first anyways
      • Uranium-235
        Comrade Glimmer
        • Aug 2007
        • 5045
        • US
        well I did it, put it on without replacing them. seems to work ok, sometimes I get a very high-pitch noise from it when its off (so high only dogs can hear it-and me)
        still works though, charges and everything
        • yyonline
          • Jul 2009
          • 692
          the RVs are much easier to do after the jack, at least for me. In fact, I usually take them off before I replace a D610 jack, as they just get in the way. I put them back when I'm done.
          On a side note - why are the D610 power jacks so failure prone? I see them break occasionally in other models, but it's broken in nearly all the D610s. At least the Tyco ones, the Foxconn ones seem to fare slightly better.
          • jinu_j
            by jinu_j
            Hi
            05-03-2025, 10:51 PM
          • MidnightRoller
            Can a resistor lose resistance after hot air?
            by MidnightRoller
            I am curious if a 0402 resistor could go from 43 ohm to 0. In electronics class and my experience a resistor can degrade and gain resistance all the way up to not being able to conduct at all. I have never heard of a resistor decreasing in resistance and becoming 0 ohm or a dead short… that's not the direction they fail… or so I thought.
            I was attempting to remove a wson8 chip on an iMac motherboard and it required a lot of heat, on one side of the chip were 3 0402 resistors that were very close. I popped the chip out unintentionally out of the tweezers and sent those resistors...
            02-02-2022, 11:46 PM
          • Bowline
            by Bowline
            06-11-2025, 10:13 AM
          • Bivolalbert
            Help figuring out the resistance of this exploded resistor. gtx 1060 6gb inno3d compact
            by Bivolalbert
            Hello,I need help figuring out the resistance of this exploded resistor. I'm pretty sure it's the one labeled R37. I tried measuring it with a multimeter, but I got different values each time, probably because it's exploded. If you have a schematic, it would be really helpful!
            Its a gtx 1060 6gb inno3d compact, i you have schematic it would be very helpful....
            02-13-2025, 10:30 AM
          • stormanimal83
            Need resistor value R519 Phase_w Fan1_Tach_FB for Dell E4310
            by stormanimal83
            I need the value for the resistor R519 on dell E4310 mainboard. nothing to find in boardview. resistor was blown/shorted laptop didnt turn on with fan connected. i desoldered R519 but fan ist cycling up an down continuously now. laptop is running fine now but sounds crazy... Resistir is for PHASE_W FAN1_TACH_FB... rpm not given now but as i said therefore the laptop is working again...
            the upper one of two soldered here... nearest to fan
            thanks for help
            UPDATE!
            found scematics right now.... is this a zero...
            05-06-2023, 09:56 AM
