dell bluetooth modules
  • ratdude747
    Black Sheep
    • Nov 2008
    • 17136
    well, dell forums has been useless so far... so here goes:
    i have a dell latitude d400. it has no bluetooth. it has a bluetooth bay and LED.
    the bluetooth option on this model was the dell truemobile 300, a bluetooth 1.2 chip.
    they later made a truemobile 350 chip with bluetooth 2.0
    they are the same form factor and coneector. 5 pin cable (already in laptop), likely 4 for usb and the 5th is for the LED.
    the issue is that another d series model had issues with the swap... bios not detecting the the newer chip, rendering it useless.
    anybody have any info or a spare truemobile 350 chip that they would be willing to part or play with?
    sigpic
    (Insert witty quote here)
  • shovenose
    Send Doge Memes
    • Aug 2010
    • 6575
    Re: dell bluetooth modules
    FUCK! at work yesteday I sold the only one we had! o well...
    coudbt you have asked this a day earlier?
    • ratdude747
      Black Sheep
      • Nov 2008
      • 17136
      i can get one on ebay for $12... i might try it.
      sigpic
      • acedogblast
        by acedogblast
        11-02-2024, 05:13 PM
      • capoplays
        Help with BIOS update on Dell G15 5515 after chip replacement
        by capoplays
        Hey everyone,
        I recently bought a Dell G15 5515 with an AMD Ryzen 7 5800H and 3060 RTX. The BIOS chip on it was dead, and my hardware guy replaced the chip. After that, everything was working fine.
        The BIOS is currently at version 1.22.1, and I wanted to update it. I downloaded the latest BIOS version from Dell Support using my ST: FQZMYJ3, but when I tried to run it, it says "unsupported system." I asked my tech guy what he did, and he said he took the chip from another board and flashed it onto mine.
        When I check the BIOS using the F12 menu Flash...
        10-24-2025, 06:53 AM
      • DynaxSC
        ASRock B650M PRO RS - BIOS CHIP 25Q256JW BLOCKED BY STATUS REGISTERS
        by DynaxSC
        Hi
        I have then desoldered the chip, backupped the contents, and tried to earease the chip in order to program stock image, but the chip is locked by status registers SREG2 (TB) and SREG6...
        08-04-2025, 12:20 PM
      • ffrlr
        Dell 5410 that doesn't have bluetooth enabled,help please
        by ffrlr
        Morning guy's,
        I have a Dell Latitude 5410 that doesn't have bluetooth enabled, by that I mean the internal bluetooth on the wireless card.
        I have removed the wireless card and fitted it into a 5420 which uses the same card, and bluetooth works in that laptop, so I know the wireless card is fine, the one from the 5420 also doesn't have bluetooth available when in the 5410.
        When I go into setup, under wirelsss, the bluetooth option is greyed out, if I look the service tag up on the Dell support page, it seems it was supplied without bluetooth, my question is...
        08-02-2023, 01:42 AM
      • Zilicon
        ATS2835P Bluetooth Chip used in a Zealit Bluetooth speaker
        by Zilicon
        Greetings everyone, please I need help with the above Bluetooth module.
        I was fixing a Bluetooth speaker that was dead, no sign of life. On checking, i didscovered the bluetooth chip ATS2835P got hot.
        I bought a new ATS2835P, the bluetooth flashes red light faintly continuously.
        Does this chip requires programming before it can work?...
        07-05-2025, 02:54 AM
