DELL E6400
  • temronis
    • Jan 2023
    • Cameroun
    DELL E6400
    heloo where is locate charging ic of this board ?
    i have one issue no 3v 5v no voltage on bat connector.
    only 19v on many cap on the board.
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: DELL E6400
    Mb markings?
      • 21853
      Re: DELL E6400
      Beginner's guidelines
      https://www.badcaps.net/forum/showthread.php?t=88758
      1.1.3 Motherboard model number
      • Bowline
        by Bowline
        06-11-2025, 10:13 AM
      • Tynan Dill
        by Tynan Dill
        Assuming...
        11-22-2024, 01:46 PM
      • m1ch43lzm
        by m1ch43lzm
        05-12-2025, 08:37 PM
      • master3112
        by master3112
        07-29-2025, 01:55 PM
      • Garret Matt.
        DELL Latitude 5430 Rugged CORE_D5K Rev.A00 Schematic and/or Board View
        by Garret Matt.
        I'm Working on replacing an Inductor on this Dell's board and I need to come up with a compatible replacement. As much as I would like to smash a comparable 2R2 in the same spot I'd like to confirm the specs before confirming a killed board. For my purposes I'd be happy with a second opinion on the replacement inductor or the actual schematics/board view. As this is a commonly used Dell Rugged in my local service area, schematics would greatly help in the future.
        Thank you in advance for any assistance you can render.
        Inductor In question. Buzzes like...
        06-20-2025, 01:21 PM
