HP 15-fa0000 (680A2AV) power led blilnking
  • mel82
    • Oct 2023
    • 11
    • usa
    Hello, everyone.
    Mainboard model: DAG3 PMB180 REV:B MODEL: G3P
    Victus 15-fa0000 (680A2AV)
    This is my first time I tackle this kind of problem with a laptop
    usually dealt with resting cmos, replace bad memory sticks or replace heat sink
    or visual bad caps and resistor and fuse...screens, keyboard etc... but not this advance but I am willing to learn repair this my self....
    I have replace memory stick before when it went bad HP has different light code the cap key blinks when is bad memory.
    I drop this laptop not from high place, I picked it up the the system was frozen, I power it off by force(power key) and re-turn on boot it up fine than few mins later just completely die no notice, try turn it on again took couple second finally power on and ask for boot password I had set.
    power off I went to work and I came home try to turn it on never again power on, now on my keyboard(this specific model) the power on is on the
    the keyboard and has white led. this led blinks interval every 9 seconds.
    if on battery, when i plug in the power cord connector has led too is amber color which mean is charging mode
    but also blinks as the same interval as power led on the keyboard.
    I did complete tear down to main-board and I uploaded 3 videos on my public google drive so any expert can see what main-board trying tell me!
    https://drive.google.com/drive/folde...r3?usp=sharing
    I did search the forums not many people have this specific model and few post I have found was talking about bios fail update etc...
  • rddube
    Aspiring Expert
    • Jun 2013
    • 940
    Re: HP 15-fa0000 (680A2AV) power led blilnking
    Did you try HP bios recovery procedure?
    • mel82
      • Oct 2023
      • 11
      • usa
      Hello, thank you for the reply.
      sorry for late reply been busy with work.
      I prepare recovery usb with latest bios
      and hit window key + b plus power button
      nothing no activities from usb drive which has led on it.
      i also notice the charging system works because i left
      laptop plug forgot unplug and had steady amber led indicated
      is charging when i got back from work the led was white
      indicating fully charge.
      • rddube
        Aspiring Expert
        • Jun 2013
        • 940
        You can check what they say here: https://h30434.www3.hp.com/t5/Notebo...s/td-p/7484805
        but I think there might be something wrong with your motherboard. If I were you, I would dissassemble it completely and to a thorough inspection of the motherboard, check for loose components, the connectors, the cpu (socket if it is not soldered), the pch, the graphics processor. The drop probably disloged something. Post some nice clear photos so that we can help you see if anything is visible.
        • mel82
          • Oct 2023
          • 11
          • usa
          ok, im at work. i teardown tomorrow and upload the pictures...
          my mine blinks 9 second interval just keep doing that and i plug in
          usb flash had led on left side the usb port i get power to usb i see light blinks almost like the power led
          i plug the flash to right side of laptop i get no activity from usb flash led
          thank you.
          • mel82
            • Oct 2023
            • 11
            • usa
            i uploaded the pictures to my drive
            https://drive.google.com/drive/folde...xleP9WK7fjeUr3
            i try take close pictures as i can before my camera start nagging im too close
            • rddube
              Aspiring Expert
              • Jun 2013
              • 940
              Very hard to see with photos. One of your videos that shows a solid white light seems to show that it is powered on, no?
              • rddube
                Aspiring Expert
                • Jun 2013
                • 940
                You might want to check this too: https://www.youtube.com/watch?v=Brvi4g6mzHE
                • mel82
                  • Oct 2023
                  • 11
                  • usa
                  when I unplug everything and just bare mainboard and ac connecter i plug in stay on but after few seconds goes back to every 9 second interval blinking. someone another thread suggested test SIC whenever i get my multimeter. Im just hoping is not my cpu. this laptop is gaming laptop. i got it feb this year.
                  I can't find any information what is the 9 second interval blinking what is trying tell me. no beep sounds no other indications . the laptop still charge battery normally so tells me there's no issue with charging...
                  I did slow visual inspection for burn, etc... i didn't see anything. I saw video saying any short the area would be hot or weird looking.
                  • rddube
                    Aspiring Expert
                    • Jun 2013
                    • 940
                    In the meantime, I suggest you look at Northbridge Fix and Electronics repair school youtube videos, they are masters in their art and will guide you on how to test for a short, etc. You might even find a video that duplicates your problem. I have learnt so much from them, it is priceless. Let me know your progress.
                    • mcplslg123
                      • Jun 2015
                      • 7262
                      • india
                      basics not followed. start with measuring resistance to GND on all coils(all power disconnected).Then proceed to measure voltages on all coils.
                      • mel82
                        • Oct 2023
                        • 11
                        • usa
                        Hello, I have been busy with work.. Today been testing the board for continuity, and what area of the board getting power this what I have so far attached pictures.
                        2 of the picture Im doing continuity test one has higher reading no beep
                        other one has lower reading it beeps indicating is close path(good?)
                        than other picture circle in orange is other area i test ididn't get any beeps and high readings.
                        on 4th picture with red brushes and white terminal I test around here i got audible and is getting power when I plug ac according to the video i watch usually this the area check first for shorts and bad cap etc...
                        • PantherDave
                          by PantherDave
                          Hi all!
                          05-29-2024, 02:01 PM
                        • GLISIT
                          by GLISIT
                          01-16-2025, 02:29 PM
                          by sam_sam_sam
                          03-31-2024, 02:12 PM
                        • noinimod
                          Sony 55X900E no standby light, no power. Replaced mainboard already
                          by noinimod
                          No standby red light, nothing
                          This Sony has a separate AC->DC power adapter supplying 19.5V to the TV power board (JK3)
                          Disconnected JK3 power board from main board, checked voltages on all the pin outs
                          At a few pins I can see the power supply providing 19.5V to the main board
                          Based on the service manual triage.. it seems to be pointing towards the power board (JK3) being the most possible culprit
                          LED light turns on when I disconnect LED driver board ribbon from mainboard (so i thought it is the mainboard,...
                          12-22-2021, 12:58 AM
                        • Jembang
                          coocaa 50S5G smart tv dropped voltage when connecting power supply to mainboard
                          by Jembang
                          good day hoping someone can lend a hand, im repairing smart tv 50 inch, status when turning on back light is dim but you can see the tv logo then slowly fading out to black, i check the supply to tcon, i only read 5+v, must be 12v, i removed lvds cable and check voltage to mainboard turned on its also 5v, then i remove the cable mainboard to power supply, i read 12v in power supply, thinking that the problem is in the mainboard, coz theres 12v in power supply, i also check while turning on checking volts in main board 12v dropping to 5v, im just new repairing in TV, hope someone see my post t...
                          11-01-2024, 09:55 AM
