how to reflow laptop graphic chip
  • saqi80
    saqi
    • Oct 2010
    • 6
    Hi Everyone,
    i am new to this forum, will try my best not to bother u ppl.
    Basically i want to know how to reflow graphic chip of laptop, i have got hot air, can anyone tell me what temprature shud be, how long shud i keep it on graphic chip, what shud be distance b/w chip and hot air and other necessarily things?
    sorry for bad english
    thanks
  • shovenose
    Send Doge Memes
    • Aug 2010
    • 6575
    Re: how to reflow laptop graphic chip
    you could just put it in the oven for like 10mins.
    heat guns are good at frying other components.
    • PCBONEZ
      Grumpy Old Fart
      • Aug 2005
      • 10661
      Ovens are better than heat guns for frying other components because they heat EVERYTHING.
      Mann-Made Global Warming.
      - Dr Seuss
        • 31247
        he's not got a heat gun because he's asking about the temperature.
        i think he probably has an smt air station.
        it needs flux injected/sprayed under the chip before you heat it btw.
        • saqi80
          saqi
          • Oct 2010
          • 6
          yeh u right i got air station but want to know how long(duration) shud i heat it for and what temprature shud be? shud i heat it under the chip or oven the chip?
          dont want to try oven anymore as i had bad experience doing with oven, it made motherboard stop working in the past so bit freaky.
          Thanks for your response
          • lasttarget
            • Jul 2010
            • 10
            Heat gun is not the way to go. If you want to do it right you have to reball. There is no other way than to reball for a permanent fix. The problem is that the solder balls used are lead free and although they have a higher melting point then lead solder, they are more susceptible to cracking under heat strain. You must reball with lead solder balls. A heat gun will probably popcorn the chip and you will have a graphics error again in the near future.
            Doing it professionally cost a lot for the equipment alone.
            You will need:
            stencils
            IR station
            Hot air gun
            Liquid flux
            paste flux
            thermal couple(s)
            aluminum foil tape
            kapton tape
            soldering iron
            wick
            suction pen
            On top of that you will need a lot of experience and knowledge
            Do not use your hot air gun on the chip unless you just want to use it a bit longer till it dies. If you do, a real repairman like myself wont even be able to salvage the chip.
