Dell 3537 - turns off after 9seconds
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3627
    • slovakia
    Hello.
    Have this dell 3537 that normally start, but turns off after 9 seconds no matter if it booting or in bios
    flashed bios and still the same. i found that fan cannot turn so maybe some fan checking circuit was damaged, but i changed fan and still the same
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: Dell 3537 - turns off after 9seconds
    Could be even dying SOC. Try replacing the load switch for 3V/5V to 3VS/5VS.
    • andrhouseolly
      Dell Precision 5510, AAM00 LA-C361P Rev:2.0 turns on, no image.
      by andrhouseolly
      Hi.
      I kindly ask you to help me solve the problem.
      Dell Precision 5510, motherboard AAM00 LA-C361P Rev:2.0
      The board turns on, there is no image.
      Read more. When the power supply is connected, the front panel indicators light up briefly.
      When you press the power button, the button indicator lights up. The board works
      there is no image, there is no matrix initialization, there is no image on HDMI.
      When turned on, the fans do not spin, but when they warm up they start spinning.
      When you turn off the button, the fans spin up to full speed for a short...
      05-11-2024, 03:14 PM
    • Bowline
      by Bowline
      06-11-2025, 10:13 AM
    • retrorepair2
      Dell E5470 LA-C631p - Short removed now turns on but no post/display
      by retrorepair2
      Got a really frustrating issue here, got a Dell laptop as above which initially had a short on the +POWER_SRC rail, discovered a short cap in a bank of 3 near PU801. Removed and verified the short was gone, it was and the laptop powered on, tried to load windows but just kept rebooting. Sometimes didn't post. Battery was charging.
      Stripped it back down and replaced the cap (assumed looking at the LA-632p schematic it's a 10U cap, no boardview so who really knows). Now the board doesn't charge the battery and while it powers on with a brief spin of the fans, there's no display on the...
      09-25-2025, 07:12 AM
    • manol278
      Dell laptop E6440 val91 la-9934p turns off
      by manol278
      Hi. I have problem with dell laptop E6440 val91 la-9934p rev.1.
      I turn on the laptop and it turns off instantly. After 5-6 attempts it turns on normally. I saw that it was burnt PU800, CD3301B Power Controller Chip.
      If you see in the photo someone tried to do bypass and remove PR831, PR832, PC820, PR838.
      I will replace CD3301B. I have the schematic but i dont know what are the characteristics of other componets to replace...
      [Mod. Edit]
      Schematic -> https://www.badcaps.net/forum/troubl...cs-theory/trou...
      01-26-2024, 11:50 AM
    • Kambi13
      Dell Inspiron 3542 Turns on works for 30 seconds to 1 minute then turns off
      by Kambi13
      Hi all need some help, I've got a Dell insprion 15 3542 that turns on works for about 30 seconds or sometimes a minute or two and then turns off and wont turn on again until I remove and replug the power connector
      Not heat related, everything is ok regarding to that.
      All voltages are present.
      Wondering if this as anything to do with one wire circuit, the charger is not original, but it was working fine
      Motherboard is Cedar 13269-1 F3XMC Rev A00...
      07-12-2024, 06:10 AM
