Lenovo Legion 5 15ACH6AH No power not charging
  • MBAS111
    • Oct 2022
    • 50
    • United Kingdom
    Hi guys got a Lenovo Legion 5 15ACH6AH with no power or charging issues I have found a chip under infrared that goes pretty hot and has shorts on a few caps near it but am unable to find out what this chip is exactly and where to buy a replacement from.
    Chip is RE=7L J2W
    • 21100
    Re: Lenovo Legion 5 15ACH6AH No power not charging
    Chip is RE=7L J2W
    Thread moved to "Troubleshooting Laptops, Tablets, and Mobile Devices" forum..
    Parts with an = in the marking are made by richtek https://www.badcaps.net/forum/showthread.php?t=90619
      • 21100
      The marking RE= has been mentioned before on the forum in this thread https://www.badcaps.net/forum/showthread.php?p=1055089
      The NM-D562 Schematic is available - https://www.badcaps.net/forum/showth...hlight=NM-D562 Page 91 - PU6201 RT6585CGQW_WQFN20_3X3
      • MBAS111
        • Oct 2022
        • 50
        • United Kingdom
        Originally posted by SMDFlea
        thanks for this but im not sure what im supposed to be looking at I have tried the comparison site but nothing comes up
          • 21100
          Don`t know what you mean by comparison. Ive edited the 2 posts above to make it a bit clearer. Anyway, the part number is RT6585CGQW
          • engineerx
            • Apr 2018
            • 23
            • iraq
            Hello
            I have the same situation here with Lenovo Legion 5
            RE=9D
            D55
            its got hot in the thermal cam, what is the equivalent?
            • mon2
              • Dec 2019
              • 14287
              Just found this amazing item on AliExpress. Check it out! US $5.99 18% Off | (2-5piece)100% New RT6585CGQW RT6585C RE=.. QFN-20 Chipset
              https://a.aliexpress.com/_mrXRgpa
              https://www.richtek.com/assets/product_file/RT6585C/DS6585C-01.pdf
              • engineerx
                • Apr 2018
                • 23
                • iraq
                Thank you I'll try it .
                • Dr.d
                  Help please..Lenovo ideapad 5 14itl05 power and charging problem
                  by Dr.d
                  I have a lenovo ideapad 5 14itl05, board LA-K321P, That will only power up on Battery only, or with battery disconnected and power adapter only. If battery is connected and usb-c power plug connected. It only works on battery and will not charge. I can however force it to charge by connecting the battery from a disconnected state while the power USB c plug is powering the laptop.
                  Additionally....to add to this strange situation. The usb-c power plug ONLY works to power the laptop on one side when inserted into the boards power usb c plug. If you rotate it 180 degrees, the board gets...
                  04-05-2024, 11:48 AM
                • Scoff
                  HP Probook 470 G4 - Power and Charging Problem
                  by Scoff
                  Looking for some help with this one if anybody can assist please? I have an HP Probook 470 G4 Laptop which recently started to intermittently failing to turn on, with intermittent white LED light(charging LED) by the charging port when it should have been charging and showing an orange LED instead. Definitely some sort of gradual failure. Now the laptop fails to power on at all, no charging LED, no Power Button LED either - seemingly dead.
                  Stripped down to the bare motherboard. The original HP battery, when disconnected from the motherboard, is reading 0.00v - possibly some sort of protection...
                  07-03-2023, 09:28 AM
                • tommy97
                  Lenovo legion 7 16achg6 - no power
                  by tommy97
                  i've got problem with Lenovo legion 7 16achg6 - no power, laptop on lab PSU does not draw any power/does not power on. While on original charger, laptop does show battery charge(orange led). After power button, top LED's are lighting up - CPU/GPU cold, only heat comes from battery mosfets (up to 45degree, which seems normal on this laptop). Checked First mosfets - correct reading Source and drain 20V - Gate 26.3V. Battery 15.4V, Bios 1.8V, Power button 3.3v. Checked on different BIOS - no change.
                  Board model: NM-D563 Rev 2.0 (AMD Ryzen...
                  08-03-2024, 09:54 AM
                • Mirenia
                  Lenovo Legion 5 15IAH7 - location of BIOS chip
                  by Mirenia
                  I've got a Lenovo Legion 5 15IAH7 with no post/no boot issue.
                  The mainboard is a NM-E241 Rev 1.0
                  Now I am searching for the BIOS chip so I can reflash it.
                  But I have some difficulties to identify the correct chip. The schemantics somehow are not really helpful for me (I am a beginner with Laptop schemantics)
                  I found 3 Winson chips and one GigaDevice chip as you can see on the screenshots.
                  My guess its the W25Q128JVSIN (UB3) because it is the biggest from all.
                  I attached the pages of the schemantics from the...
                  05-31-2024, 01:31 PM
