Macbook Air A1465 820-3435B
  • Sergio Kub
    • Jul 2018
    • 176
    • Brasil
    Good afternoon... Could anyone help me?
    I bought an 820-3435B board on Aliexpress and it arrived without charging the battery.
    The 1465 820-3435B is working fine, but I connect the MAgsafe, the screen indicates that it is charging the battery, but the Q7155 mosfet (P channel) Gate becomes Hi and does not charge the battery
  • mon2
    • 14662
    Re: Macbook Air A1465 820-3435B
    Hi.
    1) is the battery a known good battery?
    2) are you able to view the battery details like serial number, number of charge cycles?
    3) try a smc reset:
    https://forums.macrumors.com/threads...-down.1963147/
    4) is the MagSafe led orange when the battery is connected with the power adapter?
    • Sergio Kub
      • Jul 2018
      • 176
      • Brasil
      MagSafe LED has no light, neither orange nor green, with battery connected or without battery connected...
      • mon2
        • 14662
        Review if you have the +3v42 rail.
        • reformatt
          • Feb 2020
          • 1496
          Check with another LIO board and cable first. Also review the connector J9500 at the base for corrosion etc. You need signals SYS_ONEWIRE from the SMC, in addition to SMC_BC_ACOK present at this connector to get one wire comms. Without it, SMC won't enable battery charging.
          • Sergio Kub
            • Jul 2018
            • 176
            • Brasil
            Yes, 3.42V exists, computer works fine with power from the charger. Does not charge the battery nor does the Mag Safe light turn on green or orange
            • Sergio Kub
              • Jul 2018
              • 176
              • Brasil
              Yes, it doesn't have the 3.42V SYS_ONEWIRE.
              I'll get another DC card to test.
              • Pxxx3104
                • Jun 2025
                • 8
                • Philippines
                Hi. I would just like to ask. It is my first time on troubleshooting apple devices. Does the macbook air a1465 turn on without a battery installes? Only the magsafe charger will be the supply. Thank you for the answer.
                • mon2
                  • 14662
                  Yes.
                  Review this flow chart:
                  G3 to S3 State for Ivy Bridge Haswell and Broadwell - LogiWiki
                  • Bowline
                    by Bowline
                    06-11-2025, 10:13 AM
                  • gboone
                    820-00850 2019 MacBook Pro 13" Touch Bar (A1989) mysterious battery drain
                    by gboone
                    Hi, I was given this laptop by my uncle who said:
                    • It would occasionally shutdown if not plugged in
                    • battery had been replaced
                    • touchbar would "strobe"
                    I disconnected touch bar components and strobing and sudden shutdowns were fixed. Recent updates were installed to the OS.
                    After fully charging the battery, with bluetooth disabled, no LAN cable and only wifi enabled, the laptop stayed on (screen on) for about 6-8 hours. Allowing screen to turn off while not in use, and it went for over a day.
                    BUT
                    When powered off, it would at some point have a...
                    01-27-2025, 09:12 AM
                  • mferna14
                    MacBook Air A2681 battery problem after Screen Replacement
                    by mferna14
                    Hi, my dear friends., Maybe this might be a stupid question or something I missed or do not know. I have 2 MacBook Air A2681 (Indentical color & EMC #), both LCD screens broken. Before ordering the LCD Screens I confirmed both worked with their respective batteries & AC Adapters, & they did 100%. The LCD Screens came in today & I replaced LCD for the 1st A2681. (Removed Battery Terminal cable for both Laptops before installation of LCDs). Perfect Screen & Booted up fine. But it did not work with battery. I checked the battery connector & it was seated in well/perfectly....
                    12-06-2024, 08:10 PM
                  • mkdj
                    by mkdj
                    Mark and model: ASUS X571
                    Tests already made:
                    - I have removed...
                    07-14-2025, 09:16 AM
                  • leonemax81
                    Macbook a1707 820-00281 Battery no Power
                    by leonemax81
                    Hi guys I have a Macbook a1707 with motherboard 820-00281, without liquid damage that behaves strangely, with the battery connected the Macbook does not turn on and the USBC meter stops at 5v in loop, when I disconnect the battery the Macbook turns on and works fine, I have already tried to replace the battery twice without success, as soon as I connect the black cable of the battery the Macbook does not turn on, it stops at 5v and in loop.
                    08-23-2024, 09:24 AM
