Macbook Pro A2289 - 820-01987 - Low ALL_SYS_PWRGD
  • Flasman90
    • Aug 2025
    • 14
    Hi all, I'm working on an an A2289 which had a previous spill that was repaired. Now upon turning on the only signs of life are the trackpad and fans spinning. I succesfully performed a DFU restore, but after completion it did not boot into recovery mode and display still is not turning on (It didnt turn on during the DFU restore, as I believe you would expect to see the apple logo at some point?).
    I have removed the logic board as well as the usb-c charging port and plugged the charger in and taken the following readings, which show that ALL_SYS_PWRGD is low at 1.78V. I took measurements of all the rails up to that, per the 'Power Sequence' page of the attached schematic (Boardview also attached). Any help would be greatly appreciated, as I currently take the remaining measurements in the sequence
    PPDCIN_G3H 19.9
    PP3V3_G3H 3.28
    PPVCC_S0_CPU 0.8
    PPVCCGT_S0_CPU 0
    PPVCCSA_S0_CPU 1.01
    PPVCCIO_S0_CPU 0.94
    PPVCCEDRAM_S0_CPU 0
    PP1V_S0SW 1.04
    PP1V2_S0SW 1.18
    PP1V_S3 1.03
    PP1V_PRIM 1.04
    PPVPCORE_S5 1.03
    PP3V_G3H_RTC 2.97
    ALL_SYS_PWRGD 1.78
    PCH_RTC_RESET_L 2.98
    PM_PCH_PWROK 3.27
    PM_PCH_SYS_PWROK 3.27
    PM_RSMRST_L 3.27
    PM_SLP_S3_L 3.27
    PM_SLP_S0_L
    PLT_RST_L
    PM_THRMTRIP_L
    PCH_PWRBTN_L
    CPU_PROCHOT_R_L
    CPU_CATERR_L
    CPU_VR_READY
    PMU_PVDDMAIN_EN
    UPC_PMU_RESET
    PP3V3_G3H_RTC 3.27
    CHGR_EN_MVR
    P3V3G3S_EN 1.78
    PP3V3_G3S 3.27
    P1V8G3S_EN 1.78
    PP1V8_IO_SSD0
    PPVCCQ_ANI_SSD0
    PP0V9_SSD0
    PP2V5_NAND_SSD0
    SSD0_WP_L
    SSD0_OCARINA_PFN_L
    SSD0_OCARINA_RESET_L
    SSD_PMU_RESET_L
    PP3V3_AWAKE 3.27
    PMU_COLD_RESET_L
    PM_SLP_S4_L
    PM_SLP_S5_L
    TP_SMC_FIXTURE_MODE_L
    PP1V8_SLPS2R 1.78
    SOC_SOCHOT_L
    PP1V2_AWAKE 1.19
    PP0V82_SLPDDR 0.81
    PPVDDCPU_AWAKE 0.91
    PP1V8_S5 1.78
    PPBUS_G3H 12.5
    PP1V8_G3S
    PMU_ACTIVE_READY
    PP3V3_S5
    PVCCIO_EN
    CPU_C10_GATE_L
    PP0V9_SLPDDR
    PP1V1_SLPDDR
    PP1V1_SLPS2R
    PP1V8_AWAKE 1.78
    PP1V8_SLPS2R_PMUVDDGPIO
    P1V1_SLPDDR_SOCFET_EN
    PMU_CLK32K_WLANBT
    SOC_WDOG
    PMU_CLK32K_SOC
    PMU_SYS_ALIVE
    P5VG3S_EN
    PP0V8_SLPS2R
    PPVDDCPUSRAM_AWAKE 0.79
    P5VG3S_PGOOD
    PM_SYSRST_L
    SMC_SYSRST_L
    PP5V_G3S 5.08
  • mon2
    • 14394
    ALL_SYS_PWRGD is OK @ 1v8 due to the pull-up resistor @ R8005. This logic line operates at 1v8. With this status, the voltages being monitored are OK.
    • Flasman90
      • Aug 2025
      • 14
      I see, thanks Mon. I'm now focusing on the CPU rails that are presenting 0V. In light of PPVCC_S0_CPU being 0.8V and being produced by U7210 and U7210 I'm Currently reviewing the datasheet for those chips to see if there are any issues with those.
      Last edited by Flasman90; Today, 12:00 PM. Reason: Edited to correct incorrectly referenced power rail PPVCCGT_S0_CPU to the relevant one - PPVCC_S0_CPU
      • mon2
        • 14394
        https://boards.rossmanngroup.com/thr..._s0_cpu.61634/
        post # 2
        • Flasman90
          • Aug 2025
          • 14
          Sorry, I meant PPVCC_S0_CPU which is produced by those two chips and is low at 0.8V, not the video related power rails! I have edited my initial response to reflect this. However, Mon you mentioned the voltages being monitored seem okay, so I will progress with measuring the remaining rails in the power sequence and see if there are any issues with those.
          widgetinstance 457 (Related Topics) skipped due to lack of content & hide_module_if_empty option.
