a2251 820-01949 - reboot issues
  • Opunktvoll
    • Sep 2022
    • 22
    • Deutschland
    acc. to owner the macbook suddenly died for no reason. 20V but no s5 state.
    Board looks clean, no damage at all. Thermal cam shows hot T2 and PMIC.
    After DFU restore it was working again, but I´m not able to install MacOS because it always reboots (most of the time it shuts off during recovery mode loading screen, sometimes I can get into recovery and even format SSD, but latest after trying to install MacOS it shuts off again). --> Screen turns black, fan blow at full speed for one second --> macbook reboots
    Any Ideas?
  • duwane
    A2141 (2019 16" MB Pro) Strange macOS install issues. NAND? WIFI? FIRMWARE?
    by duwane
    Hi All.
    Sorry ahead of time for the text wall. This is a strange problem and I have tried to explain it as best I can. I realise this is a hardware forum (mostly), but I am still not sure if this is even a hardware fault! I am hoping that someone more knowledgeable than me in the area of understanding installation logs, or someone that has had a similar issue in the past may have some ideas of what might be causing this.
    The issue:
    Unable to do a clean install of any macOS versions supported for this model, even after fully erasing and formatting the internal SSD,...
    10-26-2022, 07:02 AM
  • gretti
    MSI Z370-A Pro, works but does not power off or reboot and USB issues
    by gretti
    I have a MSI Z370-A Pro. The board does not reboot or shut down from the Windows recovery console. USB communications stop and the status light on USB 1 stays on and does not blink. I have programmed a new BIOS with a CH341A programmer already, swapped RAM, PSU, CPU. The board will power off when the power button is held and resets when the reset switch is pressed, but it will not react to the reset switch if already told by software to shut down or restart. The board will reboot from BIOS after a save and exit command.
    The MSI BIOS included the ME firmware for the board. The size...
    10-16-2025, 02:14 AM
  • Stachujones
    Mac Mini 2014 820-5509A Reboot loop while installing macOS
    by Stachujones
    Hello i have got a Mac Mini 2014 with 820-5509A motherboard it powers on but i cannot install macOS, in first part of installer it goes about 75% and reboots back again to installer
    I think the bios was changed because it has a lot of flux around EFi chip
    Thanks in advance
    06-09-2025, 08:34 AM
  • pb1911nt
    MacBook Pro A2251 - 820-01949 Voltage Drop and unkown issues.
    by pb1911nt
    Hello forum,
    I'm still relatively new to the world of electrical repairs.
    I have a Macbook here that I can't figure out
    When the battery is gone, the USB input consumption goes up to 20 V and 0.06A. But it breaks down after about 2-3 seconds and you can also hear a small ticking on the logic board. But I can't pinpoint it exactly.
    I removed the logic board and took a few measurements.
    But I can't really figure it out.
    At first I thought the infamous CD chip was defective - but then of course you read more on the internet...
    09-07-2025, 11:35 AM
  • spice_disc
    Vizio TV M50-C1 reboot cycle and static on screen
    by spice_disc
    I'm currently trying to diagnose and fix my Vizio TV (Model M50-C1). I've tried a number of different basic solutions, but I'm trying to determine if my issue is currently a failing panel, T-Con board, or main board (or something else entirely) and whether or not it is worth my time to fix it. Details of the issue and what I've tried are below as well as why I think it is either a bad panel, T-Con board, or main board.
    The Issue: The TV will be on and working fine but after the TV is on for ~5-10 minutes the screen will freeze (with sound continuing) until the TV reboots itself. While...
    09-08-2024, 02:37 PM
