Macbook 820-00923 Stuck at 5V 0Amps
  • Instafixx
    • Jul 2022
    • 374
    • India
    Namaste.
    I have a macbook A1706 which is not having any reaction on the amp meter.
    The amp meter doesnt reboot or show any current draw.
    This is on all 4 charging ports.
    PP3V3_G3H is shorted to ground.
    Replaced the Charging Ports with known-good charging ports too. Same issue.
    Interestingly i found that the CB300 (Below the Metallic Shield) was missing and another resistor was missing. Restored them from a donor board but still same.
    I am unable to locate the issue.
  • Bmet
    MacBook Pro 13 inch A2238 M2 stuck on 5V
    by Bmet
    I have a MacBook Pro 13 inch A2238 M2 and it was stuck 5V with 0 amps. I measured some important lines and I found a short on PP3V8_AON_MPMU_ISNS_VIN, I tried injecting 1v and I saw heat coming from the mPMU so I removed the pmu thinking that was the problem. I don't know why I didn't check the other side of the border but there it was, a shorted cap. I replaced the cap and the short was gone, so I reballed the PMU and put it on again but voltage was still stuck at 5V and the current was fluctuating between 0 and 0.45 amps. I checked under the thermal camera and I saw the mPM...
    04-02-2025, 05:02 PM
  • Steven Pieter
    Macbook Pro A1706 820-00923-05 Stuck At 5V 0.03A
    by Steven Pieter
    hello everyone, let me ask, I have a macbook which is stuck at 5v and 0.03 A when tested with a usb tester. Previously I wanted to replace the screen on the device, but by accident I forgot to unplug the battery. This caused the MacBook to get stuck at 5v, previously I had replaced the CD3215 (U3100) IC because it was warm. After I replaced it the problem was still not resolved. Please guide. Thank you
    11-24-2024, 10:02 AM
  • DATATECH85
    Macbook Pro A1990 - 820-01041 Stuck at 5V / 0.02A
    by DATATECH85
    I am currently working on a Macbook Pro A1990 (motherboard 820-01041) which is not charging.
    The Macbook consumes 5V and 0.019A at USB-C. There seems to be a partial short-circuit on the PPBUS_G3H rail as I have 0V on this rail.
    I've physically separated (by removing F7000 and F7001) PPBUS_G3H and the ISL9240 charging chip to see which side the short is coming from. Removing these fuses gives me 12.6V at the output of the ISL chip (PPVBAT_G3H_CHGR_REG).
    However, I can't work out exactly why I don't have the PPBUS_G3H rail.
    Here are the values...
    07-24-2024, 06:34 AM
  • martyjelen
    Apple MacBook Pro 16-Inch 2019 - A2141 - stuck at 5V
    by martyjelen
    Hello, I have this Macbook A2141. It stuck at 5V / 0,075A. I measured all 4 ports, all the same. PPBUS_G3H is present but only 12,3V. Should be 12,6V ? according to this article : https://repair.wiki/w/MacBook_Pro_A2...w_at_5V_repair
    PP3v3_G3H_RTC_X is present - 3,3V
    PP3v3_G3H_SOCPMU is present - 3,3V
    ​What else should I check?
    Thank you for your help.
    05-05-2025, 01:34 AM
  • duwane
    MacBook Air A2337 - 820-02016 - Stuck at 5v - Varying current draw - Board had short
    by duwane
    Hi All.
    I have an 820-02016 board (A2337 M1) that has come in for data recovery. Reported as liquid damage, but no visible evidence of any liquid damage.
    Board was initially stuck at 5v, and current only spiking occasionally to around 400mA and cycling.
    After initial troubleshooting, found that C7800 (which feeds the power rail PP5V_BSTLQ_VOUT_SPMU) was dead short to ground.
    Replaced C7800 and short gone. Board still stuck at 5v. Current draw behaviour changed. It now spikes up for a second to around 100mA to 130mA, then drops down to...
    10-17-2023, 07:48 PM
