HP 820 not power off help me pls
  • Onabit
    • Aug 2023
    • 6
    • Nigeria
    Hp 820 not power off and the button is working
    I have the schematic but I don't no where the power btn circuit is
    Pls help me.
  • themosttogain
    HP Envy 13-BA1565na with intermittent power button
    by themosttogain
    Hope someone can give me some suggestions on this because i'm at my wits end with it...
    I have an Envy 13-BA1565na here with an Intel Core i7 i7-1165G7 CPU (board is a LA-J475P Rev 1.0) which has an intermittent power button issue. The power button is integrated into the keyboard, and I have ruled out the keyboard, BIOS and battery as being the issue.
    Basically, on mains power, the power button works fairly well. The first time you come to it after leving it sitting (either on charge or not on charge), it might take 2 or 3 presses of the button, but then the laptop boots...
    07-12-2024, 03:03 AM
  • Darren Hibbert
    MacBook A2179 Audio board+Power button boardview & schematic needed
    by Darren Hibbert
    Hi.
    Long shot but does anyone have a schematic & boardview for the audio board+power button on a Macbook A2179?
    There is a shorted cap on mine and I need to know if I can safely remove it or whether I need to replace it and with what capacitor.
    Many thanks. ...
    08-21-2025, 02:38 PM
  • Tynan Dill
    by Tynan Dill
    Assuming...
    11-22-2024, 01:46 PM
  • TimeRabbit07
    Asus FX517ZC charges but power button does nothing
    by TimeRabbit07
    Hi all!
    I've got an Asus FX517ZC on the bench at the moment and I just can't figure out what's going on with it.
    Here are its various numbers and identifiers:
    Model short: FX517Z
    Model long: FX517ZC-HN114W
    SN: NANRCX01S57842E
    CN: 3SDB 12M
    MFD: 2022-10
    Motherboard model: DA0NJLMBAE0 REV E
    Symptoms:
    The laptop's charge light comes on, but when the power on button is pressed nothing happens. No fan spin, no caps lock, no screen or keyboard backlight, nothing.
    History so far:
    The...
    09-04-2024, 05:48 PM
  • reessi
    Macbook Air - 2018 - A1932 - 820-01521-02 - Bootlooping if Power Button Connected
    by reessi
    With the power button connected it either boot loops with the apple logo or no display but the charging meter shows it looping on charging every few seconds.
    No corrosion any where!
    Tried a replacement power button off ebay and the same.
    Very occasionally it will work with the power button connected!
    Same results with or without the battery.
    Can it be a fault with the Audio board or the mainboard?
    The touch Id assembly connects through the Audio board first then to the Mainboard.
    Flex...
    06-26-2024, 03:31 PM
