Dell 3421 wont turn on with strange behavior
  • julianmustofa
    • Dec 2021
    • 39
    • indonesia
    Hi all
    I've been working on dell 3421 that won't turn on/charge
    Specs: i3-3217U no discrete gpu
    The behavior is
    -won't charge (charging light up for 3 second and goes away)
    -won't turn on if both battery + power adapter plugged in
    -in other way it can turn on with either power adapter only or battery only
    But sometimes all this issue goes away with no clear reason.
    Does it indicates faulty board chipset?
  • mon2
    • Dec 2019
    • 14742
    Re: Dell 3421 wont turn on with strange behavior
    Review the DCin mosfets. Often the 2nd DCin mosfet will be leaky. Review the sticky article above by @Piernov on charger circuits.
    • julianmustofa
      • Dec 2021
      • 39
      • indonesia
      Digging around and just found out that 5v/3v tps51225 was faulty and glowing hot
      • mcplslg123
        • Jun 2015
        • 7262
        • india
        Before going for replacement of 51225 Ic,do take measurements of PSL logic circuit. Often, its PSL fault and not the PWM itself. Other reason could be shorting in RTC circuit.
        • julianmustofa
          • Dec 2021
          • 39
          • indonesia
          Ah, I'am so late for this.
          You're correct, the pwm it self was fine
          Still searching the rabbit hole..
          • Th3_uN1Qu3
            Believe in
            • Jul 2010
            • 6031
            • Romania
            I'd check the peripherals that are connected in standby. Could be a bad keyboard or touchpad or the KBC chip itself.
            A working TV? How boring!
            • mcplslg123
              • Jun 2015
              • 7262
              • india
              Going by this board, its either shorted/leaky RTC and/or PSL circuit.
