HP 840 G6 - no backlight
  • YKMN
    • Dec 2022
    • 29
    • NL
    Hi, i have here HP 840 G6 (6050A3022501-MB-A01) with no backlight and i can't find the problem which causes it. Laptop is booting it gives image without backlight on LCD, it gives image also over HDMI.
    What i did already:
    - check all fuses on mb(ok)
    - measured on LCD mb fuses, ok, one have 11,99v other one 3.3v
    - swapped the LCD with working one (no effect same problem no backlight)
    - searched for short (in connector area) on mb couldn't find anything
    - checked connector pins on both sides - ok
    - BIOS updated to newest version
    LVDS_VDD_EN_TOUCH - 3.3v
    BKLT_EN - 3.3v
    LID_SW#_3 - 3.3v
    If somebody can direct me to more test or solution ill appreciate that.
  • mon2
    • 14660
    Re: HP 840 G6 - no backlight
    Since a known good lcd behaves the same, review U3001.
    • YKMN
      • Dec 2022
      • 29
      • NL
      I have no clue how could i missed that switch, it was shorted intern GND with pin 3, changed it with another one and backlight is working again! Thank you for support mon2
        Surface Mount Fuses Fundamentals Datasheet
        TE Circuit Protection offers the widest selection of surface-mount fuses available for addressing a broad range of overcurrent protection applications. Helping to prevent costly damage and promote a safe environment for electronic and electrical equipment, our single-use chip fuses provide performance stability to support applications with current ratings from .5A up to 20A.
        TE Circuit Protection also offers the telecom FT600 fuse for telecommunications applications. This telecom fuse helps comply with North American overcurrent protection requirements, including Telcordia, GR-1089,...
        10-07-2024, 06:07 AM
      • triplefour
        by triplefour
        09-13-2023, 10:43 PM
      • DanPoka
        by DanPoka
        02-15-2025, 05:05 AM
      • Comp_Pro
        No Backlight Macbook A1990 820-01041
        by Comp_Pro
        Hello all,
        Am trying to figure out this backlight issue with this A1990 Macbook Pro.
        Tests performed:
        There is no backlight even with a good screen.
        Backlight IC is receiving the correct support voltages.
        Fuse F8400 ok
        Current sense resistor R8400 ok
        Backlight IC is receiving 3.3V on enable pin.
        Backlight IC receiving voltage from PPBUS_G3H, aprox 12.5V.
        Backlight IC receiving 5V from PP5V_G3S
        Backlight IC BKLT_SCL and BKLT_SDA both measure 0.545V diode mode to ground
        I2C_BKLT_SCL and I2C_BKLT_SDA both measure...
        05-06-2024, 10:23 PM
      • cheebster
        iPad Pro 12.9 5th Gen Backlight Issue
        by cheebster
        Hello, got an iPad Pro A2378 12.9 5th gen with no backlight. Got another test unit without screen, tested the screen, still no backlight with the test unit.
        Figured out the backlight on the screen was bad, ordred a new backlight from mobilesentrix, *carefully replaced it* without damaging the lcd, oh well.
        Final result, issue is still there, the screen has no back lights. So i'm back to square one, with 3 hours less and 100$ out, issue still on the screen.
        The panel is still ok, i can see the apple in the middle of the screen when it kicks in, just no backlight.
        Anyone...
        05-20-2025, 09:17 AM
