820-00165 blown USB_EXTB lines to CPU, can I re-route them?
  • MuertoGB
    • Sep 2021
    • 94
    I've an 820-00165 here, the LIO board was liquid damaged, burn mark inside the USB port, and the USB2 filter which handles the USB_EXTB_P/N data lines has exploded along with a diode, clearly PP5V_USB travelled down the data lines and went to the PCH.
    USB_EXTB_P/N both have .018 diode mode to ground, which is not right, they should be more in the region of .400+ and their path is directly to the CPU on the logic board.
    My question is, can I disconnect these lines at J9500 and route them elsewhere? into USB3 maybe? My knowledge here is limited and I'd rather not replace the CPU for such a small problem.
    I'd appreciate any input, even a no not possible.
    Kind regards,
    Muero.
  • mon2
    • 14677
    Re: 820-00165 blown USB_EXTB lines to CPU, can I re-route them?
    USB traces are impedance controlled. While a bit forgiving, best to use PCB traces over hard wired - the difference (no pun) will show when pushing high speed over USB.
    Have you checked the ESD diodes on this connector? Remove them and test in diode mode again. Often they will be shorted after an ESD event.
    • MuertoGB
      • Sep 2021
      • 94
      @mon2
      Thanks for your reply, on the logic board side (where the lines are way too low) is where I'm testing the drop to ground (with the LIO disconnected), the USB signals come in from the LIO board connector J9500 straight to the CPU, so it can only be the CPU at fault. Unfortunately 5V made it past whatever protection there was on the LIO, I think maybe the diode fell off from corrosion, and was never there when 5V made it to the data lines.
      I'm guessing it will be a CPU replacement then.
      • howardc64
        by howardc64
        07-24-2025, 05:17 PM
      • Stanley1843
        Screen Display Vertical Multicolor Lines
        by Stanley1843
        Hello, I have a screen in where sometimes when I open it pop-up vertical multicolor lines (I would say the most of them are green). If I tun off and turn on the screen the lines dissapear or if I leave open the screen after approximately five minutes the lines gone. I measured the below voltages on the main PCB and on the T-CON board and the voltages are the same when it doesn’t display the vertical lines and when it displays the vertical lines. Also, I cleaned all the connectors very good with IPA. I moved back and forth the connectors and the COF tabs but the vertical lines didn't displayed...
        06-29-2024, 11:54 AM
      • cmlewis89
        LG 47LB5DF blown power supply board
        by cmlewis89
        Hi folks,
        I'm new to this forum. So my trusty 17-year-old LG 47" LCD recently died. As I was booting it up, I heard a hum followed by a loud bang, sounds of pieces flying around, and loss of power to the unit. Inspecting the PSU, I saw two obvious problems: a blown thermistor (bang + flung pieces) and a visibly bulging main cap. Inspecting as many components as I could with my Fluke MM, I diagnosed that the following components on the "hot side" of the board were also bad: one of the 2 main MOSFETs, main 8A fuse, small cap (25V 47uF) connected to main caps, and a blown...
        09-03-2024, 07:50 PM
      • jeyoung12
        Samsung QN50Q60t lines on screen
        by jeyoung12
        Hi all
        I have lines on the screen...which is an age old problem that can be remedied by watching Youtube videos and getting out the tape.
        My issue (after successfully fixing a different sammy tv with a separate tcon board and isolating the side of the panel...):
        This tv has an integrated tcon...so it is a bit more confusing when trying to isolate the clocks.
        It has a c ribbon and i have taken each end out to see if that will isolate the lines. instead, it makes it much worse ALL over the tv!
        So....i don't know what end of the C ribbon to work with...
        02-26-2024, 10:38 AM
      • Rubenlily
        Samsung QE50Q67TAU - horizontal lines
        by Rubenlily
        First of all I'm new here. While looking I found this amazing forum and I'm very happy I did. Now for my problem:
        I picked up a Samsung UHD QLED QE50Q67TAU from 2021 for $50 knowing it was defective. The seller said it had black lines and that it could get stuck in boot randomly.
        I've tried a new power cable, hard reset, opening up and jiggling all cables, pressing everywhere to see if I get a reaction but I've gotten nothing. I've tried the tape method but I've only managed to get the lines worse.
        I'm no expert but I've done the tape...
        08-16-2023, 01:12 PM
