Asus X541UVK REV2 Charging Issue
  • neptunept
    • Oct 2023
    • 5
    • Portugal
    Hello. I was given this laptop to attempt to repair.
    At first, there were no signs of life and the MOSFET after DC input was heating up really quick when connecting the charger. This looked like a short, and soon I found a bad cap (PCI9102). This was replaced and there was some improvement: laptop powered on with the charger (no battery) and the charging LED came on in orange.
    Now I wanted to put the battery back on, but I get the following results:
    1. Laptop powers on fine only with the charger (BIOS reports battery 0%).
    2. If the battery has enough charge, laptop powers on fine and BIOS reports what seems to be the correct percentage.
    3. If I connect both battery and charger, laptop doesn't power on and does not charge (all LEDs off).
    4. If I connect the battery and power on the laptop, I may connect the charger afterwards and the laptop stays on. It just doesn't charge.
    5. With the charger on and an empty battery, measuring directly at the battery header shows me around 0.8V.
    Any ideas of what may be wrong? Thanks.
  • mon2
    • Dec 2019
    • 14660
    Re: Asus X541UVK REV2 Charging Issue
    Which charger IC is onboard? Do not have access to my schematics as I am in HK. Waiting for the mobile electronic fair to start.
    Review the dcin mosfets. Often the 2nd one will be defective in your case but review the source / drain / gate voltage to ground.
    Check the voltage of the acdrv pin. On BQ charger ics which drive n-channel mosfets, the gate should be ~25v.
    If it is not, remove the 4K resistor but do not lose it.
    Power on again. Is acdrv now ~25v ?
    If yes, review the resistance across the 2nd dcin mosfet but with no power. If low resistance, thee add mosfet is defective. It must be replaced.
    Btw - this is all from the above charger sticky by @Piernov. A must read thread.
    • neptunept
      • Oct 2023
      • 5
      • Portugal
      The IC is a BQ24780S. I will do the checks you recommended later today and post the feedback here.
      • neptunept
        • Oct 2023
        • 5
        • Portugal
        With charger only, all S/D/G were reading 19V. If I connect the battery, the reading is ~battery voltage.
        ACDRV is 19V when only the charger is plugged, and just 11.42V after connecting the battery. I can't remove the resistor right now, but I think I found something: the first DCIN MOSFET (M3056M) is now shorting between D and S (0.026Ω), while G to D or S shows 322Ω. I believe it went bad after so much overheating from the attempts of the laptop's owner to charge it, and I overlooked it after getting rid of the shorted cap.
        • mcplslg123
          • Jun 2015
          • 7262
          • india
          Whenever +19V is shorted,the 1st dc-in mosfet almost always gets partially shorted. have seen this on hundreds of baord. I usually replace the 1st dc-in fet even without measuring whenever 19V rail is shorted.
          • neptunept
            • Oct 2023
            • 5
            • Portugal
            It was only that MOSFET, now everything is normal. Thanks everyone!
            • flat-earther
              ASUS X54H laptop thinks it's always charging even with charger unplugged
              by flat-earther
              The charging indicator light on my ASUS X54H laptop is always on even when the charger is disconnected.
              Windows also shows ''Plugged in'' when charger is not connected.
              This problem started year ago gradually, when unplugging the charger the charging light took several seconds to disappear, then minutes, and now almost always on even when unplugged for an entire day.
              Strangely, before sometimes immediately when plugging in the charger the charging light went away, and later came back with it connected.
              If I let battery run out and say it has 3% Windows will...
              06-24-2025, 09:32 AM
            • bajdik
              Intermittent Power Issue on Asus X553MA – CPU Voltage Drops ftom 0.89V to 0V
              by bajdik
              I have a problem with an Asus X553MA motherboard. Sometimes the system works fine, but other times the CPU voltage drops to 0V. In most cases, the laptop reboots after a few seconds due to the voltage drop.
              Occasionally, it shows the ASUS logo or boots into the BIOS. Sometimes it can stay in the BIOS for hours without issue.
              I checked the board with a thermal camera, but I couldn't find any overheating or leaking capacitors.
              Unfortunately, I don’t have access to the schematic.
              It seems to me that when I bend the board, something changes.
              Could this...
              08-13-2025, 07:26 AM
            • Johndill
              Dell Inspiron 7567 LA-D993P odd charger issue
              by Johndill
              Hi, I have a Dell Inspiron 7567 LA-D993P that I've just got running.
              There was corrosion around PU1503 which shorted PC1518 & blew PL1504. (Reference pictures attached)
              I've replaced PC1518 & PL1504 & the laptop is now running however I now have another issue.
              Here are the tested scenarios:
              1. With the laptop running on battery, I plug in the 150W charger & the charger shuts off (no LED, protection mode) but the laptop remains running on battery.
              2. With the laptop off, plug in charger (LED says on) & the front charging...
              11-16-2022, 10:55 PM
            • Draxywezz
              bios needed ASUS E1404GA REV2.1
              by Draxywezz
              Good day! I ask for help in this bios, first the bios have password and i've try to replace with another bios and the laptop wont detect SSD at all
              Asus Vivobook Go 14
              MODEL : E1404GA-FHD351
              CODE : E1404GA_MB REV2.1
              SN : S4N0CV06930615F
              CN : SWAZ
              MFD : 2024-04
              Thank you in advance!...
              09-07-2025, 03:44 AM
            • lukkihapsi
              Asus Vivobook X515JA Weird Boot Issue
              by lukkihapsi
              Asus Vivobook X515JA Laptop
              Issue :
              Upon turning laptop ON, screen lights up - stays black & about 30+ minutes later ASUS logo is shown & boots to windows, then laptop works fine.
              Tried :
              Cleaned inside for dust, applied fresh thermal paste. No Change!
              Removed keyboard, Trackpad, fingerprint sensor. No Change!
              Removed Internal SSD. No Change!
              Updated BIOS to latest version. No Change!
              Removed battery and pressing power button for 1 minute. No Change!
              Weird Part :
              Upon turning laptop ON, screen lights up - stays black,
              I...
              07-07-2025, 12:07 PM
