820-02020 keyboard trackpad not functioning
  • kingskie
    • Oct 2014
    • 249
    • indonesia
    hi all,
    i am working on macbook pro A2338 820-02020 can turn on but keyboard and trackpad not functioning.
    no sign of water damage.
    measurements:
    TPAD_KBD_WAKE_L = 1.78V
    KBD_INT_L = 1.8V
    SPI_TPAD_INT_CONN_L = 1.77V
    IPD_LID_OPEN_1V8 = 0V
    I2C_SMC_IPD_1V8_SCL = 1.79V
    I2C_KBD_SDA = 1.84V
    SPI_TPAD_MOSI_CONN = 0V
    IPD_LID_OPEN_1V8 = 1.8V when open lid
    anyone can help?
  • kingskie
    • Oct 2014
    • 249
    • indonesia
    Re: 820-02020 keyboard trackpad not functioning
    no external keyboard and mouse working either even in recovery mode.
    alredy change the touchpad cable but nothing happened
    can someone help?
    • Pedro147
      Pedro147 commented
      Editing a comment
      As you may be aware, the keyboard/ track pad communicate using the USB protocol prior to login and in recovery. They then switch to SPI communication after login. Therefore I would be look at the data function of the USB ports. If you have any sort ot drive with a data activity LED, you can see if there is any activity on the ports data wise.
  • JPonce
    • Nov 2022
    • Mexico
    Originally posted by kingskie
    hi all,
    measurements:
    KBD_INT_L = 1.8V
    I2C_KBD_SDA = 1.84V
    anyone can help?
    Did You resolver your problem ? I'm dealing the same fault
    • mon2
      • 14634
      What is the history of your machine? Liquid damage? Post pics of the cables of these parts. Test with an external keyboard & mouse. They work?
      • reformatt
        • Feb 2020
        • 1476
        Try another trackpad first. Keyboards on MAC's don't work without a functional trackpad. Remove and examine trackpad for liquid damage etc as this is a common fault.
        • JPonce
          • Nov 2022
          • Mexico
          On My case i replace keyboard and trackpad with a known working ones. And i have same lectures as kingskie. Thanks for the reply
          • reformatt
            • Feb 2020
            • 1476
            Examine JT400 connector and it's associated flex cable pins for damage under the microscope. Check diode values using the values from OpenBoardData for the connector.
            Review voltages on JT400 connector
            PPBUS_AON
            PP5V_S2_TPAD_CONN
            PP1V85_S2_ISNS
            PP3V3__S2_TPAD_ISNS
            etc
            • Vliegenier04
              Macbook A2338 M2 (EMC 8162) keyboard not functioning, trackpad is working
              by Vliegenier04
              Hi! This Mac has been an headscratcher for me, I can't seem to figure out the issue. The Macbook has gotten water damage to the front of the keyboard connector and battery connector. The keyboard connector was dead, by which I mean it was completely corroded and I have replaced it with a brand new one.
              I have verified all the pins are connected to the main board and the main voltages (PP1V8_AONSW_KBD_ISNS and PP3V3_AON_KBD_CONN) are both present, with and without keyboard attached.
              Unfortunately, the keyboard does NOT want to work, caps lock LED not functioning as well as any...
              06-16-2025, 12:03 PM
            • guzq
              MBA13 M3 2024 A3113 EMC8611 820-03285 No Trackpad No Keyboard (water damaged)
              by guzq
              Hi Guys,
              This Mac come with dead issues (severe water damage), now it’s turning ON except Trackpad and Keyboard not working.
              Already check and write down DM for JT400 and JT201 don’t find any abnormal value (I don’t have unit for compare).
              Already try,
              • Replacing Trackpad Flex Cable
              • Replacing New Trackpad
              • Replacing Little Board (Daughter Board)
              • Try using New Keyboard
              Still no change at all, Trackpad and Keyboard not working.
              So I check “Power Load Switches” and this is all the numbers,
              UC830 > 1 = 3.297V ; 3 =1.757V ; 4 = 3.798V...
              07-08-2025, 05:19 AM
            • playit
              ps/2 port keyboard dead ? p5ql pro / ethernet cable light
              by playit
              my system is p5ql pro asus mobo , logitech keyboard ps2 keyboard (more than 10 years) .
              my place use to get some power drip for a second ,at that time , pc shuts and restarts itself , it dint cause any problem till now , once or twice i noticed , i am not sure if it was exactly at power drip time or normal time - both keyboard and ethernet lan stopped working , the keyboard would lose power i mean led lights-num lock caps lock would not stay on , no light at etherbet cable too..then i would restart the pc - then its all good .
              few years back ps2 mouse stopped working, but ps2...
              12-23-2024, 06:05 AM
            • nicocorradini
              820-00426 (A1398 2015) no trackpad, no keyboard.
              by nicocorradini
              Hi! I have this 2015 A1398 with 820-00426 board that's driving me crazy. It originally came because of charging problems (MagSafe Board roasted, also MagSafe cable, etc. After disassembly, clean and assembly, my assistant (literally) broke FL803 and other componentes. Obviously, no screen or backlight. After replacing them, and also the LVDS connector, and LVDS flex on the screen, the board started fine, charges, chimes, shows Apple Logo, but surprise: no more trackpad or keyboard.
              Important notes:
              -Click works, so, trackpad is alive.
              -Already tried with another trackpad,...
              03-04-2025, 07:01 PM
            • mitchw
              MacBook Pro M4 Pro - no keyboard / trackpad / lid sensor
              by mitchw
              Hello
              I got this MacBook Pro M4 Pro to have a look at.
              It was tiny bit liquid damaged, just the edge of the board got 1 small 10x10 mm area wet. I've seen much worse that still worked fine to be honest.
              Since it was liquid damaged, warranty does not apply anymore.
              Anyways it was checked at an local Apple Store and they discovered that it needs new trackpad, new top case, etc. Also it needed a new lid angle sensor which they replaced.
              The main issue was that the screen remained black.
              Anyways I cleaned the liquid damaged area, put the machine back...
              09-06-2025, 07:19 AM
