MSI MS-17F51 Chip
  • asdas09
    • May 2023
    • 19
    • Finland
    MSI MS-17F51 Chip
    Anyone know it is this the bios chip or someone other? It's burned. No available boardview or schematic for MSI MS-17F51.
    I checked the MSI MS-17F31 boardview and there is added the info "TSSOP8" for chips of this size.
    MOD Edit, Link to boardview -> https://www.badcaps.net/forum/showthread.php?p=1268604
    Reminder: rules and organization of this section -> https://www.badcaps.net/forum/showthread.php?t=117483
  • ResoluteHawk
    • Nov 2021
    • 154
    Re: MSI MS-17F51 Chip
    Your BIOS chip is U37. It's located above and to the right of the PCH/Chipset (the big chip on the left side of your photo).
    If the chip in the first photo is the same chip as the chip in the 2nd photo, it looks to be a USB load switch.
    What problem are you running into exactly? Is the system not powering on? Not posting? USB ports not working?
    If that chip is burned I would take it off to start with.
    • asdas09
      • May 2023
      • 19
      • Finland
      I removed that burned chip. I can replace to this any the tssop-8 USB load switch chip? Example. https://www.digikey.com/en/products/...4-1YMM/1028557
      • asdas09
        • May 2023
        • 19
        • Finland
        Still the system won't turn on, fan won't spin, no light etc... When connect to the charger and check with a thermal camera, you see that this chip (PU5) WQFN20_TSMDQ63 soon very hot about 50°C.
        This chip also bad because it is so hot? What I also know is that SW_3V3 / +3VSUS is shorted.
        • ResoluteHawk
          • Nov 2021
          • 154
          PU5 looks like your 3.3v/5v buck converter.
          Speaking from experience here; if this chip heats up when power is plugged in, it usually means that your Super IO chip (U22) is fried.
          Just because PU5 heats up does NOT mean that the chip is bad. To verify that your 3.3v/5v buck converter is good, make sure that the input voltage is good (19-20v) on PC59, and make sure that the chip is producing the correct voltages (3.3v and 5v). Check PC65 for 3.3v and PC60 for 5v.
          Check for shorts on the capacitors around U22 (C928, C929, C932, C941). 3.3V should be present on each of these capacitors. If a lesser value is present, then your Super IO needs to be replaced.
          • asdas09
            • May 2023
            • 19
            • Finland
            All shorted U22 (C928, C929, C932, C941).
            PC60 - 9v
            PC65 - 0.37v
            PC59 - 19V
            PR116 - 0V
            PR79 - 0V
            I removed also the burned resistor (PR93). I can replace any resistor that looks like the same original resistor?
            It seems that the (U52) chip is also burned because there is a big black mark on it. Shorted capacitors around it C1226, C1240.
            • asdas09
              • May 2023
              • 19
              • Finland
              I found what a chip this really is MSOP-8 G547I1. This not added to boardview MSI MS-17F31 because motherboard is little different than MSI MS-17F51. Anyone know, need to be programmed like this chips?
              • mon2
                • Dec 2019
                • 14677
                This USB load switch does not need programming. It is a fixed max current electronic fuse that will cut off the vbus power rail if the preset current threshold is exceeded. Will reset after the event is removed but often these devices get nuked in the event. More crapware.
                • acedogblast
                  by acedogblast
                  11-02-2024, 05:13 PM
                • DynaxSC
                  ASRock B650M PRO RS - BIOS CHIP 25Q256JW BLOCKED BY STATUS REGISTERS
                  by DynaxSC
                  Hi
                  I have then desoldered the chip, backupped the contents, and tried to earease the chip in order to program stock image, but the chip is locked by status registers SREG2 (TB) and SREG6...
                  08-04-2025, 12:20 PM
                  by SMDFlea
                  Bad...
                  09-02-2021, 04:40 PM
                • kodox
                  Toshiba Portege Z30-A - Burned Chip Identify
                  by kodox
                  received unit with no power at all, pluged bench PSU and not consuming any amperage, measurement shows that 19V only reaching first mosfet & gate voltage only 6V.
                  visual inspection found that it has burned chip, marking code wasn't too clear under microscope, i guess it's "A C C I". the chip is located under huge diode with UCQ1QA03 marking on it, since i don't find any schematic or boardview for this model, wandering that someone had similiar board and kindly measure what voltage comeout from the inductor connected to that chip or maybe knew what model number of the chip...
                  09-15-2023, 09:38 PM
                • Troystain
                  Help EZP2023+ updated chip database for w25q256jveq?
                  by Troystain
                  Hello, anyone here have updated ezp2023+ chip database in .dat file format.
                  I need to add w25q256jveq chip but I do not know what data should I type.
                  I'm using the ezp chip dabase editor posted from here https://www.badcaps.net/forum/troubl...ro-programmers
                  The currenty unit model that I am trying to detect is HP elitebook 640 g9 which is currently locked on admin bios....
                  11-25-2024, 12:53 AM
