Hi, I have a 880M GTX that has a short. I removed the coils from the VRM side and the short still present so its from the GPU side?
			by StephenI check PPBUS_AON and there is a short present on the line, the computer shows a short when testing for short to ground, so when I inject voltage into the line, I get 0AMPS so no short is showing up. I have replaced a blown cap on this board that exploded and tested for the short and it is now removed. Any suggestions? I tested voltage at the line when the fuses are connected and I am getting 1.2 Volts at the line.
			by adelfr2009I have a laptop HP Victus 15-fb with motherboard DAG3PRMB8D0, CPU Ryzen 7535HS, and GPU RTX 2050. The laptop has a power issue: it does not turn on at all, and there is no light on the DC jack.
 After inspection, I found that an NMOS near the charger input had a short. I replaced it, but the short remained on the 19V line. I checked the charging circuit and it was fine, but the short appears after the current sense resistor near the charger. The charger does not pass current when connected, so I inject 3Vā4V after the sense resistor. No component gets hot, except the CPU which becomes...
 I'm trying to repair my old Acer Nitro 5 (AN517-54-55T5). I've already bought a new laptop, so this is more of a learning project. For the experience, with no high expectations of success.
 Well, my decice specs are the following:
 Model: Acer Nitro 5 AN517-54-55T5
 CPU: Intel Core i5-11400H
 GPU: NVIDIA GeForce GTX 1650
 Motherboard: GH51G LA-L181P Rev:1c
 The symptom:
 When pressing the power button, the power LED lights up for about 5 seconds and then turns off. Initially, the issue was intermittent: sometimes...05-26-2025, 10:49 AM
			by u666saLaptop is HP Envy x360 13-bf0013dx, hp website link, it's an i7-1250U with 8 gig onboard ram.
 Platform: ipa32 la-m024p rev 1b
 Originally you'd plug power supply into it and it would take up to 1.2 amps and then drop to 200 milliamps and then go back up again to 1.2, staying all the while at 5 volts. Pressing power button would results in power LED blinking amber 3 times. 3.3 volt rail, 5.1 volt rail present, main power rail 8.8 volts. Power button test pads near EC chip 2.7 volts.
 I found a short on the other side:
 ...10-04-2025, 05:03 PM
			by lapfixLenovo Air 15ITL.
 NM-D211
 This laptop won't power on , when power supply is on it takes 0.001 , button trigger on it becomes after a couple of seconds 0.061 amp..and nothing
 No heating (Of COURSE) , no short to GNd at all coils present , 3/5 valw is present , 3/5 vl present.
 With the power plane , at state 4 +1.8VALW and +3ALW_PCH must be present but no one due to enable signal is missing .
 when button trigger on , 3v dow to zero than 3v , the super io send BTN_OUT#_R to pch but no rsmrst ..0v.
 i follow his line , no short .
 ...10-21-2025, 05:53 AM
- Loading...
