dell bluetooth modules
  • ratdude747
    Black Sheep
    • Nov 2008
    • 17136
    well, dell forums has been useless so far... so here goes:
    i have a dell latitude d400. it has no bluetooth. it has a bluetooth bay and LED.
    the bluetooth option on this model was the dell truemobile 300, a bluetooth 1.2 chip.
    they later made a truemobile 350 chip with bluetooth 2.0
    they are the same form factor and coneector. 5 pin cable (already in laptop), likely 4 for usb and the 5th is for the LED.
    the issue is that another d series model had issues with the swap... bios not detecting the the newer chip, rendering it useless.
    anybody have any info or a spare truemobile 350 chip that they would be willing to part or play with?
    sigpic
    (Insert witty quote here)
  • shovenose
    Send Doge Memes
    • Aug 2010
    • 6575
    Re: dell bluetooth modules
    FUCK! at work yesteday I sold the only one we had! o well...
    coudbt you have asked this a day earlier?
    • ratdude747
      Black Sheep
      • Nov 2008
      • 17136
      i can get one on ebay for $12... i might try it.
      sigpic
      • acedogblast
        by acedogblast
        11-02-2024, 05:13 PM
      • ffrlr
        Dell 5410 that doesn't have bluetooth enabled,help please
        by ffrlr
        Morning guy's,
        I have a Dell Latitude 5410 that doesn't have bluetooth enabled, by that I mean the internal bluetooth on the wireless card.
        I have removed the wireless card and fitted it into a 5420 which uses the same card, and bluetooth works in that laptop, so I know the wireless card is fine, the one from the 5420 also doesn't have bluetooth available when in the 5410.
        When I go into setup, under wirelsss, the bluetooth option is greyed out, if I look the service tag up on the Dell support page, it seems it was supplied without bluetooth, my question is...
        08-02-2023, 01:42 AM
      • ed1i
        Dell Inspion 7610 bios chip
        by ed1i
        Hello, I'm looking for bios chip on the motherboard on Dell Inspiron 7610. Server tag: CS4MDL3. I found on the back on the motherboard chip named: Winbond 25Q256JVEQ. Is it the right bios chip for this motherboard? I need to flash new bios on the chip, because it's stuck in infinity reboots. Is it possible this chip to be read AsProgrammer 25Q256JV option and ch341a programmer?...
        01-16-2025, 02:14 PM
      • ezenia
        Dell G3 3579 BIOS chip ID
        by ezenia
        I bought a Dell G3 3579 eBay. The fault was not mentioned and it did not come with charger. Before trying to power off battery, I did some basic checks on the coils (in resistance mode) to see if there was any short. None were reading short. Decided to power the board to see if anything happened. The keyboard backlight came on. About 5 seconds later, the fans begin spinning at max speed. The white LED comes on at this time, stays solid for a bit and goes off. Fans continue to spin at max. Display is black (no backlight). If I hold down power button, board goes off. I did give...
        06-16-2025, 08:07 PM
      • Bowline
        by Bowline
        06-11-2025, 10:13 AM
